Destr0 Samba Member
Posted: Wed Jun 21, 2017 1:22 pm Post subject: Wiring harness for rail - which to get? |
Have a bare frame rail and a stock 71 type 1 engine/transaxle - nothing else on my rail but a gas tank.
I need a wiring harness - what is a good one? There is a cheap buggy harness on Amazon that gets good reviews. Still need to figure out what and how to wire dash - I will need all new as this was an off road only buggy and I want to make it street legal (but still off road toy). |
cbeck Samba Member
Posted: Wed Jun 21, 2017 4:28 pm Post subject: Re: Wiring harness for rail - which to get? |
I rolled my own. Every rail is just a little different. Maybe get a basic harness and add/modify as needed? |
Q13931152 Samba Member
Posted: Wed Jun 21, 2017 6:30 pm Post subject: Re: Wiring harness for rail - which to get? |
X2
If you're a little unsure how to start, I'd recomend you beg borrow or buy a copy of the earl duty book " how to build a dune buggy"... Amazon or Barnes and noble usually has or can get it for you . The three page wiring diagram in there is about the simplest and easiest one I've ever seen to wire up a buggy from scratch. I used it as a guide when i wired mine about 20 or so years ago, and modified it slightly for my needs. After all these years its still as good as the day i made it. _________________ Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed Jun 21, 2017 7:24 pm Post subject: Re: Wiring harness for rail - which to get? |
IF your are going for street legal... You probably will need full lighting including turn signals.... At that point easiest would be something like Rebel wiring harness where everything is already provided and all the wires have designations printed on them and comes with generic diagrams that are enough to get you setup and working with your particular...
The Rebel Wire - V W Rail Buggy kit may do trick for you if not step up to next one, Rebel Wire VW Bug Universal Harness -12 Volt...
http://rebelwire.com/rebel-wire-products.php?cat=Wire%20Kits
IF you have experience wiring sure roll your own...Just keep in mind after you buy all the wire (8-10 different colors or sizes and terminals) all the switches and fuse blocks and such, you could have had it all in kit....
Might want to do a little looking here...
https://www.thesamba.com/vw/forum/viewtopic.php?t=344781
Sure threads are old, and some links no longer valid, but concepts do not change with time, only switching for incandescent lamps to LEDS is about all...
gunslingertom Samba Member
Joined: May 21, 2017 Posts: 67 Location: Beautiful S.W. Missouri Ozarks
jimmyhoffa Samba Member
Joined: February 16, 2014 Posts: 1057 Location: St. Louis
Posted: Thu Jun 22, 2017 4:55 am Post subject: Re: Wiring harness for rail - which to get? |
+1 for rebel wire, the wire itself is also particularly high quality and labeled well. _________________ 1974 Chenowth 2RL #1244 Street Legal
My other car isn't ridiculous. |
Destr0 Samba Member
Posted: Thu Jun 22, 2017 7:17 am Post subject: Re: Wiring harness for rail - which to get? |
Thanks for the info guys! I have done some wiring in the past but only using a "stock" replacement harness. Figured anything "stock" wasn't going to work so well - and by the time I get all the colors needed to not go crazy down the road it would cost as much or more than buying one "off the shelf"- now I know I will probably have to modify anything I get, just looking for a good starting point. |
Fenix Samba Member
Joined: October 05, 2016 Posts: 468 Location: St Louis
Posted: Thu Jun 22, 2017 8:18 am Post subject: Re: Wiring harness for rail - which to get? |
Destr0 wrote: |
In the past I have always started with Rebels, but as simple as the rails, if you know wiring and how to use standard and switching relays you could probably get away with the Empi buggy kit, then add the fuse bock, relays, and flashers you want. That's essentially what I am doing, I just needed the wires and it was cheaper to get the wires like that. Unless you have an electronics or ham radio store that still sells all the colors of wire you need/want by the foot.
For flashers and hazards...don't forget there are DTDP flasher relays (EP27L) that allow you to use the same relay for flashers with keyed power and Hazards with a single relay and one 3-way toggle switch and a 2-way switch or latching push button.
Basic wireing from one of the Rod building resources I've used.
Headlights can be a switching relay with an (on-off) toggle and latching momentary push button or (off-on-on)toggle switch and momentary latching push button (if driving lights are required). Or if you have a foot switch laying around from the jeep.
So no expensive headlight pull switch, or universal flasher assembly unless you want to.
Destr0 Samba Member
Posted: Thu Jun 22, 2017 8:23 am Post subject: Re: Wiring harness for rail - which to get? |
I was actually thinking I may try the EMPI kit - in my box of spare Jeep parts I have a 7 blade fuse box that I never used (new). I also have a bunch of new relays and such - I am planning on adding a 2 ton winch to the front of the rail - Midwest wheeling has lots of mud. |
pullstart Samba Member
Joined: August 23, 2016 Posts: 599 Location: Middleville, MI
Posted: Thu Jun 22, 2017 8:58 am Post subject: Re: Wiring harness for rail - which to get? |
Fenix wrote: |
Destr0 wrote: |
So no expensive headlight pull switch, or universal flasher assembly unless you want to. |
wow, just stuck this thread in my favorites because of those diagrams! that's like gold as far as a reference goes. _________________ 4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
my build page: https://www.thesamba.com/vw/forum/viewtopic.php?t=662104&start=0 |
Third Samba Member
Joined: June 13, 2017 Posts: 116 Location: Texas Coast
Posted: Thu Jun 22, 2017 9:23 am Post subject: Re: Wiring harness for rail - which to get? |
Destr0 wrote: |
I did that on several Chenowths that I restored to flip back in the early 90's.
Really my only requirement for a harness is to avoid the old plastic bug fuse blocks (learned in the early years that off road, even just cruising sand you'll pop the damned things loose at the most inconvenient time).
mac2881994 Samba Member
Joined: February 03, 2011 Posts: 17 Location: Woodlawn, TN
Posted: Fri Jun 23, 2017 7:29 am Post subject: Re: Wiring harness for rail - which to get? |
I used the EMPI harness a couple of years ago to rewire a buddy rail. Only headlights and essential circuits to make it run. Decent quality and much better than the three wire extension cord that was originally used to wire it. |
Goshen Samba Member
Joined: April 03, 2012 Posts: 833 Location: Miami. FL & Cartagena
