gblair Samba Member
Posted: Tue Jun 27, 2017 6:45 pm Post subject: Filler neck hose size |
Hi
Would anyone know what size the filler neck hose is? I bought a Gas Smell Kit about 2 years ago and while looking it over for the upcoming Thing east show and I noticed there is some cracks in the hose and would like to replace it again. Didn't know if it was possible to find it at a local parts store.
Thanks |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Tue Jun 27, 2017 7:36 pm Post subject: Re: Filler neck hose size |
Don't know the size but make sure what you find will work for gas. See you there. |
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Thu Jun 29, 2017 10:12 am Post subject: Re: Filler neck hose size |
hey Gblair,
I installed that kit a while back and it helped, then the smell returned.
Found out that where the large hose to the tank and the smaller 1/2 size
elbow join up at the filler neck hole, the weight of my spare tire caused a tear in the elbow hose.
didn't happen right away either, not sure if the tire was mashing on it under normal conditions or when I shut the hood if it's mashing on it.
I trimmed it and got a good re-seal, and for now, I tucked a few shop rags under the elbow hose to support it and keep it from flexing so much.
Not sure how you'd tell this is occurring without getting a ripped hose yourself but thought i'd mention.
I guess if you smell gas later, check that area. it was leaking gas under the mat, and not a lot but enough to cause a strong odor.
PS: I hope yall have fun at the show, I'm not going to be able to attend this one, maybe next year if it's closer.
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
gblair Samba Member
Posted: Fri Jun 30, 2017 6:23 pm Post subject: Re: Filler neck hose size |
I ordered on from Thing Parts. Should be here tomorrow and I will tear into it. |
