Template of the Automatic transmission starter mounting flange
greebly
greebly is offline
PostPosted: Wed Jun 28, 2017 9:00 am    Post subject: Template of the Automatic transmission starter mounting flange Reply with quote
Anyone have an auto starter or automatic transmission lying around to post a template of the starter mounting flange?
greebly
greebly is offline
PostPosted: Thu Jun 29, 2017 6:41 am    Post subject: Re: Dimensions of the Automatic transmission starter mounting flange Reply with quote
Please.
greebly
greebly is offline
PostPosted: Fri Jun 30, 2017 7:07 am    Post subject: Re: Template of the Automatic transmission starter mounting flange Reply with quote
Pretty please?
rubbachicken
rubbachicken is offline
PostPosted: Fri Jun 30, 2017 7:21 am    Post subject: Re: Template of the Automatic transmission starter mounting flange Reply with quote
you can buy them from westy ventures
lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182
IdahoDoug
IdahoDoug is offline
PostPosted: Fri Jun 30, 2017 7:36 am    Post subject: Re: Template of the Automatic transmission starter mounting flange Reply with quote
I do - what cha looking for?
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader
Wildthings
Wildthings is offline
PostPosted: Fri Jun 30, 2017 7:42 am    Post subject: Re: Template of the Automatic transmission starter mounting flange Reply with quote
It is identical to a manual flange and goes way back in the VW lineage. No idea what your needs are.
greebly
greebly is offline
PostPosted: Fri Jun 30, 2017 9:55 am    Post subject: Re: Template of the Automatic transmission starter mounting flange Reply with quote
I need a template of either the mounting flange on the automatic transmission or the automatic transmission starter. Take a piece of cardboard and wet the surface of the transmission where the starter mounts up to. Or rub the cardboard to make an impression. Scan the impression 1/1 and post it here. Or if you have the automatic starter cut a hole in the cardboard to clear the bendix gear. Place cardbpoard over the starter flange and make an impression. Use a marker to accentuate the edge of the mounting flange and the mounting holes and please post it. If you are unable to insure a 1/1 ratio on the image you post please provide dimensions so that I can size it properly. Westy Ventures sells an adapter to mount a MANUAL TDI starter unto the Manual Vanagon transmission, they sell another adapter that allows a MANUAL TDI starter to be installed unto the Vanagon Automatic. I am sure they have the dimensions for both, but doubt they are willing to post it . What I need is the mounting flange for the auto starter.
greebly
greebly is offline
PostPosted: Fri Jun 30, 2017 10:06 am    Post subject: Re: Template of the Automatic transmission starter mounting flange Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=438042&view=next
Wildthings
PostPosted: Fri Jun 30, 2017 10:17 am    Post subject: Re: Template of the Automatic transmission starter mounting flange Reply with quote
Moderator note:
Diagram removed, as requested by manufacturer of part
It looks like the difference between the two is just the thickness of the adapter. As I said the bolt patterns are going to be the same, going back for decades.
greebly
greebly is offline
PostPosted: Fri Jun 30, 2017 10:18 am    Post subject: Re: Template of the Automatic transmission starter mounting flange Reply with quote
Thanks Wildthings. . The reason I am asking is that xoOOoox posted that an automatic TDI starter could be used directly on the auto transmission by wallowing out the mounting holes slightly. I have obtained a TDI automatic starter and would like to machine the mounting holes prior to dropping the present starter so that if is just an R&R when I do it. My present starter acts like it is going to die when I attempt to start the 1.8T high compression engine when it is warm. I'll cleanup the OEM starter and throw it in the van as a spare.
