mlesniak Samba Member
Joined: April 08, 2015 Posts: 350 Location: Wisconsin
Posted: Sun Jan 03, 2016 10:22 am Post subject: How to remove #4 engine/case bolt |
Hello everyone, ive been working on pulling the engine out of my bus, was able to do everything but ive been stuck on this final case bolt for a week!!!!!!!!!!
I was told to use a 17mm socket but when i tried it turned out that its wayy too small... 18mm socket wont fit either and a 19mm is too big. Question is how the hell do i get it off!?!?!
Please help me! _________________ Rosita the 73' Tin-top |
Joined: January 01, 2007 Posts: 16865 Location: sticksville, ct.
Posted: Sun Jan 03, 2016 10:25 am Post subject: Re: How to remove #4 engine/case bolt |
that is the threaded insert to do away with the nut due to a doghouse cooler and lack of room. it appears to have slipped out of the case
2 options now
1) needle nose vise grips clamped on the barrel with all you can muster and pray it doesn't slip
2) start cutting _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Jan 03, 2016 10:32 am Post subject: Re: How to remove #4 engine/case bolt |
Lmao!!! Damn im gonna try praying first and if it fails then ill cut it. Thanks so much. U saved me a whole 3 days of anger management haha _________________ Rosita the 73' Tin-top |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Sun Jan 03, 2016 10:35 am Post subject: Re: How to remove #4 engine/case bolt |
We have tried the 17mm socket with 6" extension from over the clutch arm, correct? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Sun Jan 03, 2016 10:53 am Post subject: Re: How to remove #4 engine/case bolt |
asiab3 wrote: |
We have tried the 17mm socket with 6" extension from over the clutch arm, correct? |
what good what that do him seeing it's a round barrel pressed into the case? there is no nut/hex head on that side
Jake Raby wrote: |
Brian wrote: |
Tcash Samba Member
Posted: Sun Jan 03, 2016 10:57 am Post subject: Re: How to remove #4 engine/case bolt |
That looks like an insert. Put a pair of vise grips on it. The bolt is on the trans side under the bus.
Good luck
Tcash |
Posted: Sun Jan 03, 2016 10:58 am Post subject: Re: How to remove #4 engine/case bolt |
I'm not entirely certain the OP knows that a bolt threads into that insert from the underside of the bus. Many folks who work on earlier VWs and PO'd setups don't even try for the bolt; they just go straight for a 17mm wrench behind the fan shroud "because that's the way we've always done it." _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Sun Jan 03, 2016 11:27 am Post subject: Re: How to remove #4 engine/case bolt |
Ah that explains why the 17mm didn't work. So i have to secure the vice grips on the case bolt and then undo it from the transmission/backside??? _________________ Rosita the 73' Tin-top |
Posted: Sun Jan 03, 2016 11:44 am Post subject: Re: How to remove #4 engine/case bolt |
yup _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Jan 03, 2016 11:47 am Post subject: Re: How to remove #4 engine/case bolt |
mlesniak wrote: |
Ah that explains why the 17mm didn't work. So i have to secure the vice grips on the case bolt and then undo it from the transmission/backside??? |
You only need to secure your case insert if it spins while you loosen the bolt that is above the transaxle clutch arm.
To be clear, the bolt is inserted here, and threads into what your first picture shows. See the clutch arm in the corner for reference?
Posted: Sun Jan 03, 2016 12:32 pm Post subject: Re: How to remove #4 engine/case bolt |
Alright so i secured the case nut and removed this bolt... However the case nut is still in place. I think im gonna have to pop it out with a screw driver. _________________ Rosita the 73' Tin-top |
Posted: Sun Jan 03, 2016 12:49 pm Post subject: Re: How to remove #4 engine/case bolt |
SHIET! Pulled the wrong out. Gotta go back and get the right bolt this time haha. Should be good after that _________________ Rosita the 73' Tin-top |
Posted: Sun Jan 03, 2016 12:57 pm Post subject: Re: How to remove #4 engine/case bolt |
Yeah that looks a little funky. 17mm head on the engine bolt. Leave the case insert in place, it stays inserted in the case for the life of the engine, unless it's stripped which would be rare. _________________ Learn how your vintage VW works. And why it doesn't!
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jan 03, 2016 2:01 pm Post subject: Re: How to remove #4 engine/case bolt |
mlesniak wrote: |
SHIET! Pulled the wrong out. Gotta go back and get the right bolt this time haha. Should be good after that |
Did that bolt require a 15mm wrench by any chance?, if it did you'll have to look lower and closer to the left side, directly behind the clutch lever infact. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jan 03, 2016 7:50 pm Post subject: Re: How to remove #4 engine/case bolt |
Yea it was the wrong one, but i found the 17mm bolt. Thanks for the help everyone. Got the engine out
aeromech Samba Member
Joined: January 24, 2006 Posts: 16961 Location: San Diego, California
Posted: Sun Jan 03, 2016 8:12 pm Post subject: Re: How to remove #4 engine/case bolt |
Matthew,
What the heck is wrong now? How many times has that engine been out since you bought the bus?
_________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sun Jan 03, 2016 8:55 pm Post subject: Re: How to remove #4 engine/case bolt |
mlesniak wrote: |
Don't forget to put that 15mm bolt back into the bell housing carrier . . .
Colin _________________ www.itinerant-air-cooled.com |
Posted: Sun Jan 03, 2016 10:37 pm Post subject: Re: How to remove #4 engine/case bolt |
Yup amskeptic got the 15mm bolt back...
Nothin wrong aeromech, just have to get the fuel tank/system cleaned out and ready for the Subaru engine.. Man I love that picture!!! So glad my bus has made it till now..I also got rid of that ridiculous brake switch haha. _________________ Rosita the 73' Tin-top |
Posted: Sun Jan 03, 2016 10:39 pm Post subject: Re: How to remove #4 engine/case bolt |
Just twice... _________________ Rosita the 73' Tin-top |
Posted: Sun Jan 03, 2016 10:47 pm Post subject: Re: How to remove #4 engine/case bolt |
Subaru? Who died and left you a fortune? I thought you were a broke kid right out of high school. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
