Mile High Puma Samba Member
Joined: November 11, 2009 Posts: 212 Location: Salida, Colorado
Posted: Fri Jul 14, 2017 4:48 pm Post subject: Type4 conversion exhaust |
I have been plugging away at a type4 conversion for my 65 DC and have gotten to the part that I am expecting to be a real pain, the exhaust. I am sure there have been some splitty's with this done so maybe I can get some ideas. I have some 411 pipes and I am hoping that I can fit a stock 73-74 muffler without any apron modifications. Has anyone tried it and if it won't work were you able to install something that does not hang out the bottom or is much louder that stock?
_________________ 1965 Velvet Green DC |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Fri Jul 14, 2017 7:06 pm Post subject: Re: Type4 conversion exhaust |
I am so excited to see the outcome. I have been dredin the exhaust on my type 4 conversion. What did you do with the tranny? _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Fri Jul 14, 2017 7:33 pm Post subject: Re: Type4 conversion exhaust |
very interesting how things have changed in the last 20 years or so. back in the day type 4 upright conversions involved porsche 911 fans and such. The german tuners offered type 4 exhausts that looked like beetle exhausts, etc.
like so:
i like this a lot, i am going to keep watching. _________________ regards
Uli
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Fri Jul 14, 2017 9:47 pm Post subject: Re: Type4 conversion exhaust |
With stock 73, 74 heater boxes you can bolt a single exhaust muffler across the outlets and put on a turn out tube for a neat , installation.- will try and find my pics. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Sat Jul 15, 2017 7:06 am Post subject: Re: Type4 conversion exhaust |
Zuggbug, the tranny I put together was from different year type 1 units with the stock big nut boxes. Used a 72 case with 73 "002" gearset which has the stronger mainshaft, splined coarse third and fourth gears from a bay bus trans., and 3.88 ring gear on a 70 Canadian bug swing diff. that my sister once had. This setup also gave me the later style throw out bearing setup. _________________ 1965 Velvet Green DC |
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 816 Location: clearwater,florida
Posted: Sat Jul 15, 2017 9:56 am Post subject: Re: Type4 conversion exhaust |
This is what I used in the Mid 1990's on a 66 Standard Bus, same engine bay as your Double Cab Pretty Much. I shortened the 411 heater boxes after cutting off the sheet metal and used this. I added a locally sourced round muffler and it looked nice, sounded nice, and fit nice. It was really cheap and easy. The hardest job is cleaning out the flanges you cut off the original 411 tubes and sliding then down and welding flat.
Tony _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
mark-s Samba Member
Posted: Sat Jul 15, 2017 10:32 am Post subject: Re: Type4 conversion exhaust |
Vintage Speed exhaust and headers specifically for a type 4 motor in a split bus. I went this route as the fabrication would have taken more time than I had.
It looks like the outlet hangs really low but it actually sits in exactly the same position as the stock exhaust. Also has O2 sensor ports which have been useful when tuning with a wideband.
Posted: Sat Jul 15, 2017 12:12 pm Post subject: Re: Type4 conversion exhaust |
tpinthepack wrote: |
Tony |
I have this same setup and have been mocking it up to see if it fits. Looks to me like it is too deep without dropping it down, do you have an installed pic? _________________ 1965 Velvet Green DC |
Posted: Sat Jul 15, 2017 4:25 pm Post subject: Re: Type4 conversion exhaust |
Mile High Puma wrote: |
Zuggbug, the tranny I put together was from different year type 1 units with the stock big nut boxes. Used a 72 case with 73 "002" gearset which has the stronger mainshaft, splined coarse third and fourth gears from a bay bus trans., and 3.88 ring gear on a 70 Canadian bug swing diff. that my sister once had. This setup also gave me the later style throw out bearing setup. |
Very impressive. I was hoping you did something out of the ordinary. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Sat Jul 15, 2017 4:28 pm Post subject: Re: Type4 conversion exhaust |
mark-s wrote: |
Why does their website say you have to modify the header on 3/4? _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Sat Jul 15, 2017 5:16 pm Post subject: Re: Type4 conversion exhaust |
I don't have a close up handy, but you can see a full bumper and a stock uncut apron in this image.
1990 Vanagon DOKA
1972 Super Beetle
Posted: Sat Jul 15, 2017 6:54 pm Post subject: Re: Type4 conversion exhaust |
looks like its covered well, might take another stab at that setup if a stock muffler won't fit. _________________ 1965 Velvet Green DC |
mark-s Samba Member
Posted: Sat Jul 15, 2017 10:03 pm Post subject: Re: Type4 conversion exhaust |
zuggbug wrote: |
Why does their website say you have to modify the header on 3/4? |
No further explanation about this is supplied, but having installed them, I did have to clearance the headers as they were touching the pushrod tubes in a couple of places. |
lightice Samba Member
Posted: Sun Jul 16, 2017 12:59 am Post subject: Re: Type4 conversion exhaust |
Did you buy a specific kit to do the type 4 conversion? Or did you fab as you go. |
Posted: Sun Jul 16, 2017 7:08 am Post subject: Re: Type4 conversion exhaust |
It looks like he is doing the classic Joe Cali conversion located here:
http://nextgen-usa.com/
He sells a manual that will guide you to create your own upright conversion using mostly VW OEM sheet metal slightly modified. I did one in the past and it was very nice, but in the final hours I purchased the Fat Performance unit and a 911 fan setup. I will say this one here is as nice as i have seen. His work on the tins looks great and this will be a sweet double cab. I want to hear more about the Transmission, his picture gallery shows some views but not all of them.
1990 Vanagon DOKA
1972 Super Beetle
Posted: Sun Jul 16, 2017 7:55 pm Post subject: Re: Type4 conversion exhaust |
Yes, I did buy the manual from Joe to use as a guide. A lot of the detail work you just have to make up your self like the tin, combination of type 1 and type 4 tin to get the engine compartment sealed up. I ended up making the gen/alt stand from steel stock as the one I purchased form Jake Raby for the DTM system would not let me set the fan housing back far enough to center it between the cylinders. Also the stand in Joe's book is aluminum which I did not have the proper welder to fabricate it. After all of the mods I did to the Scat shroud I think it would have been easier to modify a stock one by trimming off the heater ducts like the Sharp shrouds. _________________ 1965 Velvet Green DC |
Posted: Mon Jul 17, 2017 5:03 am Post subject: Re: Type4 conversion exhaust |
mark-s wrote: |
zuggbug wrote: |
That is great news, may I ask how you clearanced the headers? _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
mark-s Samba Member
Posted: Mon Jul 17, 2017 5:08 am Post subject: Re: Type4 conversion exhaust |
I just marked the headers where they touched the pushrod tubes, removed them and filed a bit away with one of these:
I just did a little at a time & kept refitting the header to test until I could get a feeler blade between the header and pushrod tube. |
Posted: Mon Jul 17, 2017 5:09 am Post subject: Re: Type4 conversion exhaust |
mark-s wrote: |
Ahhh. Thanks for the reply. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Mon Jul 17, 2017 8:18 am Post subject: Re: Type4 conversion exhaust |
Tony |
I have this same setup and have been mocking it up to see if it fits. Looks to me like it is too deep without dropping it down, do you have an installed pic? |
I have a DTM conversion on mine but I shortened the 411 exhaust manifolds and used this same header. I kept it off the filter and pump without having to dimple the exhaust header. It fits behind my stock apron and bumper quite nicely. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
