The Baja whit no name
Page: Previous  1, 2, 3
Enmiguel
Enmiguel is offline
PostPosted: Sat Apr 07, 2018 8:56 pm    Post subject: Re: The Baja whit no name Reply with quote
Today finally after a long time I made the bases to the gearbox, use springs of toyota crossbows (I do not know if the translation is fine as well). Use a tube which you cut to give you the measure:
The base of the tail uses a 4mm sheet, it is the same thickness as the original:
And attached to the chassis use a 6mm:
Back I copied Smileyman3000 with the bases, from the beginning I liked that idea and applied it, so:
It remains only to mount motor to see how it is going, but it did not have the screws, so it will be for another day.
View user's profile Send private message Visit poster's website Twitter Instagram Gallery Classifieds Feedback
Enmiguel
Enmiguel is offline
PostPosted: Fri Apr 20, 2018 2:29 pm    Post subject: Re: The Baja whit no name Reply with quote
Well, let's continue. Mount the engine and I was looking at where to put the water radiator:
But I did not like it at all, so I decided to put it forward:
It's from a Focus, it should be enough for the engine I'm riding.
I also did what will be the protector of the motor, it is necessary to make the detachable parts to be able to remove it, but something like this will remain:
Then I went to the front train, my friend made me the hubs of the front train, they are made of a material called 12L14, it is high in lead, they recommended that for being much cheaper than the bronze, since here the original hubs are not available
I did more for my friend and for my buggy too.
After installing the bushings, install the front axle:
My friend spiked the front drums and did the other centering forwards:
I put them as a moso to be able to adapt brake discs afterwards, it's something I already did in some buggies of several clients.
Here was where the thing was half complicated: going from 4 to 5 holes one of them was in the middle, I had to weld, to do so the piece was steel and the wick did not happen, we played a trick (thanks to San Google) heat the piece red hot and put it in lime powder:
And well, I could finish that:
And so it goes until now:
It will be the other week that I do something, this week I had a lot of free time for lack of spare parts (this routine starts to be done here).
And in the end, a super 3D sketch in Photoshop of how I want to paint it, I did a purple pearl test in the buggy and I fell in love with how it looks:
It changes as the angle of view of the car moves. So I already have a name for him:
The Chameleon. (At last).
dustymojave
dustymojave is offline
PostPosted: Sun Apr 22, 2018 12:14 pm    Post subject: Re: The Baja whit no name Reply with quote
No encantame tanto los colores, pero me gusta el nombre!
Richard
SoCalBajas Member
Enmiguel
Enmiguel is offline
PostPosted: Fri May 18, 2018 12:25 pm    Post subject: Re: The Baja whit no name Reply with quote
These last week I did several things to him, only that he wanted to publish them all together.
I had to move the steering box because it was not aligned with the wheels:
I made the front bumper with the pen (so we say here):
I need to make the bases of all the lights, I hope to do them soon.
Pass the cooling water tubes from the front to the front:
The radiator is from a Ford Focus 2000cc, change it to a friend in exchange for repairing the gearbox of your buggy.
I made the tank, grab around 80 liters (it would be about 21 gallons according to san google):
It has this trap below that is where the gas pump always submerged, I need to make the connections above, reinforce the body, make the bases and of course weld it.
I'm trying to see if I can install these seats, they are the same as I have in my buggy:
I made the stirrups to be able to mount, only the inside stuffing is missing:
And adapt the steering wheel of a Toyota Corolla:
Of course I will change the steering wheel, the rest is for the controls, suichera and others.
I'm putting everything on the site first to last solder everything, first for now I do not have many electrodes (and they are so expensive something so basic) and because if I have to do something, I do not have to cut so much.
Enmiguel
Enmiguel is offline
PostPosted: Fri May 18, 2018 12:27 pm    Post subject: Re: The Baja whit no name Reply with quote
If I'm honest I'm not convinced of the colors, but hey, the papers say those colors but I can change them in the future ($$$) and possibly have to make changes to the papers for something I want to change. (This is in see).
dustymojave
PostPosted: Fri May 18, 2018 7:38 pm    Post subject: Re: The Baja whit no name Reply with quote
La cosa importante de los colores, es que esta' encantado USTED.
Richard
SoCalBajas Member
Enmiguel
Enmiguel is offline
PostPosted: Fri Sep 07, 2018 6:24 pm    Post subject: Re: The Baja whit no name Reply with quote
Well, I spend some time since I did something to the car, it is difficult given the situation of the country, every day is a new price and so, but here we go. Apart from this, "cuadritoos" (my Buggy) was sick:
There was a bricklayer inside the engine Laughing
Things that when I put it together I do not fit because of problems with the grinding machine and so on.
There were several changes since the last time I wrote, first the engine:
I got one from Corolla 1.8 (one 7afe, the one from cuadritos is 4afe) so I have relatively the same engines in both cars.
Of course I had to redo the adapter:
A part of this in the long run would be better for me, I know it is a smaller engine than the one I had but so do not damage the gearbox knowing me.
For those who do not know, this is cuadritoos:
And here the other change. I am currently repairing a buggy with an engine equal to the one I had (cavalier) and it is green (people confuse it with mine as if they were so equal) and all the remaining paint I have been using to decide on the color:
So it will be equal to cuadritoos or different, so I painted it on the other side of another color that I had wanted to use for a long time and so it is:
And sincerely I liked more so the green, (I agreed with dustymojave that I did not like the previous color) until I made a small survey about that and most (14) preferred the purple to green (3), that at the end is my decision how to paint it but I like it more.
Now and for the last time (please and thank you) will be violet and black, aka "Dino" for The Flintstones.
I hope already in the next few weeks to continue doing things like this little by little and start the engine, since this is all complete and I have everything to turn it on.
pullstart
pullstart is offline
PostPosted: Sat Sep 08, 2018 5:39 am    Post subject: Re: The Baja whit no name Reply with quote
Great work!
4 seater Appletree buggy, road legal with 002 IRS, 3x3 Appletree kit, 6" over Dan's beam with 10" towers and Fox 2.0 shocks, '00 Subaru EJ25 with KEP stage 3 clutch and KEP adapter plate.
my build page: https://www.thesamba.com/vw/forum/viewtopic.php?t=662104&start=0
Enmiguel
Enmiguel is offline
PostPosted: Sat Sep 08, 2018 7:41 am    Post subject: Re: The Baja whit no name Reply with quote
pullstart wrote:
Great work!
Thanks bro!
Enmiguel
Enmiguel is offline
PostPosted: Wed Oct 03, 2018 7:01 pm    Post subject: Re: The Baja whit no name Reply with quote
This week after taking a walk:
I made the protector for the motor:
Now I have to correct the engine adapter because the engine is a bit on the side, I could leave it like this but the mania that everything is perfect is another thing.
And since we are in the country to change things, well, change the Cavalier engine for all this:
So I do not need almost anything to have also air conditioning, additional I got the alternator (which then uploaded the photos) and other things that I forgot to take photos.
plotch
plotch is offline
PostPosted: Thu Oct 04, 2018 5:37 pm    Post subject: Re: The Baja whit no name Reply with quote
Sweeeet, Dude!!!!!!
heywebonya
heywebonya is offline
PostPosted: Fri Oct 05, 2018 4:15 am    Post subject: Re: The Baja whit no name Reply with quote
Great build and demonstrates that necessity is the mother of invention. Well done.
If I knew what I was doing; I wouldn't be building a buggy!
Enmiguel
Enmiguel is offline
PostPosted: Fri Dec 14, 2018 8:12 pm    Post subject: Re: The Baja whit no name Reply with quote
Well, for work reasons and others I had to take my car to my house, and that was the ride:
Well, this is the alternator that I had commented:
And this is a gift, it's from a Defender:
Totally aluminum, which here is like a luxury.
I've been repairing a buggy which I put a front Kombi train and well, I fell in love and got one:
It's dirty, but all the components are perfect (except for 2 stubs that I have to buy) but it came out better, it has its rolineras, the brake discs, the amotiguadores, something that the other one did not have and the most important thing: to be I should be able to handle much more, which is what I want since I want to travel far with that car. Of course I have to do a job (later I'll teach) so it's not so rigid.
And after a long time I was finally able to buy 2 new rubbers in my life:
They are 31.5 * 10.5R15, I did not want to put a bigger one for 1: price, 2: then the car does not walk and 3: I did not get 32, the closest was 35.
And the last thanks to my girlfriend, the steering wheel with its adapter and others:
Which I love more than the account now with this hahaha.
I also took advantage and made the papers for the change of engine and color.
I hope and the week of 24 can finally do much, and grab "vacation", and buy cutting disks, to clean, I have electrodes and argon for mig, although there is always something missing I hope to advance a lot these days, I will continue reporting.
Enmiguel
Enmiguel is offline
PostPosted: Wed Jan 23, 2019 6:29 pm    Post subject: Re: The Baja whit no name Reply with quote
New year, new goals.
I hope this year to finally finish what I started, have been days of annoyance and others to want to finish it, I sincerely like how it is, it looks like what you do in the USA, the opposite of what most do here that are all ugly.
For starters, I had to disarm everything I did in the back, things to do it stuck to a wall and not see from afar, it was all crooked:
Take advantage and I made the new holes to the motor adapter, now if it is not on the side, it is right:
And then take out and start welding:
I made the base of the engine so easy, as I had done in another buggy and it worked, why not make it the same without complications ?:
Also take advantage and disarm the engine from below, I made it clean, check that everything was fine and I grab the paint to make it more beautiful:
I returned to melt aluminum:
What I did was disarm where the steering wheel goes and make the adapter directly, then to the winch:
Use part of the old adapter, just that I made new threads:
All aluminum is recycled to remelter:
While here the sunsets are like this:
And so I am:
I thought of a cheap way to lock the whole engine so they can not touch it and it occurred to me to disassemble an air filter from a truck:
And so it is staying:
I also made the gas tank:
I had to make the cut for the body of acceleration, I insist is the most annoying that I could weld Neutral
And I made a threaded base to put the gas pump, and the floating for the gasoline clock, apart from the filling and the vent:
And I took it out for a spin and that's how beautiful it is:
Only that by not seeing the sides there is a tube that is higher than the other:
So I have to correct.
I deign to ride big rubber forward because it looks more beautiful and good, since it is fine I prefer to spend that one.
I am doing the adaptation of the wheels with the apples of the front train and for that reason I have not been able to mount the front train, when I do that I will publish more.
Buggeee
Buggeee is offline
PostPosted: Sat Feb 02, 2019 9:14 am    Post subject: Re: The Baja whit no name Reply with quote
The mountains are beautiful. The buggy is strong. You are amazing! Applause
1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote:
Every setback is an opportunity to learn stuff and to buy new tools.
rodeking
rodeking is offline
PostPosted: Sat Feb 02, 2019 10:31 am    Post subject: Re: The Baja whit no name Reply with quote
Wow, unbelievable what you can fix under the conditions! If only the politicians can do the same..
Enmiguel
Enmiguel is offline
PostPosted: Wed May 08, 2019 5:36 pm    Post subject: Re: The Baja whit no name Reply with quote
I wanted to cover the holes in the wheels to make new ones and keep the original apple, so I melted aluminum:
And I emptied him in each hole:
After that tournament:
It did not help, so centering for the Kombi front train was made:
I lost time in that for the fact of riding the front of Kombi, the next will be an iron adapter, not to give birth.
So I left the front train mounted, they lent me 2 wheels and with that I got the height:
Take advantage of and modify the address box, which I learned with a buggy that assembled in December, the box can not be straight, the pins have to be tilted if it does not work.
And so, even the radiator fits perfectly:
I need to finish welding and ready around.
I got the hood, I hope I do not screw it again, I'll leave something original there, I want to install the bib ... Since it's that high I do not think it will hit and it will still have its protector.
And so it goes:
I hope soon that latoneen and so.
Enmiguel
Enmiguel is offline
PostPosted: Fri Nov 01, 2019 7:19 pm    Post subject: Re: The Baja whit no name Reply with quote
And after so much giving birth and fighting, this:
[img]https://1.bp.blogspot.com/-N0sAx9ERab8/Xbzk1lGVaLI/AAAAAAAAK4k/xzCONGyvpzMf20J03eIfiUt7gxfNFPYHwCPcBGAYYCw/s640/IMG_20191031_090426809.jpg
[/img]
There one of the reasons, rot, rust, wasted spending a lot of money, not counting the shit that had already been done ... And as I always told everyone, I did not feel excited or encouraged to finish that.
And no, I do not like to leave the things I do halfway, but sometimes the reality is better, with what I had to spend I still bought a rolling car, not counting that with all that so rusty it is not worth it. It's not that I don't like the idea, but I also didn't want to do something that wouldn't fit as I wanted.
So it looks like this:
So all the mechanics and everything I had is going to stop the buggy. And yes, this year I finish it yes or yes.
liquidrush
liquidrush is offline
PostPosted: Sat Nov 02, 2019 9:08 am    Post subject: Re: The Baja whit no name Reply with quote
Talk about roughing it...I'm sure you hate the state of the country but being able to get around some of that must be quite gratifying. Keep up the great work!
Page 3 of 3
