dolamike Samba Member
Joined: June 25, 2017 Posts: 72 Location: San Francisco
Posted: Mon Oct 02, 2017 9:56 am Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
Question for the forum. it looks like all of the insulation in my engine compartment was pulled out after the fire. Has anyone replaced this with something more modern? Any recommendations on material? Anyone running a bus without it?
Any info would be great, thanks!
_________________ 71 Bay Window Bus
85 Westfalia |
wcfvw69 Samba Purist
Posted: Mon Oct 02, 2017 10:26 am Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
It was tar board. You can find it from a bus being scrapped or buy the ones for bugs and cut it to fit. I used a sound damper up there in my 70' and then put the tar board back up. _________________ Contact me at [email protected]
The Samba member since 2004.
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Oct 02, 2017 10:46 am Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
My 73 and 78 had a masonite type board with holes cut in it for pattern or whatever-- then that went over top some fibre type stuff- The masonite/cardboard-- stuff will break up easily so there is an extensive thread here on making a replacement- personally, I'm putting one together with woodstove heat tin having whatever asbestos replacement stuff glued to it , then the pattern masonite. I've watched several burning bus Youtubes and it seems many engine fires burn thru the hatch cover and set the interior on fire pretty quick. Having a fire barrier between the engine and the top seems like a good idea- still working out the hatch access problem though. That and Blazecut should give me a chance till the fondation ruiners get there. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Tcash Samba Member
Posted: Mon Oct 02, 2017 12:25 pm Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
dolamike wrote: |
What ever you choose, make sure it is fireproof.
https://www.amazon.com/dp/B01N342LIP?psc=1
Good luck
Tcash |
Posted: Mon Oct 09, 2017 11:50 am Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
I took inventory of the glass that was included with my bus over the weekend and unfortunately it looks like I am missing all of the vent windows, including the doors.
Question, are there any differences i should be aware of between the vent windows on bay window busses between 1968-1979?
Any tips on sourcing these other than the classifieds, are there good reproductions available?
Any advise would be greatly appreciated.
Thanks! _________________ 71 Bay Window Bus
85 Westfalia |
Tcash Samba Member
Posted: Mon Oct 09, 2017 4:04 pm Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
Question, are there any differences i should be aware of between the vent windows on bay window Bus's between 1968-1979?
No mounting differences both front an back fit 1968-79.
Front wing: IIRC the Fastener (latch) knob changed.
Rear vent wing: there is a left and right, come in chrome or black.
Front vent wings are available, but I have not seen the rear vent wings.
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-241-837-601
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-241-837-602
By the time you source used rear vent windows, restore them and add up the cost of the seals.
You might be better off with new sliding windows that come with seals.
http://www.busdepot.com/vw/0/0/21/0/?q=sliding%20windows
Good luck
Tcash |
Posted: Mon Oct 16, 2017 10:14 am Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
Installed the engine over the weekend. Did the engine and trans at the same time, worked really well, two jacks were definitely needed even with the ATV jack.
I got the everything lined up and the trans bolted in when i realized that I didn't have the engine mounts bolted to the mustache bar. Definitely a learning experience.
85 Westfalia |
stwesty Samba Member
Joined: May 10, 2015 Posts: 128 Location: Vancouver, Canada
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Tue Oct 17, 2017 1:41 pm Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
Ive got panes of glass. But the tab on the bottom is gone... if you think you can use them I'll sell cheap. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Tue Oct 17, 2017 2:12 pm Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
Great dog!!
At least that didn't
My worst was a nasty HP Turbo on a Volvo - first I was an idiot and didn't replace the CBV until it was installed, then after struggling 3 hours to install it on car, I found the diaphragm on the floor under the car - it had popped out while I struggled with the cover. I almost stroked when I saw it. _________________ .ssS! |
Posted: Mon Oct 23, 2017 2:15 pm Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
Got the engine started over the weekend!
Also got my wheels on. Had the rims powder coated and found the tires on Craigslist. Hankook RA08 with less than 100 miles on them. Previous owner changed them out shortly after buying because they wouldn't fit after he lowered the bus.
I hope to have it out for a first ride in a week or so, just need to get the axles on. The transmission won't shift into first or second, I'm really hoping it's just the clutch adjustment! _________________ 71 Bay Window Bus
85 Westfalia |
Dkwautounion Samba Member
Posted: Mon Oct 23, 2017 7:58 pm Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
If it won't shift into first or second .....you may need to loosen and move around the plate at the base of the shifter. Search on it. I don't know enough to tell you what to do exactly but that sounds like it may help. |
Posted: Tue Oct 24, 2017 6:26 am Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
Dkwautounion wrote: |
x2 _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Tue Oct 24, 2017 9:18 am Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
Cool, thanks for the help. I'll definitely look into that this weekend.
It's strange, it will go into second when the engine isn't running... can't get it into first though. When the engine is running it won't go into second either, makes a sharp grinding noise. _________________ 71 Bay Window Bus
85 Westfalia |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Wed Oct 25, 2017 6:03 am Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
dolamike wrote: |
It's strange, it will go into second when the engine isn't running... can't get it into first though. When the engine is running it won't go into second either, makes a sharp grinding noise. |
If it goes into gear with the engine off but not when running means that your clutch is not completely disengaging, you need to figure out what the clutch issue is. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Nov 11, 2017 2:47 pm Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
Soooo.... I'm having some clutch issues... Any help would be greatly appreciated.
For reference this is the new clutch kit I installed:
https://www.partsgeek.com/ss/?i=1&ssq=W0133-1609526&x=0&y=0
New Bowden Tube
New Clutch Cable
New TO Bearing
Flywheel was machined by a local VW shop familiar with air cooled engines of this era.
Transmission goes into all gears with the engine off.
Transmission will not go into any gear with the engine on.
Engine will start in first with clutch pressed but lurches forward.
I have adjusted the clutch cable from fully slack to all the way tight, two turns at a time and then tried to start the engine, no luck.
I just can't get the clutch to disengage.
This morning I pulled the engine and transmission, thinking this might be due to a TO bearing that came off during install, no dice, looks fine.
The only thing I can think of is the clutch plate is a little wide, photos below of the original and the new one. The new one can be forced into an 8mm wrench but I need to press the two halves together.
Any idea on what the problem might be?
Old Cllutch
New Clutch
85 Westfalia |
Posted: Sat Nov 11, 2017 5:49 pm Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
I'd bet my left nut that your problem isn't that extra 1mm of clutch material. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Posted: Sat Nov 11, 2017 6:09 pm Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
You can see where the clutch was rubbing the flywheel on the inner edge in this photo. I have no idea what else would cause that... it's a mystery to me.
85 Westfalia |
Colonel Mosby Samba Member
Joined: February 23, 2014 Posts: 253 Location: Warrenton, VA
Posted: Sat Nov 11, 2017 6:19 pm Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
Your bus looks great. I think it might be the throwoutbearing or maybe plate. I think sometimes those do not match up based on the centering ring. Use the clutch alignment tool. Don't forget the thermostat. I put one on mine and it made a world of difference. |
Posted: Mon Nov 20, 2017 10:12 pm Post subject: Re: 1971 Bay - Me and the dog are building a bus! |
Clutch is working, went for my first drive over the weekend.
I covered the clutch issue on this thread if anyone is interested...
https://www.thesamba.com/vw/forum/viewtopic.php?p=8617529#8617529
85 Westfalia |
