Dickz Samba Member
Posted: Tue Jun 27, 2017 9:16 am Post subject: 1980 air cooled - convert to electronic ignition? |
1980 air-cooled with 62,000 miles. On a recent 3000 mile trip, points and condenser needed to be changed once and then the points readjusted a second time. Both VW shops that specialize in air-cooled suggested converting to electronic ignition. Now that I am home, trying to decide which way to go.
Did a search, but all the info seems old and conflicting. Seems the Petronix has mixed reviews. Has anyone used the Hot-Spark system? How about the Crane xr700 system (saw one old comment)?
Would welcome any thoughts, experience, suggestions. |
Zeitgeist 13 Samba Member
Posted: Tue Jun 27, 2017 10:04 am Post subject: Re: 1980 air cooled - convert to electronic ignition? |
I would avoid the aftermarket complete electronic distributor kits on the market advertised as having the correct advance curve w/vacuum advance actuators. They're Chinese Bosch copies that entirely lack the proper internal shaft bushing arrangements. I recently serviced an '80 van with 30k on a new engine with one of those distributors and the rotor was wobbling all around so much that you could see the cap rocking back and forth. Complete junk. I think I would look for the ignition setup from a 1.9L WBX which is simple and stand alone managed. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
NobyDoby Samba Member
Joined: March 03, 2012 Posts: 101 Location: The Netherlands
Posted: Tue Jun 27, 2017 10:48 pm Post subject: Re: 1980 air cooled - convert to electronic ignition? |
If you have the $$, you could put in a programmable 123Ignition with vacuum connection. You can program every curve you want and finetune it specific to your engine. _________________ 1980 Aircooled Type 4 CU 2.0L T3 Westfalia:
Flowed AMC 39x33mm heads with Porsche swivel adjusters and CR 8.0:1
94mm Mahle dished P/C's & 71mm Stroke
Original VW CU Bus Hydro Cam w/Febi Hydro Followers
Dual Dellorto's DRLA 40 - 32 Venturi's
SyncLink Throttle System
MSS Central Airfilter
123Ignition Tune & NGK BP6ET
Vintage Speed Dual Side Super Flow Type 4 Exhaust |
Mulcheese Samba Member
Joined: September 19, 2004 Posts: 548 Location: Maple Grove, Mn
Posted: Wed Jun 28, 2017 6:27 am Post subject: Re: 1980 air cooled - convert to electronic ignition? |
Hey Noby
I may been the poster you came across referring to the CranesCam. Not sure but I have come across very few with this in. Mine came with the van 13 years ago when I purchased it and I have never had and issue. I even changed out my dist with a SVDA so reinstalled it and again havent touched it since. If you can still find one I recommend it. Otherwise in my opinion the most common is the Petronix.
Mine works awesome!
Pat _________________ 82 Westy: Air is cool! |
Dickz Samba Member
Posted: Wed Jun 28, 2017 8:01 am Post subject: Re: 1980 air cooled - convert to electronic ignition? |
Thanks for the responses to date. I appreciate the inputs as I am trying to get the van reliable to avoid future problems. The 123 system certainly looks/seems great, but it is pricey. Revives are good though.
Thanks again. |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Wed Jun 28, 2017 8:03 am Post subject: Re: 1980 air cooled - convert to electronic ignition? |
I used to drive a 914 for a work commute. The only time it let me down was when the Pertronix died. But the good thing about it was that it's a simple task to re-install the points which you will keep in your toolbox as a safety measure. If I still had a Type 4 motor I would be reluctant to change from points and condenser again. |
