Colonel Mosby Samba Member
Joined: February 23, 2014 Posts: 253 Location: Warrenton, VA
Posted: Wed Jun 28, 2017 2:43 pm Post subject: Fuel Pump and Fuel Hoses...I am feeling hosed. |
So I have 1970 Bus with the old school Pierburg Fuel pump. It started seeping gas on the top cover. The little rubber gasket that the top screws down onto the upper body of the pump was wrinkled up. I got the rebuild kit and made the repair and redid the entire pump. So next I reinstall the pump and hoses. Within a week that braided hose was smelling of gas and you could tell it was getting wet. Traded that out for a new braided hose. 1 week same deal. I found some fuel injection hose with the fancy rubber inner liner but the hose is a wee bit big and even clamped down I didn't like it. So now I am pulling the hose out and the outlet pipe on the pump comes rightout. I guess it was just pressed in.
I elected to try JB Marine Weld. Just a thin smear and pressed it back in. Put a dab around the pipe and the body of the pump for a good seal. You think this will work?
Ordered some fuel hose from Voltzboltz that seems to be the best hose for VWs and I ordered it. Anybody have experience with Codan SAE J30 R9 hose at the 5.6 mm size?
Hose will not get here for a while. Coming from the UK. Found some Autocraft fuel hose 4.7mm size. J30R7. Thinking about using this for a few weeks until the good hose arrives. Anybody think this hose is worth a try or should I sit tight for couple of weeks?
been frustrating. Just want to take a cruise so bad. Something so simple is being a pain |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Wed Jun 28, 2017 3:34 pm Post subject: Re: Fuel Pump and Fuel Hoses...I am feeling hosed. |
Clean the inside and outside of the hose fitting and get it dry before applying the JB Weld. Its great with gasoline and for filling dental caries, too. _________________ .ssS! |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Wed Jun 28, 2017 3:46 pm Post subject: Re: Fuel Pump and Fuel Hoses...I am feeling hosed. |
you might consider safety wiring the carb inlet as well- nothing worse than a fuel line playing sprinkler with a generator/alt. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jun 28, 2017 4:03 pm Post subject: Re: Fuel Pump and Fuel Hoses...I am feeling hosed. |
Colonel Mosby wrote: |
Anybody have experience with Codan SAE J30 R9 hose at the 5.6 mm size? |
Never heard of them or it, but I did get some hose from an Ebay seller called Silicone hose world and/or Advanced fluid technologies out of the UK a few years ago and was less than impressed, the pic below shows what it did after a few months. Just because the factory in China print's an SAE spec on the hose doesn't mean it's the real deal
I use 1/4 barrier FI hose from my FLAPS (J30R9), it squeezes down onto the fittings with good FI clamps and has been doing it's job for more years than I should admit, no slipping, leakage or cracks.
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jun 29, 2017 5:10 am Post subject: Re: Fuel Pump and Fuel Hoses...I am feeling hosed. |
williamM wrote: |
you might consider safety wiring the carb inlet as well- nothing worse than a fuel line playing sprinkler with a generator/alt. |
That one is solid. I had the carb rebuilt by Tim from Volksbits and he put in one of those screwed barbed inlets. Safety wire....now that is just a piece of wire from a screw on the carb top to the inlet pipe? Picture hanging wire do the job? |
Posted: Thu Jun 29, 2017 5:14 am Post subject: Re: Fuel Pump and Fuel Hoses...I am feeling hosed. |
busdaddy wrote: |
Well if it works for busdaddy then I know it is a go. Going to put that FI hose back on until my fancy hose from the UK arrives.
I got the clamps that are a band style without the little groves in the band. It has a screw that seems to tighten uniformly without making an oval. Going to try them out just picked them up. Other bands I use seem to chaffe the hose. |
Randy in Maine Samba Member
Posted: Thu Jun 29, 2017 5:53 am Post subject: Re: Fuel Pump and Fuel Hoses...I am feeling hosed. |
williamM wrote: |
I think you are already using the preferred fix. Really no need for the safety wire. |
Posted: Thu Jun 29, 2017 8:46 am Post subject: Re: Fuel Pump and Fuel Hoses...I am feeling hosed. |
If there is enough meat around the fitting you should be able to use a 1/16 NPT to hose adapter, probably that is what Voltzboltz used on the carb. He might well be able to supply you with another fitting for the pump, they are a bit hard to find otherwise.
You can get 3/16" Gates Barricade 30r14 hose, which will be a good fit on the carb and the fuel pump. |
