pomfritz Samba Member
Joined: December 18, 2014 Posts: 477 Location: Folsom, CA
Posted: Fri Jun 30, 2017 11:26 am Post subject: Aux battery short? |
My aux battery system has developed an issue. When I plug an ext cord into the hookup. There is a little pop and sometimes a smell. The tang on the hookup plug shows a little black burn mark. If I leave it please plugged in it seems fine. I've checked around and the connections seem good. No fuses have blown. I took apart the hook up box and it looks good. Connections are tight and nothing touching anything it shouldn't.
Any suggestions on what to check? I usually fix these eventually but it's not easy for me to diagnose stuff. Just learning as I go along. _________________ 83.5 233K. GW 2.3, SS exhaust, My German Frau named her Stefi |
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Fri Jun 30, 2017 1:20 pm Post subject: Re: Aux battery short? |
If I am understanding correctly, your 120V hookup on the exterior of your van is where you are noticing this issue. Is that correct? Which "tang" is discolored? Ground, neutral or hot? The 120V circuit in your vehicle should be totally separate from the 12V system. The outside 120V hookup, the rear bench 120V outlet and the 120V outlet inside your cabinet are all wired together, but totally separately from the rest of your wiring. A diagram can be seen in this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=617624&highlight=shore+power+wiring+diagram
Is there anything plugged into either of your outlets when this occurs? Unplug the devices and check again. Also inspect all visible heavy gauge "romex" style house wiring connected to your outlets. _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
timichango Samba Member
Joined: April 07, 2012 Posts: 858 Location: Squamish, BC, Canada
Posted: Fri Jun 30, 2017 1:36 pm Post subject: Re: Aux battery short? |
My guess is that the hookup box has an internal short — residual moisture, contamination, or a physical short. I'd replace the box and go from there. For the cost of a new box, I'd want to ensure that I was starting from a known-good initial 120v connection point before moving on to troubleshoot the van's interior AC wiring.
If you want quicker information about whether the extant box is OK or not, pop it off of the van, disconnect the wiring from it so that it's free from the van, and use a multimeter to test continuity between its connection points in the back. IMHO this sounds like a short — either consistent or intermittent (ie. it might be shorting intermittently when you wiggle the extension into place, and joggling the box's internal connections around, due to some kind of internal structural failure (eg. cracked plastic allowing a contact to temporarily rotate into another one).
Also: does this happen with a different extension cord? Do you know with certainty that the cord(s) you're using are solid? Do you know that the outlet it's connected to on the source end doesn't have some kind of electrical fault? _________________ . . . . . . . . . . . . . . . . . . .
Vroomhilde-San: Our 1991 Silver Vanagon Westy automatic + Subie EJ25 |
Posted: Fri Jun 30, 2017 5:27 pm Post subject: Re: Aux battery short? |
The right tang is discolored. (this would be if you are looking at it as you normally would be standing in front of the box.) What would this tell you?
I took the box apart and everything looked tight, no moisture seemed present. Do the modern electrical boxes fit this and have the right screw holes?
I think it's something here or earlier, like maybe the wall outlet, I will double check that. Inside the van, the wire goes to an outlet box that is GFCI protected, this box is the one by the rear seat and above the 12V outlet. And then from there the wire goes to another outlet box inside the rear seat area and that is what the charger is connected to. The GFCI in the van is not tripping, thought where the extension cord is plugged into is GFCI protected too and that is not tripping.
I plugged one of those plug outlet testers into the end of the extension cord and it looked good, no error lights. _________________ 83.5 233K. GW 2.3, SS exhaust, My German Frau named her Stefi |
Paulbeard Samba Member
Posted: Sat Jul 01, 2017 10:16 am Post subject: Re: Aux battery short? |
Aux power (12v) or shore power (110v)? Sounds like the shore power connection, might be worth changing the title for more/better traction. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Sat Jul 01, 2017 12:19 pm Post subject: Re: Aux battery short? |
pomfritz wrote: |
And then from there the wire goes to another outlet box inside the rear seat area and that is what the charger is connected to. |
The very short lived, but high inrush current of the charger is what will be causing the small spark. It's very common with switched-mode supplies. No need to worry about that. I suspect many here will have heard a similar spark when plugging in a laptop supply at home.
The male pins on the 120V inlet box could probably do with a clean-up - they basically live 'outside' so inevitably get some corrosion over time. An old-fashioned brass cleaning wad is probably the easiest method. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Mon Jul 03, 2017 6:16 pm Post subject: Re: Aux battery short? |
Thanks for that. I charged up the system with it plugged into shore power, it once again made that little spark but no smell or anything else wierd, no overheating of anything. I don't recall if doing that earlier and will keep an eye on it. _________________ 83.5 233K. GW 2.3, SS exhaust, My German Frau named her Stefi |
climber2377 Samba Member
Joined: November 20, 2013 Posts: 230 Location: northeast
Posted: Mon Jul 03, 2017 9:09 pm Post subject: Re: Aux battery short? |
If you unplug the charger from the outlet in the van when you plug the van in on the outside or you plug in the van side (female end of the extension cord first) the arc should either be nonexistent or it will have moved to the male side of the cord when you plug in to the outlet you are going to use. Best to keep any and all sparks away from the van. If you plug the charger into the outlet in van after the van is plugged into shore power, does the plug for the charger arc? Maybe the charger is going bad and drawing too many amps? Maybe it's normal, I'd just be cautious around any gases. _________________ [email protected] 84 Westy 1.9 waterboxer > 2001 Legacy 2.5L sohc w/ subarugears 5MT Ty754 |
