mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Thu Mar 22, 2018 2:10 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
i like the center exhaust cutout, will the tip actually exit there? _________________ regards
Uli
EeVeeWee Samba Member
Joined: April 02, 2015 Posts: 836 Location: Amersfoort, Netherlands
Posted: Thu Mar 22, 2018 3:16 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
mandraks wrote: |
i like the center exhaust cutout, will the tip actually exit there? |
No there will be a damper in drive direction, but it doesn't fit yet. I'm waiting for an answer from CSP....
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Fri Mar 23, 2018 6:27 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
Looks like you gat a Bug muffler instead of a Bus one. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Fri Mar 23, 2018 11:21 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
pyrOman wrote: |
Looks like you gat a Bug muffler instead of a Bus one. |
I guess so, they will send a new one. |
The tow-bar fits well and also the bumper has been mounted.
Posted: Fri Mar 23, 2018 11:22 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
mandraks wrote: |
Now you can see why I replaced the exhaust cutout. |
Posted: Tue Mar 27, 2018 1:49 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
I connected the 7-way trailer connector to the wiring harness of the bus.
The connections are besides clamped also soldered.
It is in its place and even functioning!
Posted: Sat Mar 31, 2018 8:21 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
The central wheel nuts are tightened.
And I started with the electrics, 230V with RCD and 12V with fuse box.
Posted: Tue Apr 03, 2018 12:22 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
I did some more electrics inside of the bus, the batteries are now being charged.
Posted: Thu Apr 12, 2018 1:12 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
Finally the engine has been adjusted on the dyno.
And after that I drove the first time ever in our bus.
The smile stays for a while.
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Thu Apr 12, 2018 6:45 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
Magnificent! |
Posted: Sat Apr 14, 2018 7:37 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
I'm glad I can work on our bus again.
I fitted some wooden panels inside and already drilled the mounting holes.
Posted: Sun Apr 15, 2018 9:53 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
Some more wooden parts have been made in the right shape.
Posted: Fri Apr 20, 2018 11:51 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
Unfortunately my fuel gauge doesn't function.
I checked everything already; the fuel gauge itself, the voltage, the mass of the tank and the wires, everything is fine.
So what remains is the NOS fuel sender.
Instead of taking the engine and tank out of the bus, I will make an inspection hatch above the tank.
So I measured the exact position of the sender with help of an endoscope.
BarryL Samba Member
Posted: Fri Apr 20, 2018 6:40 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
Do you remember pulling the pin? |
Posted: Sun Apr 22, 2018 9:09 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
BarryL wrote: |
Yes of course. |
With grinder first and cutting through with Dremel, I made a hole to reach the fuel tank sender unit.
Everything is ready for mounting again, including protection against rust.
BarryL Samba Member
Posted: Sun Apr 22, 2018 10:00 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
EeVeeWee wrote: |
Unfortunately my fuel gauge doesn't function. |
When you turned the key on nada movement?
Is it fixed now? What was wrong? |
Posted: Tue Apr 24, 2018 12:34 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
So glad to use the new VDO fuel sender after all the work!
Closed the hole again and also mounted the wooden panel at the LH side of the bus.
Posted: Wed Apr 25, 2018 10:40 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
All RH side wooden panels are also mounted.
Next step is mounting of the ceiling panels.
