dunebuggy1234 Samba Member
Joined: May 06, 2017 Posts: 72 Location: Indiana (IN)
Posted: Wed Jun 21, 2017 12:18 pm Post subject: Leaking oil around my tire |
I was just driving my dune buggy around the other day when I noticed that oil had completely coated the inside of my tire. i believe the frame was off of a 1986, but I am not 100% sure on that. I was hoping one of you guys had any information on what could be leaking. there does not seem to be anything dripping on the wheel either. so I looks like the leak has to be coming from the wheel. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Wed Jun 21, 2017 12:45 pm Post subject: Re: Leaking oil around my tire |
If it's an '86 then it's presumably a Mexican Beetle, yes? If so it has swing-axle rear suspension, yes?
Then likely suspect would be rear axle oil seal - search the '67 and earlier forum for details. Fun job! _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Wed Jun 21, 2017 1:59 pm Post subject: Re: Leaking oil around my tire |
so I would essentially need to take apart the hub? |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6593 Location: Houston, Texas
Posted: Wed Jun 21, 2017 9:43 pm Post subject: Re: Leaking oil around my tire |
How's the brake fluid level? |
Braes Samba Member
Posted: Thu Jun 22, 2017 2:07 am Post subject: Re: Leaking oil around my tire |
sjbartnik wrote: |
Then likely suspect would be rear axle oil seal - search the '67 and earlier forum for details. Fun job! |
+1 ! When I changed mine I had to redo 1 side a week later because it was still leaking.. The whole inside of the rim was covered in oil. |
Tom K. Samba Member
Joined: March 10, 2005 Posts: 1603 Location: Central Pennsylvania
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Thu Jun 22, 2017 8:52 am Post subject: Re: Leaking oil around my tire |
Hi. Seems you may have a swing axle trans and the trans' gear oil is getting past the seal there.
Does the oil have a Sulphur smell? That would indicate gear oil.
Is the rear axle nut tight. Tight means 200+ ft/lbs.
Hope this helps, Bill. |
Posted: Thu Jun 22, 2017 9:52 am Post subject: Re: Leaking oil around my tire |
kawfee wrote: |
the brake fluid level does look a little bit low. I am going to top it off and the gear box oil today and see what happens |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Thu Jun 22, 2017 10:23 am Post subject: Re: Leaking oil around my tire |
dunebuggy1234 wrote: |
kawfee wrote: |
Can you tell the difference between brake fluid and gear lube? The differences are very noticeable. |
Posted: Thu Jun 22, 2017 11:51 am Post subject: Re: Leaking oil around my tire |
I am honestly not to sure on how to tell the difference. this oil is black and seems to be very thin. I have not really messed with gear lube before. but It does feel a bit different than brake fluid. this could be because it is sitting on a dirty wheel though. if it is brake fluid, what could the problem be? there is no leaking around the brake line either. so i know it is something completely in the wheel |
Randy in Maine Samba Member
Posted: Thu Jun 22, 2017 12:46 pm Post subject: Re: Leaking oil around my tire |
If it is brake fluid you have a leaking wheel cylinder or caliper or flex hose. If it is gear oil (and smells sulfury) it is likely leaking from the swing axle or transaxle.
If you were to lay under the car and have your lovely assistant pump the brake pedal it might be obvious.
Really you should check both.
I have found that having one of these is nice to have in the tool box....a 17mm socket to check the transaxle level.
http://vwparts.aircooled.net/17mm-Trans-Axle-Drain-Plug-and-IRS-Diagonal-Tool-p/7029.htm |
David_nc_72std Samba Member
Joined: August 22, 2015 Posts: 841 Location: Winston-Salem, NC
Posted: Thu Jun 22, 2017 3:03 pm Post subject: Re: Leaking oil around my tire |
The only other source of oil in that area that I can think of would be the shock absorber, but that would be very, very unlikely. |
Posted: Thu Jun 22, 2017 3:22 pm Post subject: Re: Leaking oil around my tire |
Gear oil has a very unique smell. Stinks to high heaven _________________ 1965 Volkswagen 1500 Variant S
Posted: Thu Jun 22, 2017 5:05 pm Post subject: Re: Leaking oil around my tire |
sjbartnik wrote: |
Gear oil has a very unique smell. Stinks to high heaven |
okay. so it does not seem like it is gear oil, which seems like a relief. I took out the filler bolt to check the oil level, and it spewed out like a milky brownish fluid. is that normal? and I can tell the difference in smells now. it seems like brake fluid leaking out. i topped the fluid res off, and marked it so I will see if i can catch it going down. |
ps2375 Samba Member
Posted: Thu Jun 22, 2017 5:15 pm Post subject: Re: Leaking oil around my tire |
How easy is it to pull a drum? (I don't know cause my car has typeII or III drums and they are easy to pull). Pull a drum and take a look. |
Posted: Thu Jun 22, 2017 5:17 pm Post subject: Re: Leaking oil around my tire |
ps2375 wrote: |
I will probably pull the tire and drum off tomorrow and drain and refill my tranny. I just didnt want to start taking things apart when I wasnt sure what I was even looking for. |
