markholland8 Samba Member
Joined: December 07, 2016 Posts: 149 Location: United Kingdon
Posted: Fri Jul 21, 2017 6:44 am Post subject: Re: Generator light on |
so I eventually found the issue, in insight i should bought a new regulator in the first place #onabudget anyways purchased a brand new one and low and behold i still had the issue. eventually tracked it down to a very worn generator brush. On a positive note I now have a spare. |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Fri Jul 21, 2017 8:46 pm Post subject: Re: Generator light on |
markholland8 wrote: |
There's two brushes on the generator. Change both. _________________ www.vwnos.com [email protected]
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Sat Jul 22, 2017 7:19 am Post subject: Re: Generator light on |
I've been working the last 9 days so little time to look at the forums, but when a saw the title of this thread, my immediate thought is "check the friggin' brushes"... _________________ Andy T.
heimlich VWNOS.com
Posted: Sat Jul 22, 2017 9:35 am Post subject: Re: Generator light on |
glutamodo wrote: |
I've been working the last 9 days so little time to look at the forums, but when a saw the title of this thread, my immediate thought is "check the friggin' brushes"... |
Mine was the belt. Second was the brushes.
Remember not to tighten the belt to tight.
You might think the tighter the better but that is not good in this instance. _________________ www.vwnos.com [email protected]
buggin74vw Samba Member
Joined: June 20, 2007 Posts: 98 Location: Hanover, Pa
Posted: Tue Feb 20, 2018 8:23 pm Post subject: Re: Generator light on |
Currently dealing with same situation. My belt feels kinda tight. Just curious how a tight belt would cause charging to not be happening? |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Tue Feb 20, 2018 8:59 pm Post subject: Re: Generator light on |
buggin74vw wrote: |
It would have nothing to do with charging not happening, but a too-tight belt will kill the bearings in the generator. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
mukluk Samba Member
Posted: Tue Feb 20, 2018 9:08 pm Post subject: Re: Generator light on |
buggin74vw wrote: |
The closer the pulley halves are to each other, the higher the belt rides in the groove. When the belt rides higher in the groove you're effectively increasing the working diameter of the pulley, which reduces rpm. So I guess theoretically if the belt is tightened to such an extent that the pulley rpm drops below the generator cut-in speed, you could get a gen light from that... but I'm pretty sure your idle speed would likely have to be under normal spec as well. _________________ 1960 Ragtop w/Semaphores "Inga" |
