Ukrobotman Samba Member
Posted: Sat Jul 22, 2017 2:47 pm Post subject: 72KG front beam, adjusters |
Hi folks , I have a 72 KG vert. Someone in the past has fitted Sway Away adjusters in the beam. They have welded them in so the beam is low.. a good few inches low and it will only go lower not higher. I want to get it back to somewhere near stock height. I've considered cutting the adjusters out and re wellding them in but I'm not sure how to locate them so that in one position I gets the car back to stock height and at the other end of adjustment I get it lowered. The original beam before it was cut would have had a dimples in the beam. I need to know exactly that point so that I can use that as my starting point. Does that make sense?
Can anyone help ? |
