Off to paint
Pete VW
Pete VW is offline
PostPosted: Mon Jul 10, 2017 5:01 pm    Post subject: Off to paint Reply with quote
Here is my Thing going off to body shop. Fixing a few rust areas and going with a new color. I will post some pictures as my build progresses.
Pete
Banker
Banker is offline
PostPosted: Mon Jul 10, 2017 6:22 pm    Post subject: Re: Off to paint Reply with quote
Wow it looks like it just got back from paint.
Brian
07 Charger Sublime
03 Goldwing
74 Thing
Pete VW
Pete VW is offline
PostPosted: Tue Jul 11, 2017 3:23 am    Post subject: Re: Off to paint Reply with quote
At 20 feet it looks pretty good but up close there's several spots were the Bando from a paint job nine years ago is swelling out with rust behind. The pan is solid. I am making a removable panel for easier motor install and switching to euro style tail lights.
GI Joe
GI Joe is offline
PostPosted: Tue Jul 11, 2017 5:25 am    Post subject: Re: Off to paint Reply with quote
She does look fr sh from paint! Good to get it back under. Patrol now, before she rots further!
Are You making the whole tail removable, or just doing the GI Joe mod to the apron?
'74 Thing, "Our Thing"....Blue 181
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember
Bashr52
Bashr52 is offline
PostPosted: Wed Jul 12, 2017 5:23 am    Post subject: Re: Off to paint Reply with quote
Going to copy my paint color and light setup?? Laughing
Pete VW
Pete VW is offline
PostPosted: Mon Jul 17, 2017 4:13 pm    Post subject: Re: Off to paint Reply with quote
I might as well go with new tail lights. Next I might as well cut out a panel to make engine install/removal easy. Not a good picture.
Semper_Dad
Semper_Dad is offline
PostPosted: Mon Jul 17, 2017 7:05 pm    Post subject: Re: Off to paint Reply with quote
I believe the Euro lights were the amber over red. Not like US Split Window all red that requires a different wiring setup. .
74 VW Thing - Walküre
Bashr52
Bashr52 is offline
PostPosted: Tue Jul 18, 2017 5:04 am    Post subject: Re: Off to paint Reply with quote
Yep:
Pete VW
Pete VW is offline
PostPosted: Tue Jul 18, 2017 5:34 am    Post subject: Re: Off to paint Reply with quote
Thanks for pointing that out. I am new to VW's and Things. Learning as I go.
Looks like Euro will fit. I will be running a new wiring harness so I will be able to get either style to work.
Pete VW
Pete VW is offline
PostPosted: Thu Aug 17, 2017 8:21 am    Post subject: Re: Off to paint Reply with quote
Update on my Thing. Sand blasting showed that front was repaired at sometime but repair looked to be done right. Going to fix minor rust in battery area with patch panel from the TS. Hope to have in primer next week.
ALANSD
ALANSD is offline
PostPosted: Thu Aug 17, 2017 8:50 am    Post subject: Re: Off to paint Reply with quote
awesome happenings. I wish I could do that. The PO did body work and a couple of spots have the small bubble from bondo being pushed.
I also would love to change the color.
How much will you be spending on paint if I can ask? Single stage or clear coat over?
foirmer pro guitarist with 80s band Atlanta
had vws since 1968
Pete VW
Pete VW is offline
PostPosted: Fri Aug 18, 2017 6:20 pm    Post subject: Re: Off to paint Reply with quote
It will be single stage no clear coat. I don't have a price on paint yet.
ALANSD
ALANSD is offline
PostPosted: Sun Aug 20, 2017 8:56 am    Post subject: Re: Off to paint Reply with quote
sounds good keep us posted
had vws since 1968
tootype2crazy
tootype2crazy is offline
PostPosted: Sun Aug 20, 2017 10:01 am    Post subject: Re: Off to paint Reply with quote
That's a nice solid Thing you got there. Glad to see it coming together, keep up the good work!
air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's)
Pete VW
Pete VW is offline
PostPosted: Mon Aug 21, 2017 4:03 pm    Post subject: Re: Off to paint Reply with quote
A lot of time on this panel. I hope it's worth it when I go to install engine,
Pete VW
Pete VW is offline
PostPosted: Fri Sep 29, 2017 2:50 pm    Post subject: Re: Off to paint Reply with quote
Finally in primer. Hope to have it in color by end of next week. I am happy with dash panel. Found that this Thing was originally white then yellow and when I bought it orange. Next you will see my color choice.
iltis74
iltis74 is offline
PostPosted: Fri Sep 29, 2017 3:49 pm    Post subject: Re: Off to paint Reply with quote
What a tease.
I think modifying the rear like that is a smart move.
65 Beetle
73 & 74 Things
87 Syncro
74 Thing
74 Thing is offline
PostPosted: Fri Sep 29, 2017 9:27 pm    Post subject: Re: Off to paint Reply with quote
As a person who has shoe horned too many engines to count out of a tight engine bay in a Thing, that is a well worth modification.
Can you give close up photos of what you used to re-fasten?
Thanks
Pete VW
Pete VW is offline
PostPosted: Wed Oct 04, 2017 5:25 pm    Post subject: Re: Off to paint Reply with quote
Finally in color. Watch out it's bright. New beam lowered with disc brakes. Next is rear disc brakes and lowered. Reassembling on going. Only frustration is engine tin what a PIA.
Hobug
Hobug is offline
PostPosted: Thu Oct 05, 2017 7:15 am    Post subject: Re: Off to paint Reply with quote
I like both the color and the stance! (I know the back isn't down yet)
www.athensvwclub.com
73 Thing (Typ481)
76 Westy
69 Squareback auto
70 Westy
72 Super
63 Bug
