gregaz Samba Member
Joined: May 22, 2012 Posts: 407 Location: Phoenix, AZ
Posted: Sun Jul 16, 2017 11:28 am Post subject: Weird Headlight Issue |
1983.5 Vanagon Westfalia 1.9L WBX
I have a weird headlight issue. The short of it (no pun intended) is that the headlights don't come on with the light switch.
The long of it -
When I turn on the engine, and I flip the switch all the way (two clicks to the left), the orange running lights in the front come on. The rear tail lights come on. The headlights DO NOT come on. When I flip the brights stalk, the brights flash, but DO NOT stay on in any position (headlights on or headlights off).
Any ideas? Thank you in advance! |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Jul 16, 2017 5:48 pm Post subject: Re: Weird Headlight Issue |
Seems reasonable to suspect the headlight switch, but first check grounds.
Do you have relays installed?
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
kamzcab86 Samba Moderator
Posted: Sun Jul 16, 2017 6:05 pm Post subject: Re: Weird Headlight Issue |
Headlight switch, ignition switch, and/or load reduction relay.
With the ignition switch, it could be a faulty load reduction (aka "X") circuit. Test for continuity between terminals 30 and X.
If you jumper the load redux relay and the lights work, relay is most likely shot. _________________ ~Kamz
2016 Golf GTI S
jmranger Samba Member
Posted: Sun Jul 16, 2017 6:24 pm Post subject: Re: Weird Headlight Issue |
Given that you can flash your headlights, we know that a large part of the high beam circuit is operational: fuses, relay (if installed), bulbs (obviously) and grounds are OK.
The load reduction relay isn't required for the headlights to work.
A faulty ignition switch (its X-circuit, specifically) would disable the headlights, but also the wipers, fresh air fan and rear defrost. Are these working? It they are, the main suspect is the headlight switch. |
gregaz Samba Member
Posted: Sat Jul 22, 2017 11:10 am Post subject: Re: Weird Headlight Issue |
Update - it was the headlight switch. Specifically, the connection. I took the cluster off, pulled the switch and noticed that the connection to the harness was a little loose. I pressed them together and Presto! everything is working.
Thanks for all the help, volks! |
