Help With Locating Sheet Metal Patch Panels
megasuomi
megasuomi is offline
PostPosted: Sun Jun 25, 2017 3:12 pm    Post subject: Help With Locating Sheet Metal Patch Panels Reply with quote
just purchased a 73 Thing, has rotten areas in rear fender areas near lower wheel well, and floor behind seat and battery area.
Can not seem to find a sheet metal repair panel for this????
Any thoughts?
Glad to be apart of the forum! Gonna be a great project for sure!
old toys are fun
EDragnDean
EDragnDean is offline
PostPosted: Sun Jun 25, 2017 3:57 pm    Post subject: Re: Help With Locating Sheet Metal Patch Panels Reply with quote
http://www.thingparts.com/
63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image
megasuomi
PostPosted: Mon Jun 26, 2017 3:20 am    Post subject: Re: Help With Locating Sheet Metal Patch Panels Reply with quote
Yes I have looked there as well as every other THING website with no luck, was hoping someone had a link to them or something? It must be a common spot for rust repair but there seems not to be parts.
old toys are fun
wbailey2112
wbailey2112 is offline
PostPosted: Mon Jun 26, 2017 4:52 am    Post subject: Re: Help With Locating Sheet Metal Patch Panels Reply with quote
You are most likely going to need to purchase a rear clip from a car that has had front end damage and cut the panels out that you need from the clip.
The only new panels that you are going to find are inner and outer rockers, floor pans (full or partial) and a few other panels (front apron, etc.).
Call or email Mike Basso at ThingParts.com for advice and to see if he has any rear clips that have the panels that your need.
His phone is: 518-630-0173
His email is: [email protected]
kubelmann
kubelmann is offline
PostPosted: Mon Jun 26, 2017 9:16 am    Post subject: Re: Help With Locating Sheet Metal Patch Panels Reply with quote
Cull VW Thing doors are a tried and true body repair method. Many folks like me sell culled doors for $25 to be used for body repair. Typically the bottom edge of Thing doors can rust out leaving lots of perfect body metal to use for other rust repairs...
