slopo Samba Member
Joined: July 22, 2016 Posts: 64 Location: Lawrence,KS
Posted: Fri Jun 23, 2017 9:54 am Post subject: sweet mod or...not? Generator stand |
So, going through more parts from rebuilt motor purchase and found this gem. Seems to have a crimped piece there..not sure whats going on with that. Is this something those "trike" engine build guys do?
slopo Samba Member
Posted: Fri Jun 23, 2017 9:55 am Post subject: Re: sweet mod or...not? Generator stand |
drain for the crankcase breather? |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Fri Jun 23, 2017 10:16 am Post subject: Re: sweet mod or...not? Generator stand |
That "modification" was to the road draft tube. Kinda important for engines to vent via old school technology prior to closed up crankcases.
You can google road draft tube and see. Our later ('74 and newer) didn't have this feature.
Hope this helps, Bill. |
mark tucker Samba Member
Posted: Fri Jun 23, 2017 10:54 am Post subject: Re: sweet mod or...not? Generator stand |
and stay away from ones that have been blasted clean as the abrasive meida used cant be cleaned out but will fins it's way into your oil system where it will set up a restaurant and eat everything it possiably can. |
slopo Samba Member
Posted: Fri Jun 23, 2017 11:20 am Post subject: Re: sweet mod or...not? Generator stand |
So should I replace it or is it okay to run it like it is? I cant seem to find a replacement for the missing part. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Fri Jun 23, 2017 11:41 am Post subject: Re: sweet mod or...not? Generator stand |
Cut off the crimped part, add on a rubber or metal tube, and use the "duckbill" seal that earlier engines use. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Fri Jun 23, 2017 12:10 pm Post subject: Re: sweet mod or...not? Generator stand |
Shouldnt he be able to connect the top nipple to the air filter and call it good? _________________ "Albatross"! |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Fri Jun 23, 2017 12:29 pm Post subject: Re: sweet mod or...not? Generator stand |
If the crimped tube isn't leaking, I'd just leave it as is. But, the 1974 and later, stock rubber breather tube (the elbow), requires that the breather tube (the open metal tube on top of the oil filler) be turned upward at a particular angle, that is if you want to use the stock elbow on a paper-element stock air cleaner. Otherwise, you can leave it as is and use a length of hose.
Mark made a good point about abrasives getting into the interior of the oil filler. It might be a good idea to get some brake cleaner and squirt a bunch into the baffled area on the interior of the oil filler and see if anything comes out of the top breather tube when you turn it upside down to drain. If nothing appears except a few dried oil flakes, I'd use it.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
slopo Samba Member
Posted: Fri Jun 23, 2017 12:48 pm Post subject: Re: sweet mod or...not? Generator stand |
Thanks friends |
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Fri Jun 23, 2017 9:58 pm Post subject: Re: sweet mod or...not? Generator stand |
mark tucker wrote: |
agreed. May be ok, might not, but just the sight of it is slightly terrifying, to me. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Fri Jun 23, 2017 10:52 pm Post subject: Re: sweet mod or...not? Generator stand |
notes:
It stopped being a road "draft" tube during model year 1961. That was the first emissions modification that VW did, eliminating "open air venting" of the crankcase! They totally closed the bugger off for a couple of years, no "down pipe" at all. Of course, this led to a buildup of water condensation in the crankcase and that moisture has many times cause the oil filler to rust out...
When VW brought back the "down pipe" early in model year 1964 it was absolutely not for "draft tube" effect, it was ONLY to let moisture out, they still intended for crankcase fumes to be sucked back into the air cleaner and burned off by the engine.
ANYWAY, I mention this merely to say that many of those mid 61-to-early 64 oil fillers, as similar ones they used in model year 1974, were prone to rusting out. So with that pinched off, keep that in mind. It kind of sucks when the resulting rust hole forms/opens up in the middle of a road trip, like it did for me in my 62 many many years ago:
_________________ Andy T.
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4419 Location: Stuck in Ohio
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Sat Jun 24, 2017 5:21 am Post subject: Re: sweet mod or...not? Generator stand |
modok wrote: |
+2 _________________ Glenn
Member #1009
#BlueSquare |
slopo Samba Member
Posted: Sat Jun 24, 2017 8:02 am Post subject: Re: sweet mod or...not? Generator stand |
Awesome, thanks. I think Im going to throw a different one on. |
Posted: Sat Jun 24, 2017 11:39 am Post subject: Re: sweet mod or...not? Generator stand |
they make a pretty aluminum one to go on there too, one angled and one straight.the angled is eazer to pour the oil in to. about $24. the straight is about $10.+ you need a aluminum cap the plastic ones are shite.. I do have one of those that you have around hear somewhere all painted, it was cleaned in a boiling tank the proper way. remember anything that go's in that, or is in that or can get in that... will make it's way to your oil, oil pump, bearings. roadside rest. |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Sat Jun 24, 2017 2:11 pm Post subject: Re: sweet mod or...not? Generator stand |
This is the best generator / alternator stand mod that you can do.
You slot out the mounting holes in the front of the stand. Then you double nut the rear studs and pull them out of the case. So when the stand is installed, it is held in place by the two stock case studs. However, you use bolts to secure the rear of the stand.
In a perfect world this mod means nothing. However, if a generator or alternator goes bad, it is a major time/ headache saver. No dropping the engine, removing the deck lid, undoing the thermostat mechanism, or the dreaded 36mm socket in the back.
Just loosen up the fan shroud, Remove the 4 backing bolts, take off the strap, remove the two rear bolts and loosen the front nuts, and the stand is out. Then just some wiggling, and the gen / alt assembly complete with fan is out.
I do this mod on all engine that I build, on and off road. Never had a stand break or even leak. For about 15 minutes of time with a hack saw and file, this is one of the best mods you can do. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
