wild.stuff Samba Member
Joined: August 25, 2006 Posts: 5 Location: Normandie. FRANCE
Posted: Fri Jun 23, 2017 10:34 am Post subject: 1967 beetle brake fluid line? |
Hi
I look for a photo of an original Brake Fuide line From reservoir to Dual Master Cylindrer; Brake hose and metal lines.
It ' s for put it the right way on resto 67' with dual circuit brakes.
From the top with Gas tank of will be great.
Cheers.
Eric |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Fri Jun 23, 2017 11:52 am Post subject: Re: 1967 beetle brake fuide line? |
wild.stuff wrote: |
Hi
Cheers.
Eric |
The metal lines or the rubber ones? I need to remove my fuel tank and can take a couple of pics of what your looking for if you let me know what that is. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Fri Jun 23, 2017 4:30 pm Post subject: Re: 1967 beetle brake fuide line? |
67rustavenger wrote: |
The metal lines or the rubber ones? I need to remove my fuel tank and can take a couple of pics of what your looking for if you let me know what that is. |
If you may all the metal and rubber form the reservoir to MC. As you say you will have to move the fuel tank ! Is you 67' stock? Would like to see the proper
Volkswagen mounting.
Thanks.
Eric |
Posted: Fri Jun 23, 2017 7:30 pm Post subject: Re: 1967 beetle brake fluid line? |
The clamps are not required, But otherwise this is the stock installation.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
j.goodspeed Samba Member
Posted: Sat Jun 24, 2017 9:12 am Post subject: Re: 1967 beetle brake fluid line? |
In the old parts micro film, it showed a rubber hose that exited the fluid reservoir lines that are 6mm in diameter and transitioned to 8mm at the other end. It had a widening about half way. This allowed the 8mm metal lines to connect to the rubber hose that enters the dual circuit master cylinder. These hoses were not available by VW since the late 70's. I researched and used a special rubber that is impervious to brake fluid and is flexible enough to span the additional 2mm diameter.
Here is a photo of the special hose. (not my photo)
_________________ Jeremy Goodspeed
www.goodspeedmotoring.com
www.goodspeedmotoring.net |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sat Jun 24, 2017 9:31 am Post subject: Re: 1967 beetle brake fluid line? |
Just last fall I replaced the four blue brake hoses on my 1970 with new blue braided brake hose. This took just one size of braided brake hose.
Why four instead of two? There's a metal line in the middle for each feed circuit to the master cylinder. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Sat Jun 24, 2017 10:35 am Post subject: Re: 1967 beetle brake fluid line? |
Jeremy, Does that car actually get driven onto the trailer? Or do you push it on?
My embarrassingly dirty front end is on a daily driver.
Nice work on your chassis. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Sat Jun 24, 2017 10:41 am Post subject: Re: 1967 beetle brake fluid line? |
Nice work on your chassis. |
Thanks! However the sad part, was that I was able to take the photo today because I haven't put the fuel tank in yet. It's a long tern project that keeps getting bumped for more pressing projects. Nonetheless, It will get finished and driven at some point. _________________ Jeremy Goodspeed
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Sat Jun 24, 2017 12:24 pm Post subject: Re: 1967 beetle brake fluid line? |
And can you share where you obtained the correct spec hose?
Thanks, Bill. |
Posted: Sat Jun 24, 2017 1:30 pm Post subject: Re: 1967 beetle brake fluid line? |
rockerarm wrote: |
Thanks, Bill. |
This fairly unknown company carries the blue hose for 67 and later beetles.
http://vwparts.aircooled.net/7mm-Brake-Fluid-Supply-Hose-7-X-3mm-N203501-p/n203501.htm
Buy Once, Cry Once!
Posted: Sat Jun 24, 2017 1:36 pm Post subject: Re: 1967 beetle brake fluid line? |
I know off this oem spec hose. Have used it or the last 30+ years.
Jeremy mentioned something, possibly, not in the normal oem VW spec line of hosing.
I live in an area where many European parts suppliers exist as well as hydraulic hose builders, aerospace spec, and Parker hose supplier.
Bill. |
Posted: Sat Jun 24, 2017 1:52 pm Post subject: Re: 1967 beetle brake fluid line? |
Many thanks at both it'is just for what I hoped!
Eric |
Posted: Sun Jun 25, 2017 6:27 pm Post subject: Re: 1967 beetle brake fluid line? |
I had to do some checking into what I used for my non-pressured brake lines. I believe EPDM rubber. I special ordered some from a rubber and seal speciality business, but it was years ago.
However I did find this link, and the 6mm ID should work fine and stretch to accept the 8mm tube. The tubing is not reinforced, so the 2mm stretch should be achieved.
http://www.ebay.com/itm/REMOTE-BRAKE-FLUID-RESERVO...mp;vxp=mtr _________________ Jeremy Goodspeed
Posted: Sun Jun 25, 2017 6:38 pm Post subject: Re: 1967 beetle brake fluid line? |
Thank you Jeremy. |
Slow 1200 Samba Member
Posted: Mon Jun 26, 2017 2:58 am Post subject: Re: 1967 beetle brake fluid line? |
my understanding is that at some point during the 67 model year they switched to 8mm metal lines while keeping the small line reservoir, I have a NOS pair of those unobtanium 6mm-on-one-end-8mm-on-the-other blue hoses if anyone needs them
(had them for my 67 but in the end it turns out my car (december 66) was still small diameter lines all around) |
