Sofia74 Samba Member
Posted: Sat Jun 24, 2017 4:19 pm Post subject: reassembling pedals - brake return spring - 74 coupe |
1974 KG Coupe - Can't figure out how to reassemble pedals - specifically the brake return spring.
Disassembled the cluster. cleaned, blasted, repainted. Added an X-CELERATOR “Speed Wheel” and clutch pedal extender both from Classic Bug parts but neither of those should have changed the brake pedal operation.
Does anyone have a good photo of the proper routing of the brake return spring? I've searched the threads but none have the picture I need….
I'm sure I am doing something wrong. As per SOP. |
trelms Samba Member
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Sun Jun 25, 2017 7:50 pm Post subject: Re: reassembling pedals - brake return spring - 74 coupe |
Hi. What I have done for decades is to bolt the pedal cluster to the pan with the spring not engaged onto the brake pedal. I assure the flat part of the spring is always facing the floor/pan. You have other factors involved here such as clutch pedal/cable orientation etc. Once you have the pedal assy bolted to the pan you should verify both pedals are upright. The brake pedal return spring is kinda tricky here to hook up to the pedal. I have an old cheapo 8" screwdriver which I cut a "V" into the screwdrivers flat in order to capture the end of the hook and push the end upwards towards the brake pedal specific groove for this spring. It takes a couple/few attempts but it works. I know of guys who used/modified a cotter pin remover tool for this also.
Hope this helps you, Bill |
Posted: Tue Jun 27, 2017 2:54 pm Post subject: Re: reassembling pedals - brake return spring - 74 coupe |
Thank you guys. I now see what was confusing me. Uninstalled, the flat part of the brake return spring sits rearward (as seen in the car). Every photo showed it pointing rearward. Because its sitting on a bench. However, when installed the flat part points forward (as seen in the car). That makes sense.
Don't tell anyone I have an engineering degree.
Thanks again, Matt |
