ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Mon Jun 19, 2017 8:56 pm Post subject: mkIII odometer reset |
I found an "easy" way to reset the odometer on our 94 Golf.
Just drive it till it rolls at 300K. I am on a trip from Idaho to Indiana and I noticed that it was going to roll on by 300K, so at 299,999 I took a pic and then was awaiting the rollover. It rolled, but instead of 300,000, it went to "0"! The trip odometer kept on going normally, as I was halfway thru a tank and checked. Has anyone seen this strangeness? Does VW not expect a gasser to go more than 300K? Do the TDI odometers do the same thing or is it cause it is an early mkIII? I would think a digital odometer would have no problem counting to 999,999 or more.
bvolks Samba Member
Joined: April 26, 2004 Posts: 845 Location: New Brunswick, Canada
Posted: Tue Jun 20, 2017 7:46 am Post subject: Re: mkIII odometer reset |
Mine did the same. You know it's been rolled over because the word "Total" disappears. _________________ 1985 Diesel Jetta Coupe (temporarily retired at
756,000 km)
1971 Doublecab project
1995 Golf CL
1974 Beetle
1978 Westfalia |
ps2375 Samba Member
Posted: Tue Jun 20, 2017 8:12 am Post subject: Re: mkIII odometer reset |
bvolks wrote: |
Mine did the same. You know it's been rolled over because the word "Total" disappears. |
I wonder what they were thinking to have it "roll" at 300K, stupidly low imho. Heck, I had 500-600K on my Rabbit when it was killed.
And I don't recall the word "Total", but I also ignore and don't reset the service msg. I only use the odo for oil change interval and the trip is reset at fillups. |
crsmp5 Samba Member
ps2375 Samba Member
Posted: Wed Jun 21, 2017 7:34 am Post subject: Re: mkIII odometer reset |
I'll check that out when I get back home with the VAG-Com. Still seems weird why it just wouldn't display it. Seems they would need to add a line of code to make it roll to 0 at 300K and not just display what is in it's memory. |
