i_luv_my_bus76 Samba Member
Joined: May 18, 2012 Posts: 371 Location: High Desert
Posted: Wed Jul 12, 2017 6:20 pm Post subject: Electronic Ignition |
I left my interior light on and it drained my battery...i was in a hurry right now while I was trying to jump my bus, I got the bus started and when I was removing the jumper cables I touched the 2 cables together and now my bus won't start and the battery won't charge
I replaced the alternator and installed a flame thrower distributor with a bosch blue coil around a year ago, everything was fine until I left the interior light on and touched the jumper cables together...
I'm thinking I fried the electronic ignition module...sound about right? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Wed Jul 12, 2017 6:28 pm Post subject: Re: Electronic Ignition |
Confirm that by checking for spark at the plugs, not guessing.
It's possible the alternator diodes got fried but a quick touch shouldn't have done that. _________________ .ssS! |
Posted: Wed Jul 12, 2017 7:08 pm Post subject: Re: Electronic Ignition |
I can't get it jump started now to check for spark, just enough juice to run the fuel pump even with jumper cables connected...i have an automatic trans so push sttarting is out of the question... |
Tcash Samba Member
Posted: Wed Jul 12, 2017 10:02 pm Post subject: Re: Electronic Ignition |
Clean the battery connections.
Remove the battery and have it tested at an auto parts store.
Good luck
Tcash |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Thu Jul 13, 2017 5:51 am Post subject: Re: Electronic Ignition |
Fix known problems first. Get the battery on a charger and once it is fully charged you can troubleshoot the no start issue. (your alternator is not designed to charge a completely dead battery)
Some folks report a no start issue when the electronic module does not get a full 12v. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
cmonSTART Samba Member
Posted: Thu Jul 13, 2017 6:55 am Post subject: Re: Electronic Ignition |
IIRC the threshold voltage for the pertronix unit is 9.5 volts. If your battery is weak and grounds are bad, voltage can easily drop below this while cranking. _________________ '78 Bus 2.0FI
de K1IGS |
