kevlarian Samba Member
Joined: October 16, 2014 Posts: 636 Location: Orange County, CA
Posted: Sat Jun 10, 2017 12:53 pm Post subject: What did I just buy!? |
Well, it appeared to be a deal...
$275
FAJS 44 IDF
mark tucker Samba Member
Posted: Sat Jun 10, 2017 1:08 pm Post subject: Re: What did I just buy!? |
many times appearances are deceiving....like that hot chick across the other side of the bar that turns out to have a on of bondo and paint to make her look like something he aint ....as for your carb purchase...lettuce know . most any thing can be fixed & run but ...it sometimes takes too much time,parts effort and the right person. and then the issue is getting all those togeather at one time and doing it. kinda like the woman for all seasons...just dont ever let them meat each other... oops meet each other |
Posted: Sat Jun 10, 2017 1:10 pm Post subject: Re: What did I just buy!? |
mark tucker wrote: |
ummm...
thanks? that was helpful...?
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Sat Jun 10, 2017 1:18 pm Post subject: Re: What did I just buy!? |
They aren't the greatest carbs in the world. I have a pair of FAJ's 40's and have made them work for what they are. You have the cast CB linkage so that's a plus. If those manifolds are "off set" even better.
This might help ya get them set up,
https://www.thesamba.com/vw/forum/viewtopic.php?t=667351&highlight=
Make sure to clean them thoroughly before trying to install them. There's a ton of crap trapped everywhere. Since yours look like they have been run. Cleaning is an even better idea.
Pay attention as to how the AUX vents are installed. I put mine in upside down and had a hell of a time figuring out what I did wrong
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Sat Jun 10, 2017 1:29 pm Post subject: Re: What did I just buy!? |
To be clear. I purchased them off a guy who pulled them straight off his 2110, so they were already setup and running... he got a set of Dellorots.
So I'm am hoping I they are already ready to go... |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
Posted: Sat Jun 10, 2017 8:51 pm Post subject: Re: What did I just buy!? |
UK Luke 72 wrote: |
Of the China carbs the FAJS seem to be about the best... Mine did have a load of crud in the bodies as new though as mentioned about but if yours have already run I would say you're good to go... If that included linkages and manifolds you got a good deal |
Yes, pulled off a bug w/manafolds, and linkage. So Ya. I figured I could give them a shot. Were running for about a year on another Type 1 motor...
Pulled off working. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3465 Location: Paradise, Ca
Posted: Sat Jun 10, 2017 9:08 pm Post subject: Re: What did I just buy!? |
I have a set that works perfect. Run em _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Posted: Sun Jun 11, 2017 9:34 am Post subject: Re: What did I just buy!? |
After further inspection... it would appear that they have offset manifolds, and possibly the CB Performance linkage. The PO apparently set them up pretty nice. I haven't had a chance to install them... maybe later today.
How do you adjust these things when they are in the Bug!? Do you need midget hands? Are there some tricks that you all use? |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Sun Jun 11, 2017 11:32 am Post subject: Re: What did I just buy!? |
There are mixed results withém.
I just threw a set of 44 Fajs in the bin after fighting them for three full days. Very uneven fuel distribution, engine cutting out and loading up, every time I went for a drive I could readjust when I came back to the shop. Finally said ENUF!!!
Then spent 5 hours cleaning and restoring a set of Dells. Installed them, adjusted them, and the engine runs like a bat out of,,,, well you know where. Still need to get on the dyno for final trimming though.
I have had my share of these copies now. |
Posted: Sun Jun 11, 2017 12:06 pm Post subject: Re: What did I just buy!? |
I have pretty big hands. When adjusting the carbs I have to be on my knees and contort my wrists to reach the mixture screws. Takes a little practice, but you'll get it.
What's your engine specs? What dist are you running? What's the current jetting in those carbs? What size of exhaust and what brand?
Also read the "wideband results" thread. Even if you don't have a WB. You will learn the proper way to tune dual 2bbl carbs.
Think of them as one individual carb per cylinder. You tune them one at a time for the best result.
The most critical adjustment is getting the carbs synced. Fail at that and you will have an engine that runs terrible. Get it right and you won't believe the way your engine performs.
https://www.thesamba.com/vw/forum/viewtopic.php?t=293837 <wideband results thread.
kevlarian wrote: |
Buy Once, Cry Once!
Posted: Sun Jun 11, 2017 4:17 pm Post subject: Re: What did I just buy!? |
67rustavenger wrote: |
kevlarian wrote: |
Thanks! Yes. I have to purchase a sync tool. I've only had Kads and they don't require a sync tool. This is all new to me. Hope these "EMPI/Chinese" ones work out...
Dauz Samba Member
Posted: Sun Jun 11, 2017 4:48 pm Post subject: Re: What did I just buy!? |
Alstrup wrote: |
, and the engine runs like a bat out of,,,, well you know where. . |
Don't think you're destined to arrive somewhere just by saying it. OKINAWA, UK, DOWN UNDA, BARBADOS, NETHERLANDS, COOK ISLANDS, FIJI, BORA BORA, THE MOON!! Nope.. doesn't work. Darn it.. |
Posted: Sun Jun 11, 2017 7:55 pm Post subject: Re: What did I just buy!? |
what if you klick your heals 3 times . so...whats the "bonus" of offset intakes?? the sets of them Ive see look like poop as far as flow & performance.I kinda like my tall cb big beast intakes...roast beef?..wheres the beef?? taste just like chicken!!!! |
Posted: Sun Jun 11, 2017 8:19 pm Post subject: Re: What did I just buy!? |
Based on a few other posts, it seemed that the offset intake was more desired. I could be wrong. |
Dauz Samba Member
Posted: Sun Jun 11, 2017 8:46 pm Post subject: Re: What did I just buy!? |
I cut holes in the wheel well to tune my IDFs when I had them, btw.
Mark, you wear heels? 'splains alot, Buddy! jk |
Posted: Mon Jun 12, 2017 12:12 am Post subject: Re: What did I just buy!? |
Dauz wrote: |
I cut holes in the wheel well to tune my IDFs when I had them, btw. |
Wow. That's a bit extreme for me. I don't think I'm ready to make that modification to my 1958 Euro. Hope I can squeeze my hands back there... |
nsracing Samba Member
Posted: Mon Jun 12, 2017 6:45 am Post subject: Re: What did I just buy!? |
China? Never seen them before.
Anything else NOT mande in China? |
Dauz Samba Member
Posted: Mon Jun 12, 2017 8:42 am Post subject: Re: What did I just buy!? |
kevlarian wrote: |
Dauz wrote: |
Well the circular holes I cut with metal holesaw blades look factory. Youd never see them unless you were specifically looking for them. And you could keep them plugged with rubber grommets. Work smarter.. not harder |
