Zeitgeist 13 Samba Member
Posted: Sun Oct 08, 2017 10:14 am Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Thanks so much for these informative pics. Is that sunroof standard on the CV model tops? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
spou-unit Samba Member
Joined: November 16, 2015 Posts: 68 Location: Newfoundland, Canada
Posted: Sun Oct 08, 2017 11:28 am Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Sunroof was installed by previous owner. |
Posted: Mon Oct 09, 2017 1:34 pm Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Got the carpet and subfloor up
IdeaNerd Samba Member
Joined: May 24, 2016 Posts: 598 Location: Central California
Posted: Tue Oct 10, 2017 9:54 am Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
+1 re: thanks for posting the pics. Very interesting and informative! Please keep them coming. |
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Tue Oct 10, 2017 6:53 pm Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Seeing all of the rot in the rear floors and the rear side walls I think you have made a very wise decision to strip it for parts. |
Gruppe B Samba Member
Posted: Thu Oct 12, 2017 5:26 am Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Use heat to remove the aluminum seat rail tracks. They are stuck down using a polyurethane type adhesive. If you use heat and a scraper they will pop right off.
Not sure what adhesive to use to reattach. I am looking at this too with my CV interior.... |
Posted: Sun Oct 29, 2017 3:23 pm Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Managed to get the seat rails strip up. Used a MAP gas torch and an olfa knife and got er.
Posted: Sun Oct 29, 2017 6:27 pm Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Are you going to install the Eberspacher underfloor gas heater to the new Van? |
Posted: Thu Aug 09, 2018 3:19 pm Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Hey all. Been a while since posting. Haven’t had time for any work.
Finally got around to placing the seat rails and testing carpet fit.
I took measurements from old van and lined up rails in new van. Then drilled a couple of holes for locating rails, screwed down and checked carpet fit.
Now to remove, clean and glue in place.
Still have to drill some holes and put in riv-nuts before I can glue carpet.
And also need to do something about the heater core which will be covered by the carpet when it’s laid in place.
Euro1 Samba Member
Posted: Fri Aug 10, 2018 11:46 pm Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Great work! I sent you a pm! |
Posted: Sun May 05, 2019 12:03 pm Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Ok it’s been a while. I urethaned the seat rails down today. It’s a start!
The seat fits!
Posted: Wed May 08, 2019 3:12 pm Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Ok so I hauled out the rear wiring harness from the red westfalia.
This connects to some connectors that come out of the pillar by the drivers sunshade.
This is for a number of things, from the cooler box to the display overhead of driver, water pump, yada yada
Posted: Wed May 08, 2019 7:11 pm Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Thanks for the updates!
I need to do the same install for my Eurovan CV rear bench.
Does your Westfalia have the underfloor eberspacher heater and if so are you going to install in the new van?
Cheers
Gruppe B |
Posted: Mon May 13, 2019 4:22 am Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
I got some tires switched onto the rims.
Posted: Mon May 13, 2019 1:43 pm Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Now just gotta get the two front tires switched over.
Posted: Mon May 13, 2019 4:15 pm Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Glad to see the updates! Please keep them coming. : ) |
Posted: Thu May 16, 2019 10:26 am Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Added some pics of what it’s like underneath. Compared to “Old Red”, she’s a dream. Gotta get under and give her a scrape and hit with rust converter.
Posted: Sat Jul 13, 2019 9:15 pm Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
Front bumper installed and rear wiring harness mostly installed.
murso74 Samba Member
Posted: Sun Jul 14, 2019 8:32 am Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
so were there campervans that were SWB outside of the US? |
Posted: Sun Jul 14, 2019 5:32 pm Post subject: Re: 93 Eurovan CL to Westfalia CV Conversion |
murso74 wrote: |
Yes, Canada could purchase the Eurovan CV Westfalia (full camper) from 1992-1995. Canada could also purchase LWB passenger van that sat up to 11 people and a diesel transporter panel in either SWB or LWB. |
