64delux Samba Member
Joined: November 15, 2007 Posts: 138 Location: Australia
Posted: Fri Jun 23, 2017 4:48 am Post subject: Gearbox nose cone sealant? |
gasket shot what sealant for nose cone on gearbox do i use instead? |
kooper271 Samba Member
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Fri Jun 23, 2017 9:46 am Post subject: Re: Gearbox nose cone sealant? |
When I did the nose cone on my 1977 manual transmission, I patterned out a new gasket from thin roll material from my FLAPS. I sealed that with Gaskacinch. It's similar to rubber cement in appearance and smell. Comes in a small metal can. |
THall Samba Member
Joined: August 25, 2010 Posts: 324 Location: Verona, WI
Posted: Fri Jun 23, 2017 10:10 am Post subject: Re: Gearbox nose cone sealant? |
When I installed the retainer plate on my 091 I asked Rick Long his opinion and he recommended using the Permatex Ultra Blue. _________________ '78 Westy - 2.0 FI |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri Jun 23, 2017 10:29 am Post subject: Re: Gearbox nose cone sealant? |
My suggestion would be Permatex Anaerobic Gasket Maker, 50 ml Tube
https://www.amazon.com/Permatex-51813-6PK-Anaerobi...sket+maker _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Fri Jun 23, 2017 12:35 pm Post subject: Re: Gearbox nose cone sealant? |
Hylomar blue. I find that this does the trick with or without gasket. but like any mating surface it has to be flat and clean clean clean!
I was turned on to this stuff by a coworker that once worked as a Rolls Royce tech. As well as another coworker that is our departments machinist.
http://hylomar.com/hylomar-product-range/gasket-jointing-compounds/#universalblue
Also packaged and sold by Permatex. It might be easier to find this version of the compound.
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Fri Jun 23, 2017 2:51 pm Post subject: Re: Gearbox nose cone sealant? |
Silicones...in general...can have numerous issues with gear oils. Depending on how they are catalyzed for cure....the sulfur in gear oil messes them up.
If you are just treating the gasket surface to make it more pliable for sealing...and letting it dry before installing and exposing it to gear oil...its not an issue.
Permatex 81182 is made just for gear oil use and work VERY well.
https://shop.advanceautoparts.com/p/permatex-gear-...lsrc=aw.ds
Ray |
