Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Mon Jul 10, 2017 11:36 am Post subject: Rats Nest of Wires, Not All Stock.... |
Hello again, Denizens of The Samba.
Those who have read my other threads calling for help, thanks for helping.
I have a NEW problem (will they ever end?). I found a battery isolator (finally!), and I wired it in (it works!). That is NOT the problem.
Ok, so after I got the isolator installed, I tried to figure out the rest of it (I want to put my accessories on the second battery, like GW promised with their kit). I have a '90 Diesel tin top. Under the seat, I have the Westy relay:
Only, these wires are not for the fridge and sink. They run up the front, to the rats nest under the dash:
As you can see, one splits off to the YELLOW connector, and the other goes here:
Anyone know what these are for? (Keep in mind, this van used to be a Bundeswehr MP van!)
I have found a surplus of wires that I'm not sure are all stock. For example, THIS guy (black w/ yellow connector) is one of TWO like it:
THIS random connector has power to the black w/ blue (left) only when the key is on:
If you can see it here, there is a long solid black wire with a white connector, not attached to anything....
The second black/ yellow with yellow connector:
Theres more, but I had to get back to the work I was already doing.
If anyone could help me make sense of this (mainly I need help with the relay and two wires), I would think highly of them for days and weeks to come...
Cheers!
Nico _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Mon Jul 10, 2017 12:28 pm Post subject: Re: Rats Nest of Wires, Not All Stock.... |
This so familar!
First off - What accessories do you have?
That is to say stack VW options like Power windows, Seat Heaters, A/C or a Front Diff-Lock.
Then, did the previous owner add there own accessories?
I forget if you have a Bentley to look at wiring schematics?
While they are very helpful there is some head scratching too because some of the schematics do not look like what your looking at in real life.
Do you have available to you a product called "Spiral Wrap"? It is a plastic cover that is used to protect and organize wires.
It wraps around a bundle of wires to hold them together and also provides some protection to the wires.
The Spiral Wrap can help organize the small bundles of wires that go to different switches.
Take a look at my thread and you can see where I've used it on the wire harness under the dash.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20 _________________ This free advice is worth exactly what you paid for it.
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9940 Location: Orbiting San Diego
Posted: Mon Jul 10, 2017 12:46 pm Post subject: Re: Rats Nest of Wires, Not All Stock.... |
It is pretty standard for VW to use the yellow plastic cover on wire ends that are for optional use. The black/yellow wire is for expansion of the "X" circuit and option harnesses that plug into it have their own black/yellow pigtail so yet another option can use it.
Mark |
Posted: Mon Jul 10, 2017 1:19 pm Post subject: Re: Rats Nest of Wires, Not All Stock.... |
crazyvwvanman wrote: |
Mark |
That makes sense!
Steve M. wrote: |
That is to say stock VW options like Power windows, Seat Heaters, A/C or a Front Diff-Lock. |
None. All my 'powered' options are made by 'Armstrong'. This was a German Military Police van. It's whole life.
Yes, it has two knobs, but that's air (vac) actuated. I have a couple of holes with labels on them (random, 3 letters only), and some random unplugged wires.
A few years ago, when I did the brake booster upgrade, I pulled out a bunch of chopped wires. I guess when they removed the lights, radios, switches and sirens, they just cut the devices out and left the rest!
I tried to organize it as best I could, but time was a factor. I pulled all the loose wires and tucked the rest in.
I have one inside light in the front, and one in the back, stock. No frills here!
Steve M. wrote: |
While they are very helpful there is some head scratching too because some of the schematics do not look like what your looking at in real life. |
I'm having a hard time finding consistency between the book and the wiring......
Steve M. wrote: |
Do you have available to you a product called "Spiral Wrap"? |
I know what you mean, might be the same.
A lot of the wires are in bundles, and some even have a yellow band with a number on them.
But I have no idea what the numbers match up to. Nothing I can find in the Bentley, anyway. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Mon Jul 10, 2017 7:05 pm Post subject: Re: Rats Nest of Wires, Not All Stock.... |
This might help in understanding the "G" bus.
G1 & G3- X-bus load-controlled power (hot when ign. on, goes cold when starter operates) via S12
G2 & G5- #15 ignition-switched power via S18
G4- D+ (alternator trigger circuit) via alternator warning LED
G6-dead end
G7 -headlights power
G8 -dimmer-controlled panel lighting power
G9 -parking lights power via S20
G10- hot when windshield washer pump runs
Posted: Mon Jul 10, 2017 7:15 pm Post subject: Re: Rats Nest of Wires, Not All Stock.... |
Team WorldTour wrote: |
Nico |
It looks like the BLK/ylw is coming off "G1" ? _________________ This free advice is worth exactly what you paid for it.
Posted: Mon Jul 10, 2017 11:23 pm Post subject: Re: Rats Nest of Wires, Not All Stock.... |
G3
And it looks like the Blue wire comes from G2.
Any idea what the RED YELLOW bus is?
Looks like C18? _________________ 1990 Feldjäger Syncro AAZ
Click to view image
Posted: Fri Jul 14, 2017 11:54 pm Post subject: Re: Rats Nest of Wires, Not All Stock.... |
So, I found this yesterday:
It looks to be a relay, with a 50A strip fuse on it. I don't remember this in Domo.
Can anyone identify this relay for me?
Anyway, Yesterday I finished the van. He is ready to head off the Croatia on Sunday!
After doing the GW inspired wire hack, I discovered that the promise and the reality were not the same.
The GW hack moves the radio and cigarette socket to the AUX battery. That's it.
So, I whipped out the Multimeter, and did some hacking of my own.
In the Drivers interior light, power comes in, and goes out. So, I cut the outgoing wire and capped it.
I went down to the other end, and wired it into my new fuse block.
NOW all the accessories are on the house battery.
I have the Terrapod DRLs wired to the 'on with key' wires someone identified for me, with a toggle switch (so I can switch them on and off!).
I'm still curious what my two wires (from the under seat relay) powers.
One wire shows 1.34 mV, and the other gives 12.4V with the motor running.
Anyway, thanks to everyone for the advice! My van is much better now for it! _________________ 1990 Feldjäger Syncro AAZ
Click to view image
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32634 Location: Reading Pennsylvania
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Sat Jul 15, 2017 6:54 am Post subject: Re: Rats Nest of Wires, Not All Stock.... |
Your Syncro has a a 2 speed 450 watt radiator fan.
Bentley 97.200 _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Sat Jul 15, 2017 9:51 am Post subject: Re: Rats Nest of Wires, Not All Stock.... |
Glad it worked out. I've learned a few things here.
I'm doing something similar next. Which wire did you move? Picture? _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
vanonimous Samba Member
Joined: October 19, 2013 Posts: 362 Location: Burien, Center of the Universe
Posted: Sun Jul 16, 2017 11:59 pm Post subject: Re: Rats Nest of Wires, Not All Stock.... |
Black/yellow is where power windows draw from on models that have them. The whole rat's nest is pretty standard VW behavior.
Have fun in Croatia. Balkan is my favorite place in the whole world. Hope to go touring there some day. _________________ If happiness is being a mechanic, owning a Vanagon is nirvana.
Lighting upgrades: https://www.thesamba.com/vw/forum/viewtopic.php?t=578291 |
