RicoS Samba Member
Posted: Thu Jul 13, 2017 8:57 am Post subject: How I Terminate the Green OXS Conductor |
Here you go ,Zen.
The problem with the termination of the green shielded OXS conductor as it comes from the factory is that the shielding is trimmed flush with the outer jacket and the raw edges of the copper shielding, backed up by the stiff (polyethylene?) insulation of the outer jacket can wear through the insulation of the inner conductor and, the shielding being grounded, take the OXS output to ground. When that happens, the fuel mixture richens to the max and the van runs like a pig.
This is how I improved this termination the first time I had one queef out on me.
Free up as much of the conductor from the loom as reasonably possible, pull back the boot and cut the end CLEANLY. Don’t mash the end with a pair of dykes or sidehacks. Use a sharp bypass wire cutter. If you don’t have one, a utility knife with a fresh (SHARP) blade will work. Make life easy on yourself and cut the conductor cleanly.
Unless you’re a very practiced hand, only SCORE the outer jacket at the point you want to remove it. DO NOT nick the shielding stands, they’ll end up breaking of at the nick. Flex the score line and the outer jacket will separate and you can pull off the end of the jacket.
Fan out the strands around the wire, then comb them back over the outer jacket. I stripped off much more of the outer jacket than is necessary for the sake of clarity. Although it doesn’t hurt, this is more sheilding than you’ll need – about 1/4 - 3/8” is plenty.
Cover the shielding strands with some shrink tubing.
Crimp on the spade connector. Try to use the right sized connector for this gauge of wire and DON’T FORGET to slip on a piece of shrink tubing BEFORE you attach the connector.
Shrink the covering.
If you’re as anal as I am, cover it all with another piece of shrink tubing. Slide the boot over all your pretty work - you might have to lubricate (saliva) the conductor so that the boot can be pulled over the additional bulk of the shrink tubing – and you’re done.
Note: I did this example on the bench using a spare wiring loom. Be forewarned, it’s a little tougher to do in place on the van, but I’ve managed to pull it off more than once.
Richie (near The Burgh) |
WestyKlaus Samba Member
Posted: Thu Jul 13, 2017 9:05 am Post subject: Re: How I Terminate the Green OXS Conductor |
Nice write up! Thanks. |
Zentaka Samba Member
Joined: August 22, 2010 Posts: 264 Location: Hawaii Island, Hawaii
Posted: Thu Jul 13, 2017 12:44 pm Post subject: Re: How I Terminate the Green OXS Conductor |
Thanks for the writeup Richie!
This looks fairly simple, I think even I could do it! Man that shrink tubing looks awesome, I need to get me some of that. In the mean time, does electric tape work as a poor-man's replacement? Also I got some dielectric grease, would that work for lubrication or should it be avoided in this case?
Edit: I pulled the rubber boot back and it seems to me that my shielding was terminated early possibly by a P.O. is that what it looks like in this picture?
RicoS Samba Member
Posted: Fri Jul 14, 2017 4:33 am Post subject: Re: How I Terminate the Green OXS Conductor |
Zentaka wrote: |
. . . I pulled the rubber boot back and it seems to me that my shielding was terminated early possibly by a P.O. is that what it looks like . . . |
Z - That looks like the factory termination. It might be a solid connection, it might be ready to queef out. Hard to say from this distance.
One thing I've found in old car wiring is that the conductor can look intact, yet under its unbroken insulation, the conductor has broken - especially near the connector.
Since it is in hand already, I would cut it off and redo the termination just to be certain that the wiring is solid and durable.
Re: the dielectric grease. I've only had experience with dielectric (silicone?) grease in prefabricated medium voltage (13 -22 KV) terminations and auto ignition wires. To stave off corrosion in a connection, I use an electrical connection grease (No-Ox, for one). It is messy, but it works effectively.
Taping might work as long as you can pull the boot over it. I've found out the hard way that it important to end up with a WATERPROOF connection for the OXS signal wire.
PS - Z: I just noticed that you are in Hawaii. Small world, my first Syncro came from there and boy was it ever clean. |
Posted: Fri Jul 14, 2017 7:04 pm Post subject: Re: How I Terminate the Green OXS Conductor |
I assumed that since the wire was smaller at the very end that it had been terminated by a P.O. but you're right, it looks like factory work. I had assumed the fat part of the wire came out all the way to the end on the factory connection.
In other news my OXS light came on, so we'll see if this fixes it! Anyway it's still running 1,000 times better than it was before that replacement.
Thanks again for all the help!
-Zen |
ohhorob Samba Member
Joined: September 26, 2013 Posts: 212 Location: Santa Cruz
Posted: Fri Jul 14, 2017 7:25 pm Post subject: Re: How I Terminate the Green OXS Conductor |
Zentaka wrote: |
In other news my OXS light came on, so we'll see if this fixes it! |
Unfortunately the OXS light is mileage based. There's no way for the ECU or the instrument cluster to know if the O2 sensor is in good working order, nor how long it's been installed for.. so the OXS light is wired to a counter that ticks over based on distance travelled.
From the Essentials thread: Electrical System -- OXS Light Reset _________________ "Gundy" - '85 Westfalia
GoWesty 2300cc, Digijet |
Posted: Fri Jul 14, 2017 7:48 pm Post subject: Re: How I Terminate the Green OXS Conductor |
ohhorob wrote: |
Zentaka wrote: |
From the Essentials thread: Electrical System -- OXS Light Reset |
Ahh okay that's a bit of a relief then, because fixing the terminations didn't turn off the OXS light. How strange that it decided to turn itself on right after I replaced the OXS. Correlation v. Causation, so much fun with these Vanagons!
Anyway I'll get that OXS reset, thanks for the link! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32367 Location: Reading Pennsylvania
minsk Samba Member
Joined: March 17, 2008 Posts: 899 Location: pittsburgh
Posted: Mon Jul 17, 2017 7:49 am Post subject: Re: How I Terminate the Green OXS Conductor |
Good stuff! Thanks! _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
