lintbrush Samba Member
Joined: October 10, 2013 Posts: 269 Location: Campbell, California
Posted: Sat Jul 01, 2017 9:42 am Post subject: Oil leaking from transmission side of driveshaft? |
I woke up to about a 12" puddle of oil this morning. Upon inspection it looks like it's leaking from where the driveshaft meets the transmission. In this pic, I've cleaned off all the oil, but the arrow points to where it appeared the source was. Is there a seal behind this? I have to replace the boots anyways, but figured that housed grease in these IRS ends and replacing the boots wouldn't sole this oil leak. Thoughts?
_________________ 1970 Westfalia Campmobile - SF Bay Area
https://www.instagram.com/campishome/ |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jul 01, 2017 9:50 am Post subject: Re: Oil leaking from transmission side of driveshaft? |
A bit of seepage isn't a big deal so you don't have to act immediately, but do plan this in. You also need to replace at least that one cracking axle boot.
You might also consider doing the inner and outer rear wheel bearing seals at this point. |
Posted: Sat Jul 01, 2017 11:07 am Post subject: Re: Oil leaking from transmission side of driveshaft? |
Perfect! Thank you. I cleaned everything off and just returned from a 15 minute jaunt down the freeway so I can confirm the leak point. Of course nothing is leaking now, which makes me think I should check the hypoid level . Is this a job worth tackling without the specialized tools? I see some used makeshift PVC and other tools with various levels of success. _________________ 1970 Westfalia Campmobile - SF Bay Area
Posted: Sat Jul 01, 2017 12:26 pm Post subject: Re: Oil leaking from transmission side of driveshaft? |
About the only specialized tool you need is a tool to pop the seal out and a pair of duckbill snapring pliers. You can improvise if you want but a seal puller will save a lot of aggravation and doesn't cost much. Some pullers are pretty junky though so buy with care.
These seals can weep for years hurting little, as I suggested above you should consider doing other work at the same time that requires having the axle removed to do.
Posted: Tue Jul 11, 2017 5:29 pm Post subject: Re: Oil leaking from transmission side of driveshaft? |
A lot of heavy, gritty sediment, but seals don't look horrible so far. Waiting on parts, but here is where things are at:
Posted: Tue Jul 11, 2017 6:08 pm Post subject: Re: Oil leaking from transmission side of driveshaft? |
How does the outer edge (snout) of the drive flange look where the seal rides against it? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Jul 11, 2017 7:29 pm Post subject: Re: Oil leaking from transmission side of driveshaft? |
busdaddy wrote: |
How does the outer edge (snout) of the drive flange look where the seal rides against it? |
Smooth. The marks shown below cannot be felt.
Clearly leaking though. I haven't drained the fluid yet. I figured I didn't have to until I got to the inner seal. It only appears to be leaking from one side.
Posted: Tue Jul 11, 2017 7:34 pm Post subject: Re: Oil leaking from transmission side of driveshaft? |
lintbrush wrote: |
Smooth. The marks shown below cannot be felt. |
I was more interested in the side of that area. (you may want to clean it up first) _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Tue Jul 11, 2017 7:48 pm Post subject: Re: Oil leaking from transmission side of driveshaft? |
^^^^X2
make sure the sealing surface on the flange hasn't had a groove worn in it.
also, there is a big o-ring behind that diff nut that likes to bleed oil as well _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Tue Jul 11, 2017 8:36 pm Post subject: Re: Oil leaking from transmission side of driveshaft? |
Don't drain the fluid until both sides are complete. You want the fluid to flow out of the junction so debris has a harder time finding its way in. Once you've done all your work (both sides) then consider draining or topping off to complete the job.
Like the posters above say, your output flange sealing surface should be groove-less and shiny clean.
When reinstalling the circlip, make sure that it fully seats; no sense in having the flange pop off down the road somewhere.
www.airschooled.com |
Posted: Wed Jul 12, 2017 4:45 pm Post subject: Re: Oil leaking from transmission side of driveshaft? |
busdaddy wrote: |
lintbrush wrote: |
I was more interested in the side of that area. (you may want to clean it up first) |
Okay, here are pics of the snouts. The wear lines are faint and hard to feel.
Left:
Right:
Also, when I pulled the right drive flange out (I have them just placed in there just to keep them covered) I'm guessing this that I found on the ground is the thrust/spring ring? I haven't pulled the final seal out yet so wasn't expected to see this ring quite yet.
Posted: Wed Jul 12, 2017 5:27 pm Post subject: Re: Oil leaking from transmission side of driveshaft? |
The ring is responsible for the marks on the ends of the snouts so you can figure out where they came from by that.
While you await the new seals shine up the seal areas on those flanges with steel wool or super fine sand paper so they are like a mirror and smooth as a baby's ass. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Thu Jul 13, 2017 1:09 pm Post subject: Re: Oil leaking from transmission side of driveshaft? |
On my transmission the oil leaked because the bearing was a little loose and the splined shaft could move from side to side a little and let oil pass the seal at speed.
I suspect this was from when the transmission was reconditioned and it was not exactly set correctly.
I tightened the side plate maybe a millimetre of rotation and replaced the seals and it has not leaked since. _________________ Ancient vehicles and vessels
Posted: Fri Jul 14, 2017 10:40 am Post subject: Re: Oil leaking from transmission side of driveshaft? |
busdaddy wrote: |
While you await the new seals shine up the seal areas on those flanges with steel wool or super fine sand paper so they are like a mirror and smooth as a baby's ass. |
Duh, that was easy...
I didn't see it mentioned anyplace, but based on the snout wear marks and the matching marks on the washer it appears the narrower side of the washer faces the transmission?
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Fri Jul 14, 2017 3:34 pm Post subject: Re: Oil leaking from transmission side of driveshaft? |
lintbrush wrote: |
I didn't see it mentioned anyplace, but based on the snout wear marks and the matching marks on the washer it appears the narrower side of the washer faces the transmission? |
That ring is called "thrust ring" in Type 2 Bentley manual, "spacer ring" in Type 1 manual. It's shown in Type 2 manual, but no mention of correct orientation.
Type 1 manual specifies that flat side goes toward CVJ flange, and rounded (narrower side, as you put it) side towards differential. _________________ '67 bug: seized by the authorities
Posted: Mon Jul 17, 2017 11:37 am Post subject: Re: Oil leaking from transmission side of driveshaft? |
Finished. Not the funnest, cleanest or exciting project. Hardest part was getting the seal to seat. I used the 46mm socket and mallet, but realized after I was done I could have put a bolt/washer/nut thru it and used it as a press.
For the benefit of others tackling this in the future, here are a few photos...
The seals are definitely taller than the originals by ~7mm:
New seal in:
New sidescrew lock/coverplate:
Cleaned up the drive flange :
Final drive seal...done.
Tcash Samba Member
Posted: Mon Jul 17, 2017 12:49 pm Post subject: Re: Oil leaking from transmission side of driveshaft? |
For the future
