Chase1 Samba Member
Joined: January 26, 2004 Posts: 28 Location: DC Metro
Posted: Sun Jun 18, 2017 5:34 am Post subject: 3 wire turn signal strap |
I am looking for the mounting strap to attach the switch to the steering column. Is anyone aware of someone selling reproductions?
Matts Bug Parts Samba Member
Posted: Sun Jun 18, 2017 7:18 am Post subject: Re: 3 wire turn signal strap |
You need to be specific. SWF and Hella were OEM suppliers and their straps are slightly different and not interchangeable, where the part sits in the housing, Hella is wider. Then there were aftermarket switches, for example SWF red knob and I think that strap may differ but I am unsure. There were also other iterations, Bosch red knob used a totally different strap system.
Finally, I am not aware of any repro.
Matt |
Chase1 Samba Member
Posted: Sun Jun 18, 2017 9:11 am Post subject: Re: 3 wire turn signal strap |
I guess the first step is figuring out which brand I have...
Posted: Sun Jun 18, 2017 12:49 pm Post subject: Re: 3 wire turn signal strap |
Look for markings on brown "bakelight" part of switch where wire screw terminals are.
PS, I have never had any spare Hella,straps but have found NOS SWF in the past.
Matt |
Chase1 Samba Member
Posted: Sun Jun 18, 2017 2:25 pm Post subject: Re: 3 wire turn signal strap |
This is the best picture I could get of the area.
Posted: Mon Jun 19, 2017 12:28 am Post subject: Re: 3 wire turn signal strap |
I am in Germany, returning home next week. I can help once home with some measurements since I see no marks and assume you have looked and found none.
Matt |
Chase1 Samba Member
Posted: Mon Jun 19, 2017 2:28 am Post subject: Re: 3 wire turn signal strap |
Correct. I looked all over the unit and could not find any markings. The last photo I posted shows the area where I suspect the marking was located, however, it looks to be somewhat corroded.
On the bright side, the terminals look good and it is functional.
I'm not in a hurry, I appreciate the help so far. |
