63RAGTP Samba Member
Joined: February 15, 2010 Posts: 112 Location: Daphne Al
Posted: Thu Jul 13, 2017 11:04 am Post subject: 78 bus with dual 44 empi/solex carbs |
I have a 78 bus that has dual empi / solex 44 mm carbs installed on it. I have a popping/backfiring back through the carb on the left side.
I am running a 009, timing is set and valves are good.
any suggestions? before I switch to a single progressive carb. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Thu Jul 13, 2017 11:20 am Post subject: Re: 78 bus with dual 44 empi/solex carbs |
Try to synch them. First, watch each carb as you move the linkage from idle to full throttle. They should both move at the same time. You may want to learn about the procedure first. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Randy in Maine Samba Member
Posted: Mon Jul 31, 2017 7:39 am Post subject: Re: 78 bus with dual 44 empi/solex carbs |
Here is an update, I pulled the dual carb setup off and installed a single progressive carb.
Valves and timing are set as they should be. Idles great. I still get a steady backfire through the intake on cylinder 4 when reving up the engine. its a constant pop, like the intake valve is open at the time of spark ignition on that cylinder.
I pulled the head on that side, and didn't see anything wrong with the valves, checked them for leaks, all were good
Any ideas?
The bus is running a pertronix vac advance distributor. I did notice that while setting the timing, vac unplugged, that the engine, timing, wouldn't advance as I raised the RPMS.
Could the dizzy be bad? |
mnskmobi Samba Member
Joined: February 28, 2005 Posts: 536 Location: Melbourne, Australia
Posted: Mon Jul 31, 2017 7:29 pm Post subject: Re: 78 bus with dual 44 empi/solex carbs |
63RAGTP wrote: |
Any ideas?
Yes. Sounds like the advance plate is gummed up.
There have been a few topics on how to refurb your dizzy. e.g.
https://www.thesamba.com/vw//forum/viewtopic.php?t=662515
https://www.thesamba.com/vw/forum/viewtopic.php?t=680864&highlight=distributor+advance |
vic74westy Samba Member
Joined: December 29, 2010 Posts: 59 Location: Rogue Valley Oregon
Posted: Tue Aug 01, 2017 1:34 am Post subject: Re: 78 bus with dual 44 empi/solex carbs |
If the problem definitely seems related to cylinder #4, I would pop the valve cover off, have someone crank the engine and check that the exhaust valve seems to be opening. Just visually compare the movement of the rocker arms between cylinders 3 &4 and see if they look the same. An exhaust valve not opening can cause a backfire through the intake. Just food for thought. Definitely want to get that distributor sorted out too! |
Posted: Mon Aug 07, 2017 8:39 am Post subject: Re: 78 bus with dual 44 empi/solex carbs |
ok so here is where things are, I put a new SVDA distributor in to rule out the old one.
Still no increase in RPMs past around 2500, even when secondary barrel opens on the carburetor.
Im at a loss here, Any pointers?
I have had other buses with the same carb setup run just fine. |
Posted: Mon Aug 07, 2017 8:48 am Post subject: Re: 78 bus with dual 44 empi/solex carbs |
Take a heat gun and while the engine is running, warm up the intake runners. Come back and give us the results _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Tcash Samba Member
