Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
Posted: Sun Jun 25, 2017 4:38 pm Post subject: Help Diagnose Noise at Clutch Operating Lever (video) |
Hi all.
This is for an ~ 50K miles pro rebuilt WBX transaxle, new at time of tranny install Sachs WBX clutch on an ABA gas I4 engine with KEP adaptor and flywheel. Clutch slave was replaced much less than 50K miles ago.
At times, the clutch shudders when engaged. This happens after I've driven the van a while. This is true for the groaning noise too. Clutch shudder could be a separate issue.
I'd originally thought the groaning noise was coming from the clutch master cylinder but its for sure louder at rear of vehicle. I have an idea what it may be but could really use input on this one.
~ 22 second video:
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
minnisp Samba Member
Posted: Sun Jun 25, 2017 8:33 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
hey man,
It looks like the crossarm shaft bushing is moving. which means it's probably worn out. But first the clutch slave bracket looks loose. There's a 17mm slave bracket bolt at the front/top of the engine on the drivers side that should be tightened. you also probably need to tighten the clutch slave bolts, which are 13mm. They're hard to get to. One is right below the 17mm bracket bolt mentioned above, the other .. try from underneath the drivers side of the van, in front of the engine just under the cv shaft. You'll need a long ratchet extension and maybe a swivel for the socket. a 13mm end wrench to hold the top nut.
otherwise, you'll need to drop the transmission and get a look inside the bell housing to see what's going on with the release bearing, the cross arm shaft and the shaft bushing. _________________ 1989 GL 2.1 WBX Manual |
Posted: Mon Jun 26, 2017 11:05 am Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
minnisp wrote: |
hey man,
otherwise, you'll need to drop the transmission and get a look inside the bell housing to see what's going on with the release bearing, the cross arm shaft and the shaft bushing. |
Thanks. Yes I see that bracket movement. Not a good sign.
The noise sounds like dry bushings at the cross shaft but that may be wishful thinking. One person suggested it could be the pressure plate.
VE7TBN |
Posted: Mon Jun 26, 2017 3:08 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
All fasteners were torqued ok, no obvious cracks at bracket. My thinking is that the movement between bracket and collar on clutch housing is normal and that a little "give" there is ok; better to have a little give than put that force directly onto the collar at clutch housing? (housing metal is not super strong).
As an aside, it occurred to me that one could add a 3rd brace to the clutch slave bracket. I'm sure it's been done. It also occurred to me that if one had a clutch housing with failed collar they could make a one piece part that serves as a collar and bushing but I don't think the clutch housing metal is thick enough to support a part like that; over time stresses from that part to housing might cause cracks at housing over time..... if it even worked.
VE7TBN |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2320 Location: Adobe Jungle USA
Posted: Mon Jun 26, 2017 3:11 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
There's actually a greasing hole somewhere behind the lever plugged by a screw. I have found that putting grease inside the hole then screwing it in is a good way to grease just a little but not too much. Picture:
_________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Mon Jun 26, 2017 3:44 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
Gnarlodious wrote: |
There's actually a greasing hole somewhere behind the lever plugged by a screw. I have found that putting grease inside the hole then screwing it in is a good way to grease just a little but not too much. Picture: |
Aha! Yes! That 11 mm head bolt with 1/2 of the threads erased. Nice. Thank you very much for that tip!! Was just wondering if a thin grease needle might get grease into the outer end bushing but I now recall that theres a rubber seal of sorts at each end of the hole in cross shaft hole in the clutch housing. The hole you point to accesses the middle of the inner thicker plastic bushing. At very least I could get some kind of thicker liquid grease in there (maybe chain lube?) which might work its way between the cross shaft and the 3 bushings.
I wrote:
"My thinking is that the movement between bracket and collar on clutch housing is normal and that a little "give" there is ok"
Here's a video showing clutch arm travel on my other vanagon. I don't see the slave bracket moving:
https://goo.gl/photos/qsqZgDhsRPt35cpC9
The cross shaft bushings on that bus are in great shape. The clutch works awesome.
Neil.
for other curious folks. Some of the parts involved. In image, the "thicker plastic bushing" is the greyish short bushing with hole to the RH of circlip and washer. This is where the tail of the 11 mm head bolt fits; it holds that bushing in place keeping it from turning. There are two bushings like the damage one shown.
VE7TBN |
Posted: Mon Jun 26, 2017 4:29 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
A slightly better video. It appears the cross shaft isn't moving laterally, that I can see. Bracket certainly does move but I don't think that's the issue.
The sound isn't as loud as the video makes it out to be but it gets worse as I drive the van. Engine was cold when I shot the video.
Any thoughts on what the sound may be are welcome. Barring any muffler bearing or flux capacitor jokes.
VE7TBN |
Posted: Mon Jun 26, 2017 5:27 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
that's what my clutch was doing .. the growling, not the bracket moving. I didn't figure out which specific part was causing the growling. It was all worn out and wobbling and squawking together. i just replaced it all. Once you're in there ....
I like the metallic cross-arm shaft bushing better than the plastic one (the plastic one is the OEM one). Get the OEM throw out bearing guide from Weddle, not the aftermarket one from Van-Café. The aftermarket guide is kind of weak..my 2 cents. Unless you can live with it like it is. . I couldn't. squawk! squawk! _________________ 1989 GL 2.1 WBX Manual |
Posted: Mon Jun 26, 2017 5:34 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
that's a great video by the way. My guess is the bushing. _________________ 1989 GL 2.1 WBX Manual |
Posted: Mon Jun 26, 2017 5:45 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
Thanks minnisp.
When you fixed the issue, did you replace clutch and rebuild clutch housing at the same time?
If I'm lucky, the existing throw out bearing guide is OEM. If not I may have a good used one.
I guess the tranny is coming out either way. Applied lube to plastic cup on slave. No real change.
And thanks re: comment on video. At very least videos help me diagnose. No helper here.
Thankfully, I have new OEM rubber, plastic bushings on hand but I agree; a metal bushing at driverside end of cross shaft sounds like it would be better.
VE7TBN |
Posted: Mon Jun 26, 2017 6:54 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
Yes, I did the whole nine yards several times. i learned the hard way, and then went way beyond. _________________ 1989 GL 2.1 WBX Manual |
Posted: Sun Jul 02, 2017 10:58 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
There's actually a greasing hole somewhere behind the lever plugged by a screw. I have found that putting grease inside the hole then screwing it in is a good way to grease just a little but not too much. |
Thanks again Gnarlodious. I removed that bolt and dripped in a mix of grease and chain lube then sprayed chain lube at outside end of thinner plastic bushing at cross shaft. The clutch pedal felt smoother, little to no "shudder" on last 1/2 of push though as I drove the van, I could feel a little bit of that starting again.
I'm pretty certain the noise issue is being created at cross shaft and bushings.
In spraying lube at outside end of the thinner bushing, I could then see play between the cross shaft and that bushing when I pushed up on the cross shaft. There really shouldn't be any play there AFAIK. NOT impressed. I guess new bushings aren't generally installed when a tranny is rebuilt. My thinking is that while pushing up on cross shaft, I might be able to push lube in there with a thin needle on grease gun.
post edited slightly. _________________ 1981 Westy DIY 15º ABA
VE7TBN |
tikiman71 Samba Member
Posted: Mon Nov 11, 2019 12:53 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
Hi there!
I know this was some time ago, but did you ever resolve the creaking clutch problem? I am having the exact same noise and issue, and have since lubed externally and built a more robust slave cylinder mount, but still have the noise and a slightly crunchy clutch feel. I know I need to pull the tranny at this point, but was hoping to be motivated by your successful remedy of the problem.
Cheers,
Adam _________________ 1987 Westfalia GL |
Posted: Mon Nov 11, 2019 1:56 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
tikiman71 wrote: |
Hi there!
Cheers,
Adam |
IIRC, lubing the clutch operating lever shaft bushings helped. I'm nearly certain that the noise is due to those bushings being worn.
I haven't driven that van a lot lately but again IIRC, it seemed that higher ambient temps, e.g. summer time, and use (more than less), seemed to exacerbate the noise.
Gnarlious' tip about lubing those bushings through the 11 mm head bolt that holds the bushing in place is a good idea IMO.
Bottom line: I'm nearly certain I'll be replacing those bushings sooner than later but if the noise returns, I'll live with it and lube as needed til I drop tranny and replace those bushings.
The "crunchy" feel you mention could indicate a whole different issue?
VE7TBN |
Posted: Mon Nov 11, 2019 2:10 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
Thanks for the reply!
Yes the crunchy feel of the clutch may be unrelated, but the creaking noise coincides with the crunch, always after things warm up a bit. On a cold startup, there is no clutch engagement noise or crunchy pedal feel. Then they usually come on within 30 minutes of driving/shifting.
The noise and feel are certainly not the end of the world, but after a while I fixate on them and it takes away from the (usual) pleasurable driving experience of the van. And it makes driving in traffic awful.
I'm hoping to get into the transmission in the next few months to take a look at the cross shaft assembly, TOB, and pressure plate. Everything was rebuilt/replaced less than 25K ago, so it is a bit of a mystery.
Thanks again for the quick response,
Posted: Mon Nov 11, 2019 8:24 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
You're welcome.
Ya, thinking about it again, based on your last description, if the cross shaft bushings were really worn, I guess the "crunch" sound could be a little metal on metal of cross shaft against hole in clutch housing or possibly against the end of that 11 mm head bolt. But, that sound/feel could be due to several different things.
Hopefully, the cross shaft isn't wearing (ovaling) out the hole in clutch housing it passes through. That would suck. The clutch housing material isn't that strong. I doubt excessive wear at that hole would allow cross shaft to damage the collar slave bracket sits on but.......
One thing is for sure, as I drove and tranny soaked up some engine heat, the noise would get worse.
Neil.
couldn't find image of "collar" I refer to but found this instead. This shows method I figured out to remove clutch operating lever off cross shaft. It worked great. IMO, every Vanagon owner should have a small and larger Pittmann arm pullers as tools. Good for front end work. You need to drill a small countersunk hole at end of cross shaft for Pittmann arm point.
VE7TBN |
Prairie Dog Samba Member
Joined: January 16, 2011 Posts: 16 Location: Sioux Falls, South Dakota, USA
Posted: Tue Aug 22, 2023 2:44 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
I have the same problem shown in the video for “Help Diagnose Noise at Clutch Operating Lever". The cross-shaft lever squeaks whenever I depress the clutch. I ordered the cross-shaft bushing kit and am trying to emotionally prepare myself for removing the transmission to replace and regrease the bushings. In addition to the squeak, I can feel some resistance in the clutch pedal, especially when I am starting in first gear on an incline. I now have to depress the clutch pedal to the floor to change gears.
I’m driving a 1988 Westfalia, 2wd. The tranny was rebuilt by AA Transaxle about 12 years ago. They installed a Peloquin LSD and higher 3rd and 4th gear ratios for use with a 2.5 SOHC Subaru engine (Vanaroo turn-key engine transplant kit from a 2007 Subaru Impreza with 18K). I have about 65K on the van since installing the Subaru engine 11 years ago.
Is there anything else that might account for the noise, or for the clutch pedal engagement point now being almost to the floor?
The clutch was professionally replaced two years and 6k miles ago (clutch, pilot shaft, clutch release bearing, flywheel machined).
I recently drained and replaced the tranny gear oil (Sweptco 210 – as recommended by AA Transaxle). The magnetic drain plug had only a very light coating of metal shavings. I had to remove the shifter shaft to get enough torque on the refill allen plug to remove it without stripping it. While the shifter rod was disconnected, I manually shifted through the gears (following directions in a GoWesty article), so I don’t think the transmission itself is the problem.
I checked the clutch master and slave cylinders. Neither is leaking and the fluid level in the reservoir is full. I bled the system multiple times (twice with a pressure bleeder and once by the traditional method). There are no air bubbles in the line that I can see.
So, is there anything else I should do or check before pulling the transmission?
Thanks for your help.
Jim |
Igeo Samba Member
Joined: September 25, 2018 Posts: 888 Location: Oakland, CA
Posted: Tue Aug 22, 2023 4:24 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
Were the clutch master and slave replaced with the clutch overhaul? Blow by in either could account for the low release and engagement point. _________________ 1987 Westfalia 2.1 WBX Manual |
Posted: Wed Aug 23, 2023 5:13 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
Igeo wrote: |
Were the clutch master and slave replaced with the clutch overhaul? Blow by in either could account for the low release and engagement point. |
No. I replaced the master about 10 years ago, but I replaced the slave a few months ago, after noticing that the clutch engagement point was getting awful close to the floor. I don’t know what blow by is. Is there a cure short of replacing the master cylinder? |
Igeo Samba Member
Posted: Wed Aug 23, 2023 6:04 pm Post subject: Re: Help Diagnose Noise at Clutch Operating Lever (video) |
Im suggesting that it's possible that the low engagement point may be related to internal leakage of one or both of those hydraulic components. I guess it it were mine, I'd replace both before going through the work of removing the transmission. If you still have issues, then you can at least eliminate those and focus on the release mechanism and clutch. Maybe do the master first since the slave is newer. _________________ 1987 Westfalia 2.1 WBX Manual |
