snydley100 Samba Member
Joined: February 26, 2017 Posts: 75 Location: Dansville, NY
Posted: Tue Jun 20, 2017 7:45 am Post subject: Turn signal switch - horn brass "spring" |
I'm having trouble getting my horn to work on my 1974 Ghia convertible. I took the steering wheel off to check the contact of the steering wheel horn ring and the brass spring piece that contacts the ring. Well, over the years the spring has a hole worn through it from use. Is there a replacement for this part or must I buy a whole new turn signal switch to replace this piece?
Thanks,
Snyde |
hylomatt Samba Member
Posted: Wed Jun 21, 2017 6:05 pm Post subject: Re: Turn signal switch - horn brass "spring" |
are you talking about this part? the copper-colored bent spring piece that the steering wheel's horn ring rubs around on?
trelms Samba Member
Posted: Wed Jun 21, 2017 6:52 pm Post subject: Re: Turn signal switch - horn brass "spring" |
I would not buy that 40$ one. I have and it lasted 6 months. Try to repair your original as stated make sure the turn signal cancel bits don't break and try to lube them.
Oem ones can be found for 100-200 I think.
https://www.bugcity.com/shop/shop.htm?pquery=turn+signal+switch _________________ '74 Ghia Vert SOLD |
Posted: Wed Jun 21, 2017 7:19 pm Post subject: Re: Turn signal switch - horn brass "spring" |
hylomatt wrote: |
YES! I guess I should have taken a picture of mine and uploaded it. Mine's got a hole in it. My turn signals work fine, but I'm having trouble with the horn. I want to know if just that copper/brass piece is replaceable, or if I have to buy the turn signal switch assembly in order to get it. I guess if I have to I'll also order the "ring" that it contacts, too.
Thanks,
Snyde |
Posted: Wed Jun 21, 2017 7:29 pm Post subject: Re: Turn signal switch - horn brass "spring" |
Mine's got a pretty good sized hole in it, not sure about soldering it. I thought I might try to reform mine, straightening out the part that contacts the ring, making that part longer, and making the end of it shorter to see if I can get another section of the spring part to contact the ring. Before I spend $200+ on a NOS German part I'll go to the junkyard and see if I can find a good one.
Thanks,
Snyde |
Posted: Thu Jun 22, 2017 7:16 am Post subject: Re: Turn signal switch - horn brass "spring" |
hylomatt wrote: |
Is this the $40. one, or one of the more expensive ones? How does the "quality" of the piece look?
Thanks,
Snyde |
Posted: Thu Jun 22, 2017 8:35 am Post subject: Re: Turn signal switch - horn brass "spring" |
that's just a photo that i pulled from the galleries. i would want a 1-piece unit myself. i'd try to track down a good, original. it's not that big of a deal if you order a cheaper remake. you might be replacing it again sooner than you intend though. i haven't worn one out but i recently replace the blinker column switch on my vw thing and the contacts that hang down below the column head housing are different from original. i keep having to push the connector on when my horn or blinkers don't work. it just wiggles its way off sometimes. |
swavananda Samba Member
Joined: February 14, 2009 Posts: 889 Location: Can o' Scruz
Posted: Thu Jun 22, 2017 11:03 am Post subject: Re: Turn signal switch - horn brass "spring" |
Agreed and same scenario .
But i would recommend you try to solder a piece of patch copper over the worn section before anything else. Start with the cheapest and easiest first. |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2875 Location: Auckland, New Zealand
Posted: Thu Jun 22, 2017 11:14 am Post subject: Re: Turn signal switch - horn brass "spring" |
swavananda wrote: |
My experience with this part is this: The original part would not flick from brights to dimmed lights. I replaced it with a new aftermarket part. It malfunctioned within a year. I then showed both parts to a classic VW specialist parts supplier (in Sydney, Australia) and he told me that the aftermarket part had a lifespan of about 1 year and that I was better off repairing the German VW original. I was able to do the repair myself. It took 10 minutes. 20 months later, the repaired original is still working perfectly. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
Posted: Fri Jun 23, 2017 7:52 am Post subject: Re: Turn signal switch - horn brass "spring" |
I was able to bend, and reform the copper piece so that part of it that didn't originally contact the horn steering wheel ring now makes contact and the horn works great! Someone posted a link to some flat copper and I'm gonna buy that and try to make that piece, just in case this fails.
Thanks for all the help, guys,
Snyde |
Posted: Fri Jun 23, 2017 12:46 pm Post subject: Re: Turn signal switch - horn brass "spring" |
kiwighia68 wrote: |
swavananda wrote: |
My experience with this part is this: The original part would not flick from brights to dimmed lights. I replaced it with a new aftermarket part. It malfunctioned within a year. I then showed both parts to a classic VW specialist parts supplier (in Sydney, Australia) and he told me that the aftermarket part had a lifespan of about 1 year and that I was better off repairing the German VW original. I was able to do the repair myself. It took 10 minutes. 20 months later, the repaired original is still working perfectly. |
Well, I guess I won't buy the $40. aftermarket part then, I've got other places to waste my money, (damn money pit).
What did you do to fix yours, fabricate and solder a new piece of copper to your original
copper piece, or remove the old copper, make a new piece, and rivet it to the original location?
Thanks,
Snyde |
Posted: Fri Jun 23, 2017 1:07 pm Post subject: Re: Turn signal switch - horn brass "spring" |
snydley100 wrote: |
kiwighia68 wrote: |
swavananda wrote: |
Well, I guess I won't buy the $40. aftermarket part then, I've got other places to waste my money, (damn money pit). ](*,) :shock:
Thanks,
Snyde |
Hi Snyde, No, mine had a different defect. It didn't involve working on the copper piece. I had to raise the contact point under the switch arm. By the way, I derived greater satisfaction from repairing an old part like this than from installing a new one, not to mention the dollars saving. _________________ Festina lente - hasten slowly
Posted: Fri Jun 23, 2017 6:05 pm Post subject: Re: Turn signal switch - horn brass "spring" |
kiwighia68 wrote: |
snydley100 wrote: |
kiwighia68 wrote: |
swavananda wrote: |
Thanks,
Snyde |
Hi Snyde, No, mine had a different defect. It didn't involve working on the copper piece. I had to raise the contact point under the switch arm. By the way, I derived greater satisfaction from repairing an old part like this than from installing a new one, not to mention the dollars saving. |
Yes, I can understand fixing something instead of buying new, I also feel that way. I "re-formed" the copper piece, in my switch, and so far the horn works great! I think when it eventually fails I'll buy some of that flat copper material and try to make my own. I'm just not sure how I'm gonna rivet it back on, but I'll worry about that when the time comes.
Thanks for the help and conversation,
Snyde |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3818 Location: Georgia
Posted: Sun Jul 08, 2018 7:34 pm Post subject: Re: Turn signal switch - horn brass "spring" |
Wow!
I didn’t realize that they’re that much.
I still have one in the box I got back in 96
Interestingly there are two extra wires on it.
Hope that doesn’t mean there are surprises in store. |
