myghiarocks Samba Member
Joined: June 02, 2009 Posts: 143 Location: DFW area Texas
Posted: Wed Jun 21, 2017 1:58 pm Post subject: 74 standard engine just quits after running for 5 minutes |
I have a 74 standard with a dual port 1600 engine..
For the last week the engine has started stalling after running perfect for 5 or 10 minutes. This happens while driving or idling.
I have tried 2 different carbs with same result, both carbs are good.
Tried removing plunger from fuel shut of solenoid. same result. no vacuum leaks.
009 dist with new points that work fine. Watched coil with test light during a stall out with no loss of power.
Fuel pump and filter are good.
Very strange problem. Almost seems like ignition is shutting off.
On a modern car or electronic ignition I would suspect a bad module.
Any Ideas? |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4421 Location: Stuck in Ohio
Posted: Wed Jun 21, 2017 2:05 pm Post subject: Re: 74 standard engine just quits after running for 5 minutes |
Obviously you were chasing the float issue first, which is what the title would suggest is the problem, but is apparently not the problem.
I had a 70s Honda Civic once that did this and it turned out to be a tiny crack in the distributor cap. Moisture would develop in there when it warmed up and it would quit running. I never did see any droplets or anything but I changed the cap and the problem stopped.
That's all I've got. What a PITA. Good luck!!!
EDIT - what a bout a clogged vent in the gas cap that doesn't allow air to enter the tank as gas is being pulled out? _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
vwjetboat Samba Member
Posted: Wed Jun 21, 2017 2:08 pm Post subject: Re: 74 standard engine just quits after running for 5 minutes |
is there a fuel filter up front under the tank.. sounds like fuel pump ... how did you test pump ? how many psi ? |
Posted: Wed Jun 21, 2017 2:09 pm Post subject: Re: 74 standard engine just quits after running for 5 minutes |
and have you changed condenser ? |
wcfvw69 Samba Purist
Posted: Wed Jun 21, 2017 2:34 pm Post subject: Re: 74 standard engine just quits after running for 5 minutes |
*Check fuel filter/filters and possible debris in fuel tank.
*What fuel pump and what PSI is it putting out?
*Condensers love to fail like this as do coils.
*Cap/rotor. Check them closely.
*Any loose power wires to the coil or at the coil? _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Jun 21, 2017 2:38 pm Post subject: Re: 74 standard engine just quits after running for 5 minutes |
thanks bugee, tried removing gas cap and running engine, same result.
Vwjetboat, there is no filter up front. maybe the filter in the tank is bad.
I have not changed the condenser.
fuel is visually running through the filter and into the carb right up to stall condition.
Fuel filter remains 1/3 full under running conditions and during stall. |
Posted: Wed Jun 21, 2017 2:42 pm Post subject: Re: 74 standard engine just quits after running for 5 minutes |
id change the condenser then.. I have seen them do exactly what you describe and its cheap so not like ya dishing out a lot of money to parts change to solve issue.. |
Posted: Wed Jun 21, 2017 2:53 pm Post subject: Re: 74 standard engine just quits after running for 5 minutes |
Thanks guys
Will change coil and condenser tomorrow. hoping for luck and results.
This has become frustrating. |
Posted: Wed Jun 21, 2017 2:55 pm Post subject: Re: 74 standard engine just quits after running for 5 minutes |
id do condenser first.. don't change more then 1 part at a time.. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Wed Jun 21, 2017 3:59 pm Post subject: Re: 74 standard engine just quits after running for 5 minutes |
My money is on the condenser or the rotor. Some times the rotor burns through and grounds on the drive shaft instead of at the plugs! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Jun 22, 2017 8:02 am Post subject: Re: 74 standard engine just quits after running for 5 minutes |
When it stalls next, spray some aerosol starter fluid into the air cleaner, see if it starts up. I'm wondering if this is one of those situations when the fuel pump intermediate flange heats up and grabs the fuel pump pushrod.
Also, if spark related, one of those inexpensive spark tester things that visually show spark might help.
First thing is to positively identify whether the issue is fuel-related or sparking-related, like for ANY troubleshooting like this. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Thu Jun 22, 2017 8:45 am Post subject: Re: 74 standard engine just quits after running for 5 minutes |
Hi. As Mr Cusser stated you need to be up on some basic diagnostic skills here. Here are a few basic tests one could use but would need to do them immediately when this occurs.
1- Remove air filter and peer into the carb air-horn to verify it isn't flooding over.
2- If not, then with a test light attached to coil term 1, key on, car in neutral, hand crank engine over and verify test light goes off-on during turning engine over.
3- If ok, I'd remove carb top and see if float bowl is full or empty.
Over the last few years I have seen parts failures at an alarming rate. Condenser's, points, floats, etc.
Also verify your gas tank is vented properly. I have seen a gas tank begin to suck itself inwards from this.
Hope this helps, Bill. |
Posted: Thu Jun 22, 2017 11:16 am Post subject: Re: 74 standard engine just quits after running for 5 minutes |
Hi guys
Changed the condenser and I think it has solved the problem.
After 30 minutes still running fine. will close the book on this one after a few more run cycles.
It would be my first condenser failure in many years of wrenching. Both domestic and foreign makes. Always time for a first. last thing to check as usual.
Thanks for the help |
andrewwebb58 Samba Member
Posted: Thu Jun 22, 2017 11:21 am Post subject: Re: 74 standard engine just quits after running for 5 minutes |
glad you were able to figure it out. Thanks for reporting back! _________________ 1974 Super beetle Lime Green 1600 DP (originally my Grandpa's before he passed)
1995 GMC 1500 4x4
2015 Silverado 4x4 |
Posted: Fri Jun 23, 2017 5:04 am Post subject: Re: 74 standard engine just quits after running for 5 minutes |
myghiarocks wrote: |
Hi guys
Glad to hear..
I have seen I think 2... 3 now with yours.. kinda how i knew what it was.. if you never experienced it. you would never think of it.. I just got lucky because I have had it happen. so glad ya got fixed.. |
