pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Fri Jun 23, 2017 6:33 am Post subject: Help!!! |
My newest vehicle is a 1970 Bug. Yesterday I went to open the glove box to retrieve the garage door opener and the knob came right off the lid!!!
How the hell do I get this thing open now without mangling something??!!??
_________________ Some people are so busy being clever they don't have time enough to be wise. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Fri Jun 23, 2017 6:42 am Post subject: Re: Help!!! |
You may be able to slip a card in between the top of the glove box lid and the dash, maneuver it over the latch and get the spring-loaded latch bit to push down. Probably need something stiff but more flexible than a credit card. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
71superAS Samba Member
Joined: February 02, 2012 Posts: 223 Location: New York
Posted: Fri Jun 23, 2017 6:48 am Post subject: Re: Help!!! |
Use a feeler gauge - you can press the spring latch down as mentioned
Source: I've had to do this before _________________ Ahoy! |
beetlenut Samba Member
Or grab onto that slotted tab inside the remaining latch with some needle-nose pliers and turn the latch to open. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
pyrOman Fire Master
Posted: Fri Jun 23, 2017 6:52 am Post subject: Re: Help!!! |
beetlenut wrote: |
Or grab onto that slotted tab inside the remaining latch with some needle-nose pliers and turn the latch to open. |
It might be broken in there. The pix may not show it well but I cannot see anything I can grab to make it open.
Is there an "exploded view" of the mechanism?
I've also heard before that the way to get to the trunk when the cable breaks is to cut the handle, but I don't want to do that if at all I can help it. _________________ Some people are so busy being clever they don't have time enough to be wise. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Fri Jun 23, 2017 7:29 am Post subject: Re: Help!!! |
Yes, you can cut the handle. You will need to cut out the middle section, like 2 inches of it. You are then left with 2 "L" sections. You can turn these CCW to unscrew them from the bolt on the underside. Not fun to do, since the bolt becomes a free agent after the tension is gone against the hood, so you need to supply tension until it is completely removed from the hood.
Then the hood will open.
Be careful, it is really easy to scratch the paint.
Or, it may be easier to cut away the lip and open the door. Like this. Just deep enough to break away little segments of material.
_________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Fri Jun 23, 2017 7:35 am Post subject: Re: Help!!! |
71superAS wrote: |
Source: I've had to do this before |
Feeler gauge! Great idea! _________________ 1965 Volkswagen 1500 Variant S
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
pyrOman Fire Master
Posted: Fri Jun 23, 2017 7:56 am Post subject: Re: Help!!! |
Well thanks a million for that. Sure does help in making me feel so much better!
Thanks for playing too! _________________ Some people are so busy being clever they don't have time enough to be wise. |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Fri Jun 23, 2017 8:06 am Post subject: Re: Help!!! |
I'd like to be the first one to say-------------
HIT IT WITH AN AX. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri Jun 23, 2017 8:08 am Post subject: Re: Help!!! |
should be able to turn whats left with a large screwdriver?
And when you replace it, source a NOS or good used one, aftermarket are junk and prone to break like what you have now. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
pyrOman Fire Master
Posted: Fri Jun 23, 2017 8:18 am Post subject: Re: Help!!! |
iowegian wrote: |
Now ^^THAT^^ really triggered my fillings!!!
But since there isn't a "safe place" around, I'll just suck it up, buttercup! _________________ Some people are so busy being clever they don't have time enough to be wise. |
slayer56 Samba Member
Posted: Fri Jun 23, 2017 10:52 am Post subject: Re: Help!!! |
So I guess the bug is now out of service??
After all how can you drive it with a broken glove box knob!! |
Cusser Samba Member
Posted: Fri Jun 23, 2017 11:43 am Post subject: Re: Help!!! |
Cusser wrote: |
I'd help you but refuse to on the grounds that your topic title of "Help" is so dumb and non-descriptive. |
With your number of posts, you should know better. A good descriptive title helps folks with searching too. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
sb001 Samba Member
Posted: Fri Jun 23, 2017 12:53 pm Post subject: Re: Help!!! |
Cusser wrote: |
I suppose that's as good a reason as any not to help someone.. |
pyrOman Fire Master
Posted: Fri Jun 23, 2017 1:46 pm Post subject: Re: Help!!! |
Cusser wrote: |
Cusser wrote: |
With your number of posts, you should know better. A good descriptive title helps folks with searching too. |
It DID get your attention!
Fool quoted himself too!
Figured someone else might have had the same situation and could answer with what he/she done. The multi-slice will prolly be what I do. Thanks Jimbo!
pyrOman Fire Master
Posted: Fri Jun 23, 2017 1:49 pm Post subject: Re: Help!!! |
And if all else fails, I do have an axe!!!! _________________ Some people are so busy being clever they don't have time enough to be wise. |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Fri Jun 23, 2017 2:20 pm Post subject: Re: Help!!! |
drill through it. better than slicing it risking to damage the glove box door and the lock is busted anyway, so if it doesn't work (it should) you can always use that axe. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
David_nc_72std Samba Member
Joined: August 22, 2015 Posts: 841 Location: Winston-Salem, NC
Posted: Fri Jun 23, 2017 2:54 pm Post subject: Re: Help!!! |
Drill into the center, and if the drill bit doesn't turn the correct way to retract the latch, use an easy-out (or even a sharp pointed screw) to turn it the other way. |
Cusser Samba Member
