beetleman217 Samba Member
Posted: Fri Jun 30, 2017 10:07 pm Post subject: Turn signal won't cancel |
My turn signal works but does not cancel when returning the steering wheel. Even though the signal mech seems perfect, I swapped it for another and that didn't help. So if two turn signals don't work, it must be the cancellation ring on the steering wheel. But that seems to be intact as well with no signs of breakage or other flaws. So what could be the problem?
_________________ If all else fails, stop using all else
1977 Westfalia
1961 Beetle |
Posted: Sat Jul 01, 2017 12:09 am Post subject: Re: Turn signal won't cancel |
Buy a loud flasher. |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Sat Jul 01, 2017 5:56 am Post subject: Re: Turn signal won't cancel |
What's the clearance between your switch housing and your steering wheel?
Shouldn't be more than a few millimeters.
_________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
a-marshal Samba Member
Posted: Sat Jul 01, 2017 5:57 am Post subject: Re: Turn signal won't cancel |
the entire plastic pod that houses the signal and wiper arms can slide down the column, try sliding it back up. Don't know about other years but my 73 has two Philips screws that hold the pod together, one accessed from either side, slide pod up tighten screws problem gone.. _________________ -Ob. vehicle info....
1973 Westy w/ '74 1.8 liter / PDSI (type3?) carbs / 009 distributor / pertronix |
Tcash Samba Member
Posted: Sat Jul 01, 2017 8:57 am Post subject: Re: Turn signal won't cancel |
beetleman217 wrote: |
My turn signal works but does not cancel when returning the steering wheel. |
If they never cancelled. The cancel ring may have been put on wrong?
busdaddy Samba Member
Posted: Sat Jul 01, 2017 9:44 am Post subject: Re: Turn signal won't cancel |
How about a pic of your signal switch looking down into it when the wheel is off?, there's a few plastic parts and a spring that break often. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Jul 04, 2017 7:45 pm Post subject: Re: Turn signal won't cancel |
a-marshall's point was interesting- -perhaps the tang on the ring simply doesn't reach the white cancellation piece in the mech. So I took out the hex head screw that holds the entire unit in place and it did slide up, decreasing the gap. I then tightened it back and was sure my troubles were over, but unfortunately it still doesn't cancel.
Busdaddy - the mech is not the issue, I have two and they both are good with all the plastic bits that tend to break intact and the spring in place.
Bentley says to install the wheel with the tang to the left - but I don't see why. It should cancel in any position as the steering wheel is turned, shouldn't it? _________________ If all else fails, stop using all else
1977 Westfalia
1961 Beetle |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Tue Jul 04, 2017 10:14 pm Post subject: Re: Turn signal won't cancel |
Bentley says to install the wheel with the tang to the left - but I don't see why. It should cancel in any position as the steering wheel is turned, shouldn't it? |
"On the left" only applies up to 73 or 74 or whenever it was VW changed the mechanism design. Subsequently, I believe it goes on the right. And it
does matter, especially when you're just turning the wheel enough to make a normal turn _________________ '67 bug: seized by the authorities
Tcash Samba Member
Posted: Tue Jul 04, 2017 11:46 pm Post subject: Re: Turn signal won't cancel |
So you have the Turn signal Switch from ch. no. 2142 164 060 1974-79
Maybe the switch just needs a good cleaning? |
504 Samba Member
Joined: February 03, 2010 Posts: 136 Location: New Orleans
Posted: Sat Sep 14, 2019 10:00 am Post subject: Re: Turn signal won't cancel |
That spring that is shown on the photo in the last post popped off while I was backing out of my driveway. One of the plastic tabs that is hangs on broke off. The turn signals still work normally.
Do you think i can still drive it like this without any major issues? What does that retainer/spring do?
I'm heading out of town next week, hoping I can still drive the bus.
Thanks! |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
504 Samba Member
Posted: Sat Sep 14, 2019 11:59 am Post subject: Re: Turn signal won't cancel |
Thank you! I was hoping that was the case. They never did cancel anyway. |
Auggie West Samba Member
Posted: Sat Jun 13, 2020 6:49 pm Post subject: Re: Turn signal won't cancel |
Yay!
I just got mine cancelling thanks to this thread!
I won’t be the old guy driving miles down the road with my blinker on anymore!!!😁 _________________ Auggie
‘87 Vanaru Westy (Lola)
My new home!
Dual port 1600
'69 Westy (Pearl)
My former summer home, and has traveled to 31 states, mostly via the scenic route, so far... |
