Questions swap'n Engine from an Automatic into a bus with Manual
ryyanking
ryyanking is offline
PostPosted: Wed Jul 12, 2017 11:35 pm    Post subject: Questions swap'n Engine from an Automatic into a bus with Manual Reply with quote
Okay, so last week I overheated my engine and it needs a rebuild as it doesn't have compression. The even worse news is I don't own a garage or a driveway to work on it, and all the mechanics in Seattle are booked out at least 2 months for engine rebuilds.
So I bought an engine (type iv 1800cc with a 009 and a progressive weber compression is 1: 160 2: 155 3: 160 4: 170) from Small Car performance today that came out of a 74 bus with automatic transmission. And the plan is to swap it into my 74 bus that has a manual transmission.
What all needs to change to make this work?
I heard I need to swap out the bottom studs (of the 4 bolts) of the engine block in order to make sure it fits the transmission, as the manual studs are longer.
Anything else to watch out for?
Wasted youth
Wasted youth is offline
PostPosted: Thu Jul 13, 2017 2:14 am    Post subject: Re: Questions swap'n Engine from an Automatic into a bus with Manual Reply with quote
I have learned the original 1700 engines had two different camshafts; one had two rings cast in it and a painted stripe. This is for the automatic application and Bentley illustrates this. Also, the engine code is either a CB or CD depending on whether it was auto or manual... Bentley also notes this. I have one of each.
I do not know if this carried over to the 1800 engines.
Regardless, although I am uncertain how important the cam profile is between the two, neither was ever meant for an engine with an 009 distributor or signal carb. The automatics were built with 205 S distributors meant for PDSIT dual carburetor set ups. Not sure what the manual trans had.
If yours comes with its flex/drive plate, it is something that can be hard to
find at times, so it may have some decent resale value.
rockerarm
rockerarm is offline
PostPosted: Thu Jul 13, 2017 9:30 am    Post subject: Re: Questions swap'n Engine from an Automatic into a bus with Manual Reply with quote
Hi. Well you, or someone, will need to check and possibly reset the endplay for the flywheel you will need to install. The needle (pilot) bearing is easily serviceable or replaceable.
I would check existing endplay. Remove flexplate. Decide if you want to replace flywheel seal. Will probably have to if you end up changing the shim pack. There is also an o-ring in the flywheel and you will need the 5 hole crushable gasket/shim when torqueing down flywheel. Inspect the pressed in plug for the main oil gallery.
Verify the flaps are present under the cyl tins. Check spark plug threads. Inspect alternator wiring harness and alt belt.
I'm sure there's more to check like the oil cooler seals and the oil strainer plate for any issue that gave this area a bad rap.
Hope this helps.
Amskeptic
Amskeptic is offline
PostPosted: Thu Jul 13, 2017 9:33 am    Post subject: Re: Questions swap'n Engine from an Automatic into a bus with Manual Reply with quote
Those sky-high compression numbers . . .
Colin
www.itinerant-air-cooled.com
ryyanking
PostPosted: Sat Jul 15, 2017 1:07 pm    Post subject: Re: Questions swap'n Engine from an Automatic into a bus with Manual Reply with quote
Yes, not planning on keeping this carb/dizzy combo for long. Just long enough to save up for dual webers and a svda. If the 1800's did have two cams... how bad would it be to use it? Have people had problems running a 1700 automatic cam with a manual transmission?
Unfortunately no flex/drive plate
ryyanking
PostPosted: Sat Jul 15, 2017 1:11 pm    Post subject: Re: Questions swap'n Engine from an Automatic into a bus with Manual Reply with quote
Colin
They are... can compression get too high? Are there problems associated with that? I've only ever had compression numbers that were too low.
Anywhoo, I got the engine in. Starts and runs, but is making a squealing noise. First guess was alternator bearings or fan belt, but it sounds like its coming form the drivers side. Could it be the throwout bearing or clutch? I've engaged and disengaged the clutch and the squealing remains exactly the same.
Amskeptic
PostPosted: Tue Jul 18, 2017 8:05 pm    Post subject: Re: Questions swap'n Engine from an Automatic into a bus with Manual Reply with quote
ryyanking wrote:
Colin
Remove belt. Start engine. Advise.
Colin
[lubricate distributor under rotor and make sure points (if you have them) have grease on rubbing block/breaker cam]
ryyanking
PostPosted: Fri Jul 28, 2017 9:46 am    Post subject: Re: Questions swap'n Engine from an Automatic into a bus with Manual Reply with quote
Okay, finally got back around to messing with the engine (3 jobs don't allow a lot of wrenching time)
Here's a video of the sound with the fan belt on:
Here's a video of the sound with the fan belt off:
Here's a video of the sound with the fan belt back on...but I turned the engine off so you can hear how the noise changes as the engine stops.
Whats it sound like and/or whats the next test?
Thanks guys. [/youtube]
dugfresh
dugfresh is offline
PostPosted: Fri Jul 28, 2017 2:31 pm    Post subject: Re: Questions swap'n Engine from an Automatic into a bus with Manual Reply with quote
Hey Ryan, We chatted via text earlier this morning.. forgot my computer at work doesn't have sound (to prevent youtube watching i guess). Maybe I could swing by sometime and take a look with you and see or hear it. I'm going to the Oregon coast thru thurs...
dug
78 Riviera
http://flic.kr/s/aHsjDRJPa1
