Rodmullet Samba Member
Posted: Thu Jul 13, 2017 4:36 pm Post subject: No start diagnosis confirmation |
1973 bus....turn key...nothing.
12.7v across battery terminals
12.6v across battery clamps
12.8v at ignition switch (I have an aftermarket switch in dash...done long ago by PO....I already have replaced with a new one)
12.4v or so at the ignition terminal on the starter solenoid
12.5v or so at the battery terminal on solenoid
Starter spins when the battery terminal is crossed to the starter terminal
solenoid does nothing when battery terminal on solenoid is crossed to ignition terminal
Could it be anything other than the solenoid?
Ant any recommendations on a non-crappy solenoid....I've received a lot of junky parts lately....
Thanks,
Rod |
Posted: Thu Jul 13, 2017 4:38 pm Post subject: Re: No start diagnosis confirmation |
Cleaned every connection I could get to, by the way. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jul 13, 2017 4:39 pm Post subject: Re: No start diagnosis confirmation |
Sure sounds like the solenoid, but spend some time cleaning every cable connection and ground strap termination anyways, those are some serious voltage drops you've measured. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Thu Jul 13, 2017 6:49 pm Post subject: Re: No start diagnosis confirmation |
Maybe my crappy HF multimeter, or that some places are easier to reach and get a good ground....guess I should have said plus or minus. Just trying to figure out if it could be anything besides the solenoid before I do the work. The bus is parked in sort of a constricted area and getting under and out from under the bus is difficult, especially as I am not 25 years old anymore.
Rod |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Thu Jul 13, 2017 8:53 pm Post subject: Re: No start diagnosis confirmation |
lil-jinx wrote: |
12.7 at the battery and 12.8 at the ignition?How can that be? |
10th of a volt isn't an issue here when you have 2 miles of wire. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Thu Jul 13, 2017 10:10 pm Post subject: Re: No start diagnosis confirmation |
skills@eurocarsplus wrote: |
lil-jinx wrote: |
10th of a volt isn't an issue here when you have 2 miles of wire. |
That actually sounds better than most buses I end up working on _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Thu Jul 13, 2017 10:55 pm Post subject: Re: No start diagnosis confirmation |
lil-jinx wrote: |
Thank you Skills. OP needs to properly learn and execute a voltage drop/loss test along this circuit, and it does seem like 2 miles. |
Tcash Samba Member
Posted: Thu Aug 24, 2017 6:26 pm Post subject: Re: No start diagnosis confirmation |
Well, it was the solenoid....thanks to everyone who had some positive input...those who didn't...I don't understand that type of attitude, I'm just a guy trying to keep my bus on the road....
Rod |
Xevin Samba Member
Posted: Thu Aug 24, 2017 6:55 pm Post subject: Re: No start diagnosis confirmation |
Rodmullet wrote: |
Rod |
Did I miss some shenanigans in this thread nice you got the issue sorted out. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
SGKent wrote: |
Posted: Thu Aug 24, 2017 6:59 pm Post subject: Re: No start diagnosis confirmation |
Nothing too bad...but the important thing is that I can hopefully rely on the bus to start...
Rod |
mnskmobi Samba Member
Joined: February 28, 2005 Posts: 536 Location: Melbourne, Australia
Posted: Thu Aug 24, 2017 7:13 pm Post subject: Re: No start diagnosis confirmation |
Rodmullet wrote: |
Rod |
Rod, Did you replace it or fix it? |
Posted: Thu Aug 24, 2017 8:15 pm Post subject: Re: No start diagnosis confirmation |
I replaced the solenoid...the old one may have been ok, when I pulled the starter off, the solenoid was missing one mounting screw and the other was loose...but it could be the original solenoid...since it was off I figured I would just replace it.
Rod |
