Oil leak woes
hepmeheme
hepmeheme is offline
PostPosted: Sat Jul 01, 2017 11:30 am    Post subject: Oil leak woes Reply with quote
Been losing a lot of oil lately in my 73 bay window bus. About a quart a week. It seems to be only when the engine is running because I've watched for a while while parked and I don't see anything dripping. Here is a photo of the bottom of the engine. There are weep areas that don't drip but that look like that's where the leak was coming from perhaps. Do you guys have any recommendations or tips on how to diagnose this and fix it? Am I due for an engine rebuild? Thank you.
busdaddy
busdaddy is online now
PostPosted: Sat Jul 01, 2017 11:45 am    Post subject: Re: Oil leak woes Reply with quote
Step 1 is a can of this and a trip to the local DIY car wash (bring a bag to put over the distributor):
Then when it's clean locate the source of the oil, most likely places are the oil pressure sender, dipstick boot or the fan hub seal.
Wildthings
Wildthings is offline
PostPosted: Sat Jul 01, 2017 12:36 pm    Post subject: Re: Oil leak woes Reply with quote
How much oil are you getting on the ground? A quart a week of leakage would leave puddles of oil any and everywhere you parked. I am guessing you may have a blowby/crankcase ventilation problem that is causing the engine to both burn and leak a high amount of oil.
hepmeheme
PostPosted: Sat Jul 01, 2017 12:51 pm    Post subject: Re: Oil leak woes Reply with quote
There are definitely some spots and drip areas under the car. But I think it only drips when I first park and then stops after a while. I've been reading up and based on where I see the oil I think it's the fan hub seal. Worth a shot to replace it. The area around the dipstick also looks like it's leaking.
Wildthings
PostPosted: Sat Jul 01, 2017 2:44 pm    Post subject: Re: Oil leak woes Reply with quote
A dipstick leak is a sure sign of over pressurization of the crankcase, check that your breather is routed correctly and that every part of the system is functioning/open. If you don't have the original carbs anymore, or even not just the original air cleaner then there is a good chance you breather is not hooked up correctly.
The oil pressure switch is one of the likeliest places for a straight out leak to occur. Oil will show up everywhere when the OPS leaks.
busdaddy
PostPosted: Sat Jul 01, 2017 3:00 pm    Post subject: Re: Oil leak woes Reply with quote
The dipstick tube could also be wet from a fan hub seal throwing oil on it where it passes through the shroud and the cooling air pushes it out, clean it up and look at all the suspect areas really closely for the first hour of driving/running.
SamboSamba22
SamboSamba22 is offline
PostPosted: Sat Jul 01, 2017 4:26 pm    Post subject: Re: Oil leak woes Reply with quote
Iím chiming in with a fan hub seal leak, Iím dealing with the very same issue, with oil leaking in the exact same spots.
Prior to replacing the oil pressure sending unit, the leaks were worse, you would not believe how bad that little thing can leak!
My leak isnít horrible, just enough to keep things wet, nothing concerning as of yet, thank goodness.
FWIW, my oil cooler, adapter, and oil filter as nice and dry.
Invention is the tool of the adventurer - Jacques Cousteau
Sinning led me to become a saint, which I then learned I wasn't qualified. -Samuel Heath Belcher
2017 Golf GTI
1974 Brilliant Orange Westfalia Deluxe
1965 Ruby Red Standard Beetle - SOLD
1959 Dove Blue Single Cab
ISO Rebuild kit APG Fuel Pump (Type 4/72-74
Bus)
hazetguy
hazetguy is offline
PostPosted: Sat Jul 01, 2017 4:39 pm    Post subject: Re: Oil leak woes Reply with quote
check the condition of the dipstick boot between the housing and the filler pipe.
Seems like this repair is always being discussed and cursed, due to the cramped space the boot sets in. I found that removing the lower tin between the case and heater box provides much more access to that area, and made the job much easier and much faster. I was able to stick my hand in there easily and slide the boot on very easily. Entire job, including removing and installing tin took less than 15 minutes.
Great, someone put hose clamps on this one.
This is the tapered end where the boot fits, on the oil filler pipe where it attaches to the engine case. Shown with boot in proper installation orientation.
This is the 8mm o.d. pipe that sticks through the fan housing, shown sticking out of the housing, where the boot attaches.
Your crystal ball ain't so crystal clear
Parts and mechanical restoration services available. I restore and rebuild fuel pumps, distributors, spindles, etc.
Check my ads or send a PM.
lil-jinx Premium Member
lil-jinx is offline
PostPosted: Sat Jul 01, 2017 4:42 pm    Post subject: Re: Oil leak woes Reply with quote
Clean it and check it, when you get it clean run it for a minute shut it down and start looking around the bottom,when you see oil follow it up to the source.when you think you have located it give it a shot with the engine cleaner,run the engine and double check the leak.
1968 Dune Buggy
1974 parts bus
hepmeheme
PostPosted: Sat Jul 01, 2017 8:17 pm    Post subject: Re: Oil leak woes Reply with quote
Thanks everyone. I appreciate all of the advice. I'll let you know how it goes. Hopefully this bus will stop being a source of (as much) stress soon.
hazetguy
hazetguy is offline
PostPosted: Fri Jul 14, 2017 7:13 am    Post subject: Re: Oil leak woes Reply with quote
soooo, any update as to what the leak was/is?
airkooledchris
airkooledchris is offline
PostPosted: Fri Jul 14, 2017 9:14 am    Post subject: Re: Oil leak woes Reply with quote
If you want to get more of a definitive answer, do the UV light and dye test.
I had an oil leak originating from a case bolt and the oil filter mount, which when dripping down would make it look like it was coming from all sorts of other wrong locations.
Clean everything, dye the oil, run it until it's warm and back it into your garage. turn on the UV light and watch for where it's dripping down from. Even a slight weeping will be obvious with the light.
1979 CA Transporter
Join the IAC Facebook group here!
hepmeheme
PostPosted: Fri Jul 14, 2017 7:20 pm    Post subject: Re: Oil leak woes Reply with quote
The fan hub seal was definitely leaving. Has rot see if there are more. What dye do you use for the oil?
hepmeheme
Leaking
old DKP driver
old DKP driver is offline
PostPosted: Fri Jul 14, 2017 8:41 pm    Post subject: Re: Oil leak woes Reply with quote
Pull the old seal out.Replace it and put oil on the seal / Hub
surface and torque to Bentley spec.
Do you own the Bentley repair Manual so you have the torque spec's ?
You really need:
OIL SEAL...and oRING
V.W.owner since 1967
hepmeheme
PostPosted: Sat Jul 15, 2017 4:44 am    Post subject: Re: Oil leak woes Reply with quote
Thank you. Yes, I've got Bentley. Let's see if Oreilly will lend me a harmonic puller.
SamboSamba22
PostPosted: Sat Jul 15, 2017 6:42 am    Post subject: Re: Oil leak woes Reply with quote
Let us know how it goes, Iím currently trying to track down my remnants of my rebuild gasket kit to locate the O ring, seal came in yesterday, so looks like Iíll be doing this soon myself.
Hoping that with a harmonic puller, all i have to do is remove the center cooling tin, the fan out, and do a little switcharoo.
Good luck.
2017 Golf GTI
Bus)
Tcash
Tcash is offline
PostPosted: Sat Jul 15, 2017 8:49 am    Post subject: Re: Oil leak woes Reply with quote
hepmeheme
PostPosted: Sun Jul 16, 2017 8:29 pm    Post subject: Re: Oil leak woes Reply with quote
Well still leaking after replacing that seal. I got out the big guns and took a video. I guess I'm not good at searching. I looked through the entire Engine Section of the Bentley manual and I cannot find what this cover is called. It's not the oil strainer. It's towards the back. That's where it's coming from. There might be more leaks but this is definitely a major one of them.
https://www.youtube.com/watch?v=k_Lqg_6O4UY
Xevin Premium Member
Xevin is offline
PostPosted: Sun Jul 16, 2017 8:41 pm    Post subject: Re: Oil leak woes Reply with quote
Damn that guy taking the video can run fast Shocked I'm of no help. But seriously cool video. Hope you get it sorted out. What a PITA.
Keep on Busin'
Clatter wrote:
sunnydog wrote:
(This probably is Xevin's new signature line quote: Sunnydog said:"just the tip...")
Abscate wrote:
I dont hate anyone on the Samba - except for Xevin - who brought me cold coffee in the morning.
[email protected] wrote:
