markcm2 Samba Member
Joined: September 02, 2015 Posts: 505 Location: Bellingham, Washington
Posted: Mon Jun 19, 2017 6:05 pm Post subject: 6.5' Collapsible ladder for accessing roof top storage box |
I thought I'd share this. We bought a 6.5' Collapsible ladder to access our roof top cargo box. I also built a little riser to slide the ladder under so we can still stack camping or other supplies on top.
I got this from Amazon for $75 prime and it is worth every penny and then some.
Yi Hai 6.5ft Portable Aluminium Telescoping Ladder Extension Multi Purpose Lightweight https://www.amazon.com/dp/B0196DL3YI/ref=cm_sw_r_cp_api_7mhszbH0V2Z94
sdunn35 Samba Member
Joined: September 05, 2008 Posts: 38 Location: Concord, CA
Posted: Tue Jun 20, 2017 10:03 am Post subject: Re: 6.5' Collapsible ladder for accessing roof top storage box |
Nice solution - much more elegant than my aluminum step stool, which, because it only fits on the roof rack next to the Thule box, I have to stand on the rear tire to un-velcro it before I can get it down and then use it to access the Thule box. This is more civilized _________________ 99 EVC
ex-03 Weekender |
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1266 Location: Bethlehem, PA
Posted: Tue Jun 20, 2017 10:08 am Post subject: Re: 6.5' Collapsible ladder for accessing roof top storage box |
I actually bought that same one a month ago and just used it for our camping trip. I didn't know how it would work because it just sat in the box until I left last week. |
Zeitgeist 13 Samba Member
Posted: Tue Jun 20, 2017 12:13 pm Post subject: Re: 6.5' Collapsible ladder for accessing roof top storage box |
Thanks for posting this. We're strongly considering one of these prior to our Summer road trips _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Tue Jun 20, 2017 3:55 pm Post subject: Re: 6.5' Collapsible ladder for accessing roof top storage box |
We have been finding the simple wood riser just as valuable as the ladder. It really minimizes the space and makes it so easy to access. I made it out of some scrap wood that was laying around.
The ladder is light and sturdy, love it! |
Posted: Tue Jun 20, 2017 4:02 pm Post subject: Re: 6.5' Collapsible ladder for accessing roof top storage box |
I want a heavy rickety ladder instead. One with splinters is even better. |
IdeaNerd Samba Member
Joined: May 24, 2016 Posts: 597 Location: Central California
Posted: Sat Jul 01, 2017 7:19 pm Post subject: Re: 6.5' Collapsible ladder for accessing roof top storage box |
markcm2 wrote: |
We have been finding the simple wood riser just as valuable as the ladder. It really minimizes the space and makes it so easy to access. I made it out of some scrap wood that was laying around. |
When you first posted this I wondered about that -- seemed like a really simple, handy way to accommodate an item that would otherwise be difficult to pack well, and prone to "grabbing" other things when pulled out. Thanks for sharing! |
rcowan Samba Member
Posted: Thu Sep 06, 2018 1:06 pm Post subject: Re: 6.5' Collapsible ladder for accessing roof top storage box |
Thanks to Mark's advice, I just bought one of these ladders. I like it a lot! We have been using it to load bikes on the roof. Not the easiest task to begin with but it works quite well. The link above didn't work for me but I bought the one linked below and I believe it's the same ladder. Thanks again Mark!
https://www.amazon.com/gp/product/B0196DL3YI/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1 |
Posted: Thu Sep 06, 2018 1:16 pm Post subject: Re: 6.5' Collapsible ladder for accessing roof top storage box |
Glad to hear it is working well for you too. This ladder is still one of the most appreciated accessories. This past weekend we had a full spacebox and a paddle board on top the van which made the top too heavy to self support. In a pinch, I used the ladder to prop up the top to ensure it wouldn't collapse on us overnight.
Also, a new storage location for our ladder has been constructed, integrated into our new pull-out drawer:
Posted: Thu Sep 06, 2018 2:38 pm Post subject: Re: 6.5' Collapsible ladder for accessing roof top storage box |
When you found the top was too heavy, did it want to drop back down straight or cant over to one side or the other? I recently replaced the top struts as a pair, but prior to that I always got nervous when putting stuff up top and then lifting the top. I couldn't help but feel that it was going to wrack itself and twist the rear hinges.
We also love that collapsing ladder. _________________ Casey--
y u rune klassik? |
Posted: Fri Sep 07, 2018 9:09 am Post subject: Re: 6.5' Collapsible ladder for accessing roof top storage box |
Zeitgeist 13 wrote: |
We also love that collapsing ladder. |
I'm pretty sure I need new pop-top lift struts. Even our empty spacebox and yakima racks make the top questionable, adding anything to the spacebox makes a issue with top support. When closing the top with any load on it I have to pull while pushing on one side or the other to keep it straight; its definitely not right.
Did the new struts make a noticeable improvement for you and did you get the stock weekender struts? I've heard there are heavier duty struts available to but they may be difficult to close with no load on the top. |
Posted: Fri Sep 07, 2018 10:41 am Post subject: Re: 6.5' Collapsible ladder for accessing roof top storage box |
I haven't tried pushing up on the top with a load since I replaced the struts. We usually carry a paddle board (25lbs) and a kayak (50lbs) and the weight disparity was what caused the wracking. I'm hoping the new struts, which were very difficult to compress enough to install, will fix this issue. _________________ Casey--
y u rune klassik? |
saintjobe Samba Member
Joined: August 20, 2006 Posts: 45 Location: Denver, CO
Posted: Fri Sep 07, 2018 1:26 pm Post subject: Re: 6.5' Collapsible ladder for accessing roof top storage box |
I also just got the ladder, similar one from Go Westy. I do love it, but I access my box from the same side that my awning is on, so if the awning is out it's a little odd to get into the box from the back. Guess that's my fault though.
As far a roof weight. I have a box and a medium road shower on my racks. I also have the go westy locking roof struts which I think are key since my kids sleep in the top. I have found that I can lift my roof, although it takes my wife and I together, when there is a bit of stuff in the box. I try to pack mine with lite stuff like sleeping bags, pillows, kites, my shower enclosure, etc... I will say that when the road shower is full (about 75 lbs) I do not like the way the roof goes up, especially since it is mounted all the way to one side. If I completely empty the box it can be done though, carefully. |
