Alternate carb options on air cooled 911
motomorrelli
motomorrelli is offline
PostPosted: Mon Jul 03, 2017 10:04 am    Post subject: Alternate carb options on air cooled 911 Reply with quote
Have read many forums regarding non traditional / experimental carb set ups. Most just fizzle out with no results. I am looking for a performance carb option for a 2.7 powered kit car I am rebuilding. Last car I built is an mg midget that among many other mods I installed & tuned a set of 4 34mm Keihin side draft carbs (motorcycle) to fuel injection quality. Given the engine configuration it would seem to be far more difficult on a flat 6, linkage etc. Other options, (don't want to spend the $ on webers or pmo)
Single 4 barrel on custom intake? 3 double carb units from a large V6 outboard? Other ideas are welcome
BK911
BK911 is offline
PostPosted: Thu Aug 10, 2017 12:18 pm    Post subject: Re: Alternate carb options on air cooled 911 Reply with quote
Zenith carbs originally came on the 2.2Ts and are relatively cheap.
Parts are finally available to set them up for other engines up to a 3.0.
'72 914 1.7
'74 Standard Bug 1600
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Aug 10, 2017 12:23 pm    Post subject: Re: Alternate carb options on air cooled 911 Reply with quote
PORSCHE = $$$$
Get the PMO, you'll cry only once. Then enjoy many miles of driving.
Glenn
Member #1009
#BlueSquare
Jacks
Jacks is offline
PostPosted: Sun Aug 13, 2017 12:23 am    Post subject: Re: Alternate carb options on air cooled 911 Reply with quote
http://forums.pelicanparts.com/porsche-911-technical-forum/309860-4-barrel-intake.html
Jack Staggs
Actual name
motomorrelli
PostPosted: Sun Aug 13, 2017 9:43 am    Post subject: Re: Alternate carb options on air cooled 911 Reply with quote
I've seen that, even spoke to the 4 barrel guru himself. He doesn't recommend it on a street car. I am considering the triple jet ski carbs. Polaris 750 has a setup that should work nicely.
Starbucket
Starbucket is offline
PostPosted: Mon Aug 14, 2017 12:53 pm    Post subject: Re: Alternate carb options on air cooled 911 Reply with quote
750 carbs will be way too small it will run like a 67 VW. The 4 barrel manifold will work great with a Holly 450 dbl. pumper. You will need to plumb your oil lines through those fittings as the plentum needs heat to vaporize the gas or it will stumble and die when cold and never run right.
motomorrelli
PostPosted: Mon Aug 14, 2017 1:10 pm    Post subject: Re: Alternate carb options on air cooled 911 Reply with quote
750 x 2 = 1500 x 2 (2 stroke) = 3.0 liter Two Strokes taken twice as much air as a 4-stroke. Bottom line is the size of the Venturi all else can be worked with
