Bob Brugge Samba Member
Joined: April 09, 2015 Posts: 721 Location: Missoula, MT
Posted: Sun Jun 18, 2017 2:42 pm Post subject: Rod VW part number |
Can anyone identify what this rod pn is please?
113 105 411
I think they measure 5.1875 if I read my Stanley tape measure right.
Which gives me an idea
I want to build a 74x88mm 1800cc. You can use 5.325" rods and retain an engine that is real close to stock width.
If these are as short as I think they are, the difference between these and 5.325 rods is just under 3.5mm.
Does that mean I could go 76mm or even 78 mm crank ending up with an 1850 or even a 1900?
The 88mm jugs only come in A piston variety and I am thinking the shorter rod would make up for the difference in pin height of the B piston.
Is there enough room at the skirt of the piston to clearance? _________________ Keep on Dubbin'! |
vwjetboat Samba Member
Posted: Sun Jun 18, 2017 4:44 pm Post subject: Re: Rod VW part number |
I thought they might be.
I tried to stick'um on a junk crank I have to see if I could get a rough guess of clearencing needed. The rods are to wide to fit around the journal between the counterweights. The crank is a 76mm and it looks like there could be enough room on the swing to clear the pistons. Anyone else done this? If the rods are too wide by a few thou, would it be a terrible idea to have them and the bearings milled down?
Since it is too wide to fit in the crank, I wonder if the journal size is the same?
Thanks in advance!
Edit: I got my 5.1875 measurement by taking the rod cap off and measuring from a flat surface I had it on to as close to the centerline of the small end as I could eyeball _________________ Keep on Dubbin'! |
FeelthySanchez Samba Member
Joined: February 03, 2011 Posts: 1349 Location: Now is that a real poncho, or a Sears poncho?
Posted: Sun Jun 18, 2017 5:17 pm Post subject: Re: Rod VW part number |
As noted, the 40HP conrod is 1mm wider than 1300/1500/1600. It's also a whole lot shorter on center-to-center. Rod journals are the same dia.
The real problem will be wrist pin diameter: believe it's 20mm for 40HP rods.
Bob Brugge wrote: |
Anyone else done this? If the rods are too wide by a few thou, would it be a terrible idea to have them and the bearings milled down? Since it is too wide to fit in the crank, I wonder if the journal size is the same? |
modok wrote: |
I would like if you had enough clue to communicate what you are doing. |
Ryan Tucker wrote: |
Enough clue..Whats that mean? |
OldIronSpine wrote: |
I'm not sure how compression works.
Turbos don't produce torque, they produce HP. Instead of torque.
The real problem with NA engines is you don't hear the nice whine of the turbo as it spools up.
Before I commit, I'm going to do more research because I don't really know what piston rings are. |
Posted: Sun Jun 18, 2017 6:37 pm Post subject: Re: Rod VW part number |
I realized that as well. What is the o.d of that bushing? I have seen on here somewhere someone was talking about using a 40 hp rod with no bushing. I also saw where someone said they make a 40 hp rod with the 22mm wrist pin bore, but I can't find them.
Looking at aircooled.net I see even shorter rods but no mention of the wrist pin size, only that it fits 2.0 journals. Would these be for w/c? _________________ Keep on Dubbin'! |
mark tucker Samba Member
Posted: Sun Jun 18, 2017 6:51 pm Post subject: Re: Rod VW part number |
I never thought about using a tape mesere to messure rods.me~sure it wont be exzact. |
Posted: Sun Jun 18, 2017 7:04 pm Post subject: Re: Rod VW part number |
No idea offhand what bushing OD is. A good archive search topic, tho.
Sans bushing would be rather scary.
The "even shorter rods" from ACN may just be native to T4/2.0L 914, which are very short & I believe sport a 24mm pin.
Bob Brugge wrote: |
Looking at aircooled.net I see even shorter rods but no mention of the wrist pin size, only that it fits 2.0 journals. Would these be for w/c? |
modok wrote: |
Posted: Sat Jun 24, 2017 5:50 pm Post subject: Re: Rod VW part number |
mark tucker wrote: |
Not the most accurate tool to use for sure. I was a carpenter for 15 years and I got pretty good w/ my Stanley 25'. I am super curious how close I came. Mostly I was trying to guestimate the difference between a 5.325" rod and a 40hp rod, then convert that to mm to see if I could use a larger crank _________________ Keep on Dubbin'! |
