Comparison of BJ and 181 Spindles/Trailing Arms
mackaymanx
mackaymanx is offline
PostPosted: Fri Oct 13, 2006 3:14 am    Post subject: Comparison of BJ and 181 Spindles/Trailing Arms Reply with quote
I have some comparison pics of the BJ and 181 lower trailing arm and spindles.
http://forums.aussieveedubbers.com/viewtopic.php?tid=56811
You can see the difference in offset of the spindles from the ball joint centrelines.
You can see how the centres of the balljoints are the same for the BJ and 181 spindles
Standard ball joints, you can see the limited surface area that the lower ball joint(top one in this photo) has to work on.
BJ and 181 lower trailing arms
181 trailing arm has thicker wall thickness, upper BJ trailing arm has same thickness as lower 181 arms
BJ, modified BJ and 181 ball joint socket in lower trailing arm.
This shows the difference in the shock absorber mounts, but the axis and centre line of the shock absorber remain the same. The 181 stud is longer and the boss machined back closer to the ball joint to accommodate the longer sleeve on the 181 shocks. The 181 stud has a larger thread.
I can see no difference in the geometry of the 181 and standard ball joint trailing arms. I have easily modified a lower bj lower trailing arm to accept a 181 ball joint.
Ian Epperson
Ian Epperson is offline
PostPosted: Fri Oct 13, 2006 7:44 am    Post subject: Reply with quote
Wow! Excellent comparison pics! Do you mind if I put this in a page in Veewiki?
Probably at:
http://veewiki.com/TheThing/ThingOnlyParts/FrontEnd
ztnoo
ztnoo is offline
PostPosted: Fri Oct 13, 2006 9:26 am    Post subject: Reply with quote
mackaymanx has some great shots of some good looking front disk brake caliper mounts over at Shoptalkforum. Nice workmanship.
http://www.shoptalkforums.com/viewtopic.php?t=104463&sid=1ede23154c8528399eecb9e0847c51ea
mackaymanx
PostPosted: Fri Oct 13, 2006 3:05 pm    Post subject: Reply with quote
Ian use what you can, I've read some conflicting reports on the trailing arms and decided to make some comparisons. I got a 2nd hand set for my manx off another buggy owner(Apoligies to the purists). From what i've been able to work out the top trailing arm are directly interchangable and the lower with a minor modification.
tripicana
tripicana is offline
PostPosted: Sun Dec 14, 2008 10:54 am    Post subject: Reply with quote
i used thing spindles with type1 trailing arms. i just swapped the lowers from side to side and pressed in the thing balljoints from the bottom.
this picture shows type 1 trailing arms on my beam.
Bashr52
Bashr52 is offline
PostPosted: Sun Dec 14, 2008 9:08 pm    Post subject: Reply with quote
I just built an adjustable beam for my thing. I will be swapping to Ghia discs as well. Everything on the beam is stock Thing parts, including arms. I just installed ghia/bug balljoints into the thing arms, with the lower one flipped the right way. No problems at all. Should save anyone head aches if they are going this way as well. You can keep the beefier Thing arms.
EMPIImp69
EMPIImp69 is offline
PostPosted: Fri Mar 02, 2012 8:33 am    Post subject: Reply with quote
Will Thing front backing plates bolt directly on 66-67 Type 1 front spindles? thx
1963 Ragtop Bug
Hebster52
Hebster52 is offline
PostPosted: Wed Dec 21, 2016 2:07 am    Post subject: Reply with quote
I would not swap the trailingarms from one side to the other... The end where the balljoints are fitted is in an angle and becomes totally wrong if you flip them...
Only correct way to fit Thing balljoint is to do as Mackaymanx did. I've done just the same now too.
Ready to be fitted into my -66 beetle.
~Kris~
The Hebster52
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
The Doppel -67, SOLD
The Singlecab -72, SOLD
mackaymanx
PostPosted: Wed Feb 07, 2018 10:44 pm    Post subject: Re: Comparison of BJ and 181 Spindles/Trailing Arms Reply with quote
Photo links updated.
[url=http://www.vw-mplate.com/mplate2-18600.png]Click to view image[/URL]
74 Thing
74 Thing is offline
PostPosted: Thu Feb 08, 2018 7:32 am    Post subject: Re: Comparison of BJ and 181 Spindles/Trailing Arms Reply with quote
Help me understand.
What did you do to the front end or are you just showing Type 1 vs Type 181 trailing arm differences?
