ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Mon Jul 10, 2017 5:03 pm Post subject: Re: I don't even know where to start anymore |
Welcome to the "I'd like to push my '78 Convertible off a cliff Club"
I can't tell you how many times in the 20 years I've owned mine, it has defied being fixed.
Take a little time off & when the weather cools take another look at it.
Get you some DEVES Piston Rings, 85.5mm Bore, but be sure to get the correct thickness rings, so measure the ones you got first.
Also while you got the legal smog cert apply for historical plates.
I hear if you have historical plates you don't have to get smog anymore. _________________ Good Luck
Al |
KKiley Samba Member
Joined: March 08, 2016 Posts: 662 Location: Aruba, Jamica, nope, Kokomo
Posted: Mon Jul 10, 2017 9:19 pm Post subject: Re: I don't even know where to start anymore |
I get it about buying the wrong parts. I have also thrown away brand new parts that were junk and not worth returning.
I just look at it that if I don't fix it 2 or 3 times something is not right. I am just looking to get it running for more than a few days so I can get the bodywork done, get a new top installed. Once that is done, it runs and looks good, this car is gone. 1 1/2 years later, it's time to admit that this car and I are not a good fit. For being a simple car, it is truly the most frustrating vehicle I have ever messed with.
Kevin _________________ 1978 Super Beetle convertible
Click to view image |
KKiley Samba Member
Posted: Wed Jul 19, 2017 7:20 pm Post subject: Re: I don't even know where to start anymore |
Ok, back from vacation, time to get this car running again. I actually have a registration and title on the way for this car. That only took 1 1/2 years.
It will start, but not keep running under 2,500 rpm. I did pull the injectors and powered up the fuel pump and verified the injectors are not leaking.The fuel pump just doesn't sound right to me, so I am going to get a fuel pressure gauge tomorrow and see what is going on.
Before this happened, the plugs looked fine. How long would it take to get them to look like they did when I pulled them?
Any other suggestions would be appreciated. I am done ranting and will fix my issues. I am going to re-ring the pistons one more time. I should have just measured everything and re-ringed it in the 1st place, if the pistons and cylinders were in spec. But I thought I'd just replace and move on.
Thanks
KKiley Samba Member
Posted: Fri Jul 21, 2017 3:10 pm Post subject: Re: I don't even know where to start anymore |
Here is what I have done today:
Fuel pressure checked: 28-30 psi while running. Holding pressure for at least 30 minutes
New plugs. Set points. It would start when giving it throttle and run at higher rpm's, then it would act like it has a major vacuum leak and want to die below 2,000 rpm.
Then the high speed idle issue returned. It was running at at least 3,500 rpm on its own, I was playing with the throttle cable and verified it was completely returned. It was screaming in the garage, then it started pouring out smoke again. I had to shut it down before it blew itself up.
I don't know if it's because the dual relay is bypassed and feeding the ecu directly, but that shouldn't do it.
It acts like the biggest vacuum leak ever when it's not running 3,500 rpm. But I have checked, sprayed every seal on it. I have no broken lines that I can find.
I am at a loss as to what to try next.
KKiley Samba Member
Posted: Fri Jul 21, 2017 3:19 pm Post subject: Re: I don't even know where to start anymore |
One thing I know, these rings are junk and the engine will need to come back out and have those replaced.
At this point, the car is undrivable. I hate to bail on the fuel injection, but I don't know where else to look. I just can't figure out what would cause it to idle at 3,500 rpm on its own with no throttle hooked up. For some reason the FI is just pouring gas into the engine while it's running. It bogs horribly, then decides to run WFO.
And to think, it was actually a decent running car at one point in time...
Click to view image
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Fri Jul 21, 2017 3:23 pm Post subject: Re: I don't even know where to start anymore |
Is the Auxiliary Air Valve stuck open?
Easy check is to remove both hoses and look inside. Cold it should be open. Hot it should be closed. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
busdaddy Samba Member
Posted: Fri Jul 21, 2017 4:03 pm Post subject: Re: I don't even know where to start anymore |
KKiley wrote: |
Then the high speed idle issue returned. It was running at at least 3,500 rpm on its own, I was playing with the throttle cable and verified it was completely returned. It was screaming in the garage, then it started pouring out smoke again. I had to shut it down before it blew itself up. |
I wonder what would happen if the nut down inside the plenum that holds it to the case came off and it somehow started leaking?, a large vacuum leak pulling from the crankcase? where there's splashed oil too?, hmmm... _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KKiley Samba Member
Posted: Fri Jul 21, 2017 6:20 pm Post subject: Re: I don't even know where to start anymore |
busdaddy wrote: |
I wonder what would happen if the nut down inside the plenum that holds it to the case came off and it somehow started leaking?, a large vacuum leak pulling from the crankcase? where there's splashed oil too?, hmmm... |
Actually, that is what happened when Robbie was here. When I pulled the engine out to replace the pistons and rings, I found the nut inside the head. It was quite rounded off, lol. But it ran ok, but did have a leak. When I put it back together, I put blue locktite on that nut.
And the AAR is stuck open. I took it off and hit it with some carb cleaner and got it moving freely and put it back on.
At this point that really isn't the main issue, as I just started it and it is blowing blue smoke to fog the whole neighborhood. If we had mosquito's, they would all be dead now. Hopefully the vacuum issue will be found with the engine out again.
I do appreciate all the help and I do look forward to the car at least running again.
KKiley Samba Member
Posted: Fri Jul 21, 2017 7:00 pm Post subject: Re: I don't even know where to start anymore |
And I am so bummed to see that Grant rings are $23.75 a set. All this could have been avoided for such little money. But the links that I saw warning about the AA rings were from about 3 years ago, so I was hoping they had addressed that issue.
Guess not...
KKiley Samba Member
Posted: Tue Jul 25, 2017 8:19 pm Post subject: Re: I don't even know where to start anymore |
Well, time to pull the engine again and fix any issues I can find. I have been trading emails with Jonathon at AA Performance about the ring issue. I have tried to be nice, haven't ripped him a new one, and communication has stopped. The funny thing is they haven't even offered to sell me another set of rings, let alone offer a discount. Time to order up the Grant rings, just not from them.
I am over being mad at the car, lol. time to move on and fix this issue. I just hope the rings are the issue why it will not run under 2,500 rpm.
The good news is, since I quit smoking, my son ordered me the replacement ash tray/ cup holder. Since I have blue tooth in the car, the stereo is the best feature at this point, lol.
KKiley Samba Member
Posted: Tue Jul 25, 2017 8:41 pm Post subject: Re: I don't even know where to start anymore |
And I think the AAR valve is part of the issue. It is open and I need to figure out how to adjust it. The nut allows it to moved back and forth, determining how much it opens.
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Wed Jul 26, 2017 5:47 am Post subject: Re: I don't even know where to start anymore |
Do you have these FI manuals?
https://www.thesamba.com/vw/archives/manuals/afc_f...r_1974.pdf
https://www.thesamba.com/vw/archives/manuals/afc_f...Manual.pdf
I should be one to talk because I have my own FI issues on my bus that I am terrified to tear into, but i have these printed out in a 3 ring binder and have read through them for the most part.
The multi-meter will be the tool of choice for testing and troubleshooting.
The FI on these old VWs is dead simple compared to modern ones but that makes it no less daunting. There are simply many more points of failure than a carb engine, the parts aren't readily available and rebuilding or jury-rigging stuff just isn't possible for the shade tree mechanic.
I don't think re-ringing is going to solve your idle issue, but it will solve the smoke issue hopefully.
The FI is going to need careful attention. The AFM could be stuck or sticking, as well as the throttle plate in the throttle body. I have a spare for my bus that is completely frozen. You can open up and adjust the AFM, there is a good thread in the baywindow forum on it.
We're pulling for you man.... _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
KKiley Samba Member
Posted: Wed Jul 26, 2017 3:22 pm Post subject: Re: I don't even know where to start anymore |
Thanks Rock. Those links are great and I am going to make a manual for them.
Started the engine pull today. Called Bill and Steve's parts. Grant rings. $20 in stock. Will make a trip tomorrow and pick them up.
KKiley Samba Member
Posted: Wed Jul 26, 2017 7:39 pm Post subject: Re: I don't even know where to start anymore |
Well, Busdaddy is the winner of What's wrong with Kevin's car now, lol. Removed the engine today and found issue #1: Nut was missing from the alternator wire, I am guessing that might have an impact on the Alt light coming on.
Here is issue #2:
Budaddy, the nut did not come off in the intake. I locktited the nut on, so the whole stud came out this time. Every bolt on the intake was loose, and that oil deflector was leaking oil down the case. Also a major vacuum leak, for sure.
Picking up new rings tomorrow and some other bolts and seals. The car may not be terminal after all
We will get it buttoned back up and they address the dual relay/ electrical issue next Blue Locktite all around on this build, lol.
Posted: Wed Jul 26, 2017 8:14 pm Post subject: Re: I don't even know where to start anymore |
Damn, that was a wild assed guess , although it was the most logical explanation for the combined symptom
Your rings may be fine afterall, it's your call if you want to reattach the manifold and try it, or swap the rings just because you are 3/4 of the way there now and the ones in it are known to be an issue. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
KKiley Samba Member
Posted: Wed Jul 26, 2017 8:30 pm Post subject: Re: I don't even know where to start anymore |
No way I am going with these rings. I don't like the compression readings I am seeing and for $20, I'd rather use known good ones.
I need to confirm the direction of that oil sling under the intake and make sure it is going in the right direction.
Also found that the main seal on the transmission is leaking, that is where the major oil leak was coming from. Will address that tomorrow too.
KKiley Samba Member
Posted: Tue Aug 01, 2017 3:39 pm Post subject: Re: I don't even know where to start anymore |
Well, just to update everyone, we have a running vehicle again! The intake not staying tight was causing so many issues. I red loctited the studs into the block for the intake. Then I bought all lock nuts for the nuts on the intake and the studs.
VW_Jimbo was very nice and helped me thru the build. I texted him like crazy during the assembly and then he came over yesterday for the final prep and we started the car! It smoked initially, but cleared up nicely. Jim thought the pulses felt good and the engine is hitting nicely on all 4 cylinders.
Found the issue with the alternator light, the nut was missing on the wire to it and it was loose. Now my newest issue is the parking light come on when the ignition is on. And it not the switch in the wrong position. It could be the switch though.
Going to address the dual relay next. Figure out why they are blowing.
Thanks for putting up with all my rants. Much better now.
Posted: Tue Aug 01, 2017 3:56 pm Post subject: Re: I don't even know where to start anymore |
Hey Kevin! It was awesome lending a hand to the cause! I enjoyed getting that Bug going with you, but you did all the work. I was just there for the fun part!
I saw you posted up that molded air hose up in the injected thread. Nice job, that is going to help someone out down the road!
Also, thought of one more item that I saw while helping you out. It was not of concern at the time, as we only wanted to see if the car would run, but since it is running. You need to get that engine compartment seal installed. Do not drive too long without it, you will negate all of your hard work.
I will try and get back out to you to help with the lights and the dual relay, soon, if I can work it out regarding my work schedule.
See you for beers on one of these Fridays. The Coconut beer is on me! _________________ Jimbo
TDCTDI wrote: |
Posted: Tue Aug 01, 2017 5:26 pm Post subject: Re: I don't even know where to start anymore |
Yay Kevin!, third time's a charm
And props to Jimbo for the hand holding/assist, sounds like Kevin's finally going to get some miles on that beast from the drivers seat, instead of just bent over the back end. Good news! _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Posted: Tue Aug 01, 2017 6:39 pm Post subject: Re: I don't even know where to start anymore |
I have no experience with FI Beetles. A 1974 Sun Bug was the newest I ever owned. WTF is that stud with a nut doing In the intake port? I am not understanding where it came from or how it got in there...
Also, Coconut beer? Wow, sign me up!
Great that your bug is running again.
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
