73sparks Samba Member
Posted: Wed Jul 05, 2017 10:25 pm Post subject: Brm 15x5 on split bus with type 67 tranny. |
I was going to finally mount my brms on my 62 bus but the lugs that come with rims are for bus drums and I have a 67 bug tranny on rear.
so my question is since 67 is 5 lug can i find a chrome lug for rear tires
that will let me use them on bus.
Thanks |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Thu Jul 06, 2017 5:32 am Post subject: Re: Brm 15x5 on split bus with type 67 tranny. |
You can get the correct lug nuts or screw in studs/lug nuts from CIP1 or CB Perf. I believe that Bus drums use 14mm acorn nuts and your 67 wide five drums use 12mm acorn nuts. |
Posted: Thu Jul 06, 2017 6:39 am Post subject: Re: Brm 15x5 on split bus with type 67 tranny. |
I bought lugs for bus when I got the rims, front drums are bus should be good. will get correct ones for rear, chrome hopefully.
Thanks for info, much appreciated. |
Posted: Thu Jul 06, 2017 1:25 pm Post subject: Re: Brm 15x5 on split bus with type 67 tranny. |
A rear brake upgrade you might want to consider is using Thing rear drums. They are larger than standard beetle drums and will give you more braking power. Not sure all what's involved in the conversion but a search in the beetle thread will have examples.
Rear Thing drums are expensive unless you can find a usable set in someone's junk bin or spare parts. If you have to purchase them new and associated parts for the conversion you could purchase a bolt-on rear disc brake kit for about the same. |
Posted: Thu Jul 06, 2017 2:02 pm Post subject: Re: Brm 15x5 on split bus with type 67 tranny. |
for sure the Thing rear brakes would be sweet, but I dont beleive they work on 67.
Got the tranny super cheap newly rebuilt and bus is goung to be low and slow cruiser.
Thanks for the info✌ |
Posted: Thu Jul 06, 2017 4:50 pm Post subject: Re: Brm 15x5 on split bus with type 67 tranny. |
73sparks wrote: |
Are you using a 67 beetle tranny.....if so l believe it has been done! |
Posted: Thu Jul 06, 2017 5:46 pm Post subject: Re: Brm 15x5 on split bus with type 67 tranny. |
unfortunatly as splits go this build has been expensive. I will drive it the rest of summer and then sell to finance another bus I have to build.
cheers |
