Blew AC Hose While Stopped
Wolfram
Wolfram is offline
PostPosted: Wed Jul 05, 2017 8:46 pm    Post subject: Blew AC Hose While Stopped Reply with quote
Drove up from Terrebonne, OR to The Dalles and was having lunch at a city park. Boom!. Really loud sound from LR of van. Oh shit moment as I thought; propane, coolant, tire...
It was the high pressure AC line retiring after 29 years and spewing R134 and fluorescent dye allover the engine compartment.
Phew.
88 Westy, '07 EJ25 Vanaru.
Either van-less on Waiheke Island in New Zealand where we spend the Southern summer, or Wolfram is in Seattle/Olympia in storage.
Guybrush
Guybrush is offline
PostPosted: Wed Jul 05, 2017 8:57 pm    Post subject: Re: Blew AC Hose While Stopped Reply with quote
Perhaps a failed pressure switch?
Abscate Premium Member
Abscate is offline
PostPosted: Thu Jul 06, 2017 2:45 am    Post subject: Re: Blew AC Hose While Stopped Reply with quote
One of the few failures that is fixed by rolling a joint and opening a window....your shoulder, opening the window...what did you think I meant?
.ssS!
djkeev Premium Member
djkeev is offline
PostPosted: Thu Jul 06, 2017 3:20 am    Post subject: Re: Blew AC Hose While Stopped Reply with quote
I've removed 30 year okd A/C hises and looked at them. While they are indeed showing cracks I would never expect one to blow!
Yet another argument for modernizing your entire A/C with new hoses and such.
Dave
Ghia
Vanagon
Beetle
greebly
greebly is offline
PostPosted: Thu Jul 06, 2017 6:16 am    Post subject: Re: Blew AC Hose While Stopped Reply with quote
Dave
Especially if you are going to convert to the higher system pressure R134 requires.
Wolfram
Wolfram is offline
PostPosted: Thu Jul 06, 2017 9:08 am    Post subject: Re: Blew AC Hose While Stopped Reply with quote
Note the AC wasn't even operating when it blew.
Westified
Westified is offline
PostPosted: Thu Jul 06, 2017 11:36 am    Post subject: Re: Blew AC Hose While Stopped Reply with quote
You were lucky it didn't blow the hose on the interior of your vanagon. What a mess that would be. I had a similar incident. I converted to 134a and had my van idling in the driveway to see how good the AC was with the new 134a. I was about 15 feet from the van and all of a sudden there was a huge boom. Sounded like a gun shot. Scared the crap out of me. The hose above my new propane tank blew. Then a cloud of the gas enveloped the the van. I thought it was on fire. I ran over and shut it off. Made a mess all over the tank. I have now replaced my entire AC system except for the Evaporator inside. I mean everything with new barrier hoses, fittings, 709 Sanden compressor, dryer, parallel flow condenser and blower fan. The old hoses and higher pressure of the 134a did it.
1984 Westy Wolfsburg, owned since 1987.
greebly
greebly is offline
PostPosted: Thu Jul 06, 2017 11:54 am    Post subject: Re: Blew AC Hose While Stopped Reply with quote
Generally AC pressure will stabilize across the system unless there is a major restriction and static pressure will vary with external temperature. A properly charged R134 system will show 70 psi on both high and low side at 70F at stasis. If the hose blew under static pressure it is a wonder it did not explode under system pressure.
