shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Fri Jun 23, 2017 8:11 pm Post subject: How bad does my heater core look |
Long story short, my grandma is awesome. Gave me her 83 westy with 114k miles right after getting a 4.5k paint job. She is funding the 'essential' parts to restore it.
Anyhow here she goes:
Replacing blower motor(never worked for me>
Windshield wiper motor
Both windshield wiper shafts
Jeep resistor with 4 speed switch
Some sound deadner
But not the heater core! I know the haters are going to come out, but an oem one from van cafe is $150. I really don't want to put any unnecessary costs on my grandma. I have one more semester of college and I'll be graduating and getting my bachelor's in Computer Science. A year from now I hope to replace the heater core along with brake booster and slaves.
Anyhow, how bad does this look? I don't even know if it works. Is there a way to test it?
Last edited by shagginwagon83 on Fri Jun 23, 2017 8:29 pm; edited 2 times in total |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Fri Jun 23, 2017 8:20 pm Post subject: Re: How bad does my heater core look |
Hey, you've got an awesome Grandma. Very cool.
The only thing I think that matters is, Was it leaking? _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Fri Jun 23, 2017 8:24 pm Post subject: Re: How bad does my heater core look |
levi wrote: |
The only thing I think that matters is, Was it leaking? |
Thanks! But no it was not leaking when I pulled it. |
Bills85Westy Samba Member
Posted: Fri Jun 23, 2017 9:20 pm Post subject: Re: How bad does my heater core look |
Whether it was leaking or not, if you've got the thing out and in your hands, i would replace it. As you know, it's a job to get it out and IMHO one of the "might as well" if you're that far in there.
My 85 Westy had a really well maintained cooling system & on a low mile van. It sat for some time and as I started to use it regularly, I had to replace both the front and rear within the first 4 years. Just a little bit of weeping that caused fogging when starting out in the morning.
Of course, if you don't mind getting in there, replace it when it fails..... _________________ 89 Tristar Syncro Doka - White
85 Westfalia Syncro (conversion)
SAH 1.8T Conversion - 2005 AWP
Engine Conversion Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=612144&highlight=
85 Doka L345 Grey - 1.9L |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sat Jun 24, 2017 6:32 am Post subject: Re: How bad does my heater core look |
Yes there is a way to test it.
That would be a pressure test.
You know what happens when the engine overheats and you've got steam blowing out of the radiator because of low coolant causing the engine to overheat-that steam is a lot of pressure.
That steam will burn you. Fortunately the heat exchanger is enclosed inside the heater housing so the chances of that happening is practically zero-you've never heard of anyone getting burned by a heater core!
But that pressure is why you get it tested. the pressure cap on a radiator is designed to vent pressure at 15psi I think (somebody can chastise me if I'm wrong.) The heater core and radiator has to withstand more than 15psi so that the weak point is the radiator cap and it vents before the radiator or the heater core ruptures from the pressure.
I would be concerned about the powdery looking corrosion shown in your pictures. That is a sign of something not right.
The question is the source of that moisture to cause that.
If there was any of that powdery white corrosion on the ends of the heater core between the plastic and the aluminum where the seals are I would change it.
A pressure test would show if the seals are going bad.
A radiator shop can do the test.
$145.00 at Van-Cafe.com _________________ This free advice is worth exactly what you paid for it.
Posted: Sat Jun 24, 2017 6:40 am Post subject: Re: How bad does my heater core look |
This blackening of the fins is a concern of why it is there and exactly what it is.
There is a product used to clean evaporator cores. There are a few different vendors of the same product.
Do a search for "Evap Foam No Rinse", mfg. is Nu-Calgon, product number 4171-75.
it is a spray can of a mild acid that will clean the aluminum.
Try very hard not to bend any of the fins when you are handling the core _________________ This free advice is worth exactly what you paid for it.
Posted: Sat Jun 24, 2017 6:52 am Post subject: Re: How bad does my heater core look |
Here is another alternative.
However, when ever you buy anything used the condition is always in question and you have to check it just like the parts you have that you are questioning.
https://www.thesamba.com/vw/classifieds/detail.php?id=2067171 _________________ This free advice is worth exactly what you paid for it.
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Sat Jun 24, 2017 7:13 am Post subject: Re: How bad does my heater core look |
it's in your hands....replace it. it's 100 years old. I just rebuilt my rabbit truck top to bottom. I replaced the old heater core just because. these tend to block up over time from junk in the cooling system.
I have heat by the end of my driveway now. just do it. you'll be glad you did. buy a behr or valeo if you can. no china junk. I wouldn't waste a minute trying to clean it.... _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
danfromsyr Samba Member
Posted: Sat Jun 24, 2017 7:25 am Post subject: Re: How bad does my heater core look |
people say it's a pain in the butt job, and most of them haven't replaced a heater core from a more modern VW..
the vanagon dash while a pain comes out in about 2hours (less once you get used to it). you are younger than you are rich. I say clean it, put it back in and all will be fine.. replace it again in a year.. put that $150 towards brakes/fuel pump/coolant items that will leave you stranded or unsafe.
but, do yourself a favor and put some 1/4" hardware cloth sandwiched between the heater box and the 2 holes that it mounts to. keep the heater core from becoming a mouse habit trail. because even if you put a new one in. nothing is worse than mouse pee on a heater core. _________________
Abscate wrote: |
vino de vano Samba Member
Joined: September 10, 2016 Posts: 359 Location: columbia gorge
Posted: Sat Jun 24, 2017 7:41 am Post subject: Re: How bad does my heater core look |
the pic of your flaps sealing are a little fuzzy. It's important to use the right foam for a good seal. I went with a truck bed to camper shell foam tape. Just a thought. Lucky you to have such a great grandma. Tough call on replace core or not. I just rinsed mine out and put it back in and am hoping it lasts. _________________ what a long strange trip it's been |
Posted: Sat Jun 24, 2017 7:45 am Post subject: Re: How bad does my heater core look |
skills@eurocarsplus wrote: |
Put a garden hose on one of the pipes and see how much water comes out the other pipe. If you have good steady flow it is not blocked up. _________________ This free advice is worth exactly what you paid for it.
Abscate Samba Member
Posted: Sat Jun 24, 2017 7:53 am Post subject: Re: How bad does my heater core look |
Fill it with water, Put a rubber stopper firmly on one pipe, then rig up a garden hose to the other. 30 feet of water pressure up,in the air is about 1 ATM pressure, if it holds that Put it back in.
If you dry it in the sun for a day before, any seep will show up well. _________________ .ssS! |
tencentlife Samba Member
Posted: Sat Jun 24, 2017 9:35 am Post subject: Re: How bad does my heater core look |
Hmm, surprising ol' Terry Kowabungowski or whatever isn't here flogging his gold-plated heater cores.
There's an old joke where the guy calls his lawyer's office and asks to speak with him, but is told that his lawyer is dead.
He calls again the next day. Same question, same polite reply.
He calls again every day for three weeks running, with the same short conversation each time.
A day comes when he calls once more and asks for his lawyer. The receptionist finally loses patience and yells at him, "Mister, for the twentieth time, your lawyer is dead!"
He says, "I know, I just love hearing you say it."
Come on, folks, who wants to give me that pleasure? _________________ Shop for unique Vanagon accessories at the Vanistan shop:
levi Samba Member
Posted: Sat Jun 24, 2017 9:56 am Post subject: Re: How bad does my heater core look |
I'll give you 2nd best.
He is BANNED
How are you feelin ten cent.
Long time no see _________________ One of these days I'm gonna settle down,
levi Samba Member
Posted: Sat Jun 24, 2017 9:58 am Post subject: Re: How bad does my heater core look |
Btw;
If you want, you can ask me again tomorrow. _________________ One of these days I'm gonna settle down,
levi Samba Member
Posted: Sat Jun 24, 2017 10:00 am Post subject: Re: How bad does my heater core look |
Also, that heater core has the clean area on it because there's a plate that goes over that. _________________ One of these days I'm gonna settle down,
Posted: Sat Jun 24, 2017 10:20 am Post subject: Re: How bad does my heater core look |
levi wrote: |
He is BANNED
Long time no see |
Naw, man, that's as good as it gets, THANKS Levi!! I'm glad it was you, one of the solid oldtimers, who granted my wish. God damn it's about fracking time, que no? Maybe I'll call back tomorrow, cuz y'know, once is not enough...
Feeling good, thanks, I bet you are too, you got your home back!! Some good changes in the works here I'm real excited about, I'll be telling y'all about it pretty soon, now I gotta get to work and make it happen. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Sat Jun 24, 2017 11:12 am Post subject: Re: How bad does my heater core look |
If you leave the baffle plate out you will get more air flow and the exterior of the core will be less apt to clog with dog hairs and other nasties. |
Posted: Sat Jun 24, 2017 11:16 am Post subject: Re: How bad does my heater core look |
Steve M. wrote: |
Put a garden hose on one of the pipes and see how much water comes out the other pipe. If you have good steady flow it is not blocked up. |
not true at all...
you will still have good flow if the bottom 2 inches are plugged solid with sediment. to each their own....having done this kind of work for 30+ years, I can tell you I personally wouldn't do it. any time I have the dash that far down it gets a new core and evaporator....unless it was done within the last couple of years. 150.00 now, or 6 hours of your life later....guess you have to decide what your time is worth....
think of it this way....people replace radiators for the same reason....it may look good, but your cooling sucks. this is nothing more than a small radiator...with even smaller passages inside. _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sat Jun 24, 2017 11:58 am Post subject: Re: How bad does my heater core look |
Steve M. wrote: |
not true at all...
you will still have good flow if the bottom 2 inches are plugged solid with sediment. |
Your right. I've been looking at a different type of heater core all week and when I close my eyes I still see it! _________________ This free advice is worth exactly what you paid for it.
