Busman1985 Samba Member
Joined: May 24, 2017 Posts: 67 Location: Cleveland GEORGIA
Posted: Mon Jun 19, 2017 1:41 pm Post subject: Should I be concerned? |
I recently bought a 1.8 ec block unseen for $100, when i got it I noticed these grind marks on the inside. Is this block still usable, or is this something I should be concerned with? I seen a engine build on google where someone grinded on the block for clearance issues, but don't know if this is a common thing or just someone doing something stupid. I've got an engine lined up to buy, but was going to rebuild this one as a spare. Thanks
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Mon Jun 19, 2017 1:50 pm Post subject: Re: Should I be concerned? |
dumpster bait by the looks of it. unless someone was doing a very high lift cam. in that case, it may be ok....I don't think they used a grinder....looks like the used a hatchet _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Tcash Samba Member
Posted: Mon Jun 19, 2017 1:59 pm Post subject: Re: Should I be concerned? |
If this is a crack, it would need to be repaired.
It does not look like they took that much off. I looks like they took the concave out of them.
Danwvw Samba Member
Posted: Mon Jun 19, 2017 2:06 pm Post subject: Re: Should I be concerned? |
Probably someone did that to run a 71mm crankshaft in it. If the lifter bores are not warn inside or cracked I don't see a problem with it. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Thanks for the help! I haven't opened the case up yet to inspect it for cracks, but I'll definitely check that spot out as soon as I do. |
Danwvw Samba Member
Posted: Mon Jun 19, 2017 2:36 pm Post subject: Re: Should I be concerned? |
Or it could have had a broken crankshaft happen that did it. Just make sure the case haves come together as they should. One thing you can do is bolt the empty case halves together with just the primary case bolts and shine a flashlight in one crank hole and look in the other and you will see light shinning through between the case halves if it doesn't come together as it should. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Mon Jun 19, 2017 3:02 pm Post subject: Re: Should I be concerned? |
Ok I'll be doing the flashlight trick for sure! |
Tcash Samba Member
Danwvw Samba Member
Posted: Mon Jun 19, 2017 4:48 pm Post subject: Re: Should I be concerned? |
Yeah, come to think about this a bit. it couldn't be that the crank did it because it's under a lifter. It almost looks like something done with a chisel when the case was taken out of it's mold when it was made. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Mon Jun 19, 2017 5:12 pm Post subject: Re: Should I be concerned? |
I agree that someone may have clearanced the case to run a high lift cam. Put some light oil on a lifter and try it in the bores. Let the lifter stick half way out toward the inside of the case and try to move it up and down. You should be able to detect not even the slightest movement. Even with light oil you should still feel some resistance as you slide the lifter in and out.
You can buy inserts to fit into the bores so that you can run Type 1 lifters. You could go this route of the lifter feel loose in the bores. |
Posted: Tue Jun 20, 2017 6:22 am Post subject: Re: Should I be concerned? |
Ok thanks for all the help! I will do everything you all listed before I even think about using it for a rebuild. Thanks again! |
