Front Axle Nuts: How tight? Alternate nuts?
Wildthings
Wildthings is offline
PostPosted: Mon Aug 14, 2017 5:33 am    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
djkeev wrote:
You will need a bolt,
6mm x 1.0 x 25mm +/-
I am unclear if a washer is needed, Any Mercedes people out there?
Dave
I wouldn't think so as a washer would be just another potential point of failure, but will bow to the knowledge of a person with Mercedes experience.
dobryan
dobryan is offline
PostPosted: Mon Aug 14, 2017 6:41 am    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
Those were stock on my '71 bus. No washer and they took an allen head bolt. 6mm allen IIRC.
Dave O
The West Coast Westy
djkeev Premium Member
djkeev is offline
PostPosted: Mon Aug 14, 2017 7:07 am    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
Here ya go!
https://www.grainger.com/product/FABORY-M6-1-00-x-25mm-26LG41
The proper item but you most likely don't want 100 of them!
Dave
Ghia
Vanagon
Beetle
Jake de Villiers
Jake de Villiers is offline
PostPosted: Mon Aug 14, 2017 5:40 pm    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
Dave
I'd put a lock washer under there, for sure. Would one of the fancy ones from the half shafts fit, Dave?
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
djkeev is offline
PostPosted: Mon Aug 14, 2017 5:51 pm    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
Dave
Axle bolts are 8mm aren't they?
Schnoor safety washers are a well known brand....
http://schnorr.com/product-details/safety-washers/
You can get 6mm ribbed lock washers though....
https://www.grainger.com/product/5MXD7&AL!2966...15004759:s
Studies have shown that lock washers are for the most part "feel good" items but really don't work.
Dave
Ghia
Vanagon
Beetle
dobryan
dobryan is offline
PostPosted: Tue Aug 15, 2017 6:11 am    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
For reference try looking at the front axle parts for a '71 bus. Mine used those same axle nuts.
Dave O
djkeev is offline
PostPosted: Tue Aug 15, 2017 6:33 am    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
A few images I puledl off the interwebby thing..... pelican parts and mercedes forums.
None of them show a washer of any tyoe that I can discern.....
The item shown between the axle nut and the bearing cap I believe to be a grounding spring?
Dave
Ghia
Vanagon
Beetle
danfromsyr
danfromsyr is offline
PostPosted: Tue Aug 15, 2017 7:07 am    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
there's no need for a washer on the bolt on the pinch nut.
the spring tension of the pinch nut keeps the bolt under tension just fine for millions of cars of that era.
but if a schnoor washer makes you sleep better at night.. go for it.
Abscate wrote:
Abscate Premium Member
Abscate is offline
PostPosted: Tue Aug 15, 2017 8:00 am    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
That three eared washer looks critical to me. Without it, the clamp nut places no force on the outer bearing race.
Am I wrong on that?
.ssS!
djkeev is offline
PostPosted: Tue Aug 15, 2017 8:52 am    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
That is a mercedes illustration.
We aren't redesigning the system, simply replacing VW's one use peen in place nut with a reuseable locking nut.
Dave
Ghia
Vanagon
Beetle
Abscate is offline
PostPosted: Tue Aug 15, 2017 9:15 am    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
Enlightenment has burst upon me, Biggles.
Nice meeting you at Bug Rama, Dan!!
.ssS!
Wildthings
PostPosted: Tue Aug 15, 2017 9:25 am    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
Am I wrong on that?
You only want force to be applied to the inner race. I don't understand why the washer has its special shape.
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Tue Aug 15, 2017 9:52 am    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
djkeev,
Just got mine too, and as I had not looked at this thread for a week, I had not known that the clamp nuts would be missing the fastener bolt.
Any consensus on the bolt? Seems like a lot of back and forth on what I need to look for... I may just have to take the nuts out to Fastenal.
'87 Westy 'Flossie','83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '63 Notch
djkeev is offline
PostPosted: Tue Aug 15, 2017 10:13 am    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
6mm
1.0 thread pitch
22 or 25 mm long
cap screw head, 5mm hex for allen wrench.
Buy the hardest one they carry 8.8, 12.9 ...... stay away from stainless, it is a weak metal and this is too important of an item to risk fastener failure.
Dave
Ghia
Vanagon
Beetle
Wildthings
PostPosted: Tue Aug 15, 2017 12:05 pm    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
djkeev wrote:
6mm
1.0 thread pitch
22 or 25 mm long
Dave
On a Bay (don't have a clue about the Mercedes) the clamping bolts were socket head cap screws.
Abscate is offline
PostPosted: Tue Aug 15, 2017 1:09 pm    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
Wildthings wrote:
Am I wrong on that?
Yeah, but you need to apply force to both cones of the needle bearing on that Merc design. The actual outer race isn't getting force.
I don't get the shape either. It could just be a thrust washer
.ssS!
djkeev is offline
PostPosted: Wed Aug 16, 2017 4:27 am    Post subject: Re: Front Axle Nuts: how tight do you tighten them? Reply with quote
Mercedes nuts with 6 x 1.0 x 25 mm hex head socket cap screw head.
Takes a 5mm / H5 Allen wrench
Dave
Ghia
Vanagon
Beetle
dobryan
dobryan is offline
PostPosted: Tue Jun 05, 2018 8:41 am    Post subject: Re: Front Axle Nuts: How tight? Alternate nuts? Reply with quote
Here is the bus version.
https://www.ebay.com/i/252592358947?chn=ps
Dave O
shagginwagon83
shagginwagon83 is offline
PostPosted: Tue Jun 05, 2018 9:02 am    Post subject: Re: Front Axle Nuts: How tight? Alternate nuts? Reply with quote
there are different ones for each side? i used mercedes style both same
Brandon
"Jo Ann" - 1983.5 Ivory Westfalia 1.9L 2wd
djkeev is offline
PostPosted: Tue Jun 05, 2018 4:32 pm    Post subject: Re: Front Axle Nuts: How tight? Alternate nuts? Reply with quote
Not sure of the year or model breaks but left handed threads were used so that any "loose" nuts tightened themselves instead of spinning off.
Dave
Ghia
Vanagon
Beetle
Page 3 of 5
