EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
EeVeeWee Samba Member
Joined: April 02, 2015 Posts: 836 Location: Amersfoort, Netherlands
Posted: Thu Oct 12, 2017 1:18 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
No it seems home made from wood and foam. |
Posted: Thu Oct 12, 2017 1:26 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
Bulli Klinik wrote: |
I'm really liking what you're doing here. Thumbs up from Colorado!
What model of Webasto heater is that and where can I find one?
Have you considered putting seat heater elements under the upholstery? Just finished building a Bus for a customer with them and they are for sure going into my next build. |
I found a used one and had it been checked and rebuild.
It's a Webasto Air Top 2000ST 12 volt on petrol, most of them are for diesel fuel.
With the heater on I don't need an extra seat heater I guess.
Here is a Dutch seller, I hope you can read it.
https://www.standkachel.nu/webasto-kachels-en-onde...pset912146 |
rennie Samba Member
Joined: October 06, 2016 Posts: 246 Location: Orange County, CA
Posted: Thu Oct 12, 2017 4:35 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
Nice work. Smart to secure the bay window tank filler neck vs. letting it nudge around more than you'd like.
Excellent choice with Webasto. I drove on a traverse from the edge of Antarctica to the South Pole (and beyond) and back several years ago and my Case Quadtrac's Webasto never blinked in extreme conditions over 84 days of traversing! You'll be so hot you'll be driving in your Speedo! |
Posted: Sun Oct 15, 2017 10:06 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
The petrol lines to heater and engine are ready.
Including a shut off valve for security reason and against theft.
Also made a hole in the side for the 230V connector.
It's a stainless steel connector with a waterproof cover when not in use.
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Sun Oct 15, 2017 10:24 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
The grommet dampeners are sassy. In the long run will the hose pooch at the tee be a cracking point? The juice inlet is yachty. |
Posted: Sun Oct 15, 2017 10:53 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
BarryL wrote: |
I don't know what kind of English this is, but it's difficult for me to understand what you mean. The hose is E10-proof, is that an answer? |
BarryL Samba Member
Posted: Mon Oct 16, 2017 7:01 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
EeVeeWee wrote: |
BarryL wrote: |
In the long run will the hose pooch at the tee be a cracking point? |
...what kind of English this is, but it's difficult for me to understand... |
Me try interpret:
See the number 12 on the hose?
See how it is stretched right there to go over the pipe?
Will it crack there from stress some day?
Posted: Tue Nov 14, 2017 2:03 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
I got the handles back from the chroming company, which are now better than new.
Meanwhile started cleaning the inside of the lifting roof.
Posted: Thu Nov 16, 2017 1:20 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
Some parts really have to be repainted.
Posted: Sat Nov 18, 2017 1:37 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
The aluminum strips really had te be cleaned.
After that, I started with mounting the canopy.
panel Samba Member
Joined: December 02, 2001 Posts: 1090 Location: Victoria B.C. Canada
Posted: Sat Nov 18, 2017 1:00 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
Are those copper brake lines ? _________________ My '65-Subaru EJ20 Turbo conversion |
Posted: Sun Nov 19, 2017 3:13 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
panel wrote: |
Are those copper brake lines ? |
Correct. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24736 Location: Olympia Wash Rinse & Repeat
Posted: Sun Nov 19, 2017 9:17 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
EeVeeWee wrote: |
panel wrote: |
Correct. |
Probably copper plated steel. Copper by itself is not going to hold up to such high pressure. _________________ In Stereo, Where Available! |
Posted: Sun Nov 19, 2017 10:03 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
The canopy now completely mounted.
I made some holes oval to make it a bit adjustable after mounting.
After that I cleaned and sanded the inner side of the roof before I put it in plastic primer.
panel Samba Member
Posted: Sun Nov 19, 2017 12:26 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
EeVeeWee wrote: |
panel wrote: |
Correct. |
Yikes! I don't even think you're allowed to run those in Canada _________________ My '65-Subaru EJ20 Turbo conversion |
Posted: Sun Nov 19, 2017 1:12 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
panel wrote: |
EeVeeWee wrote: |
panel wrote: |
Correct. |
Yikes! I don't even think you're allowed to run those in Canada |
With well-made double flares these copper lines are very common here in Europe.
Only used without ABS. |
Posted: Mon Nov 20, 2017 12:17 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
Latest news for the copper brake line with 4,75 mm outer diameter and 0,9 mm wall thickness:
Max. working pressure 309 bar (4482 psi), burst pressure 928 bar (13460 psi). |
Posted: Mon Nov 20, 2017 1:15 pm Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
EeVeeWee wrote: |
Does a magnet stick to the brake line?? _________________ In Stereo, Where Available! |
Posted: Tue Nov 21, 2017 12:58 am Post subject: Re: 1967 panel becomes 11 window camper with Dormobile roof |
Eric&Barb wrote: |
EeVeeWee wrote: |
Does a magnet stick to the brake line?? |
Yes, a special copper magnet does. |
