ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6351 Location: Honolulu,Hawaii and France
Posted: Sun Jul 16, 2017 4:36 pm Post subject: Weak brake booster? [advice needed] |
Aloha folks!
I have a little problem with a brake booster on my 84 Automatic Westy.
Freshly polished ( 8 hours of work )
The brake pedal feels partially non assisted since I had the van. I changed the fluid, the brake pads, brake lines because it was needed but I still have that problem.
When I brake, if I apply too much force it seems like I loose assistance.
The brake pedal gets harder, it feels normal at first but if I ask too much braking power then it seems like the booster runs out of vacuum kind of like if the engine was off.
I made the engine off type of test to waste the vacuum. Then I start the engine, but I only get partial assistance for a little bit of travel, then it gets freaking hard!
If I keep applying pressure on the brake pedal with the vehicle non moving, if I rev' the engine, I can get past that hard spot that I previously reached.
This makes me think the vacuum is weak. I have a report of low compressions on the engine from 2 previous owners. The engine was indeed sluggish until I adjusted the valves and the lockdown and throttle cable the other day... it's definitely not to the point where it's dying and not going uphill at all anymore.
It runs cherry.
So, what should I do? Replace the booster or I don't know? I don't hear any leaks by the booster when the engine is running, the engine doesn't have a vacuum leak either....
Thank you for your help! _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17121 Location: Retired South Florida
Posted: Sun Jul 16, 2017 5:15 pm Post subject: Re: [advice needed] Weak brake Booster? |
Two things to check. I would disconnect the vacuum hose at the booster and measure the vacuum. There is also a check valve in the system that could be not functioning properly or installed backwards. I would also see how the brakes feel without the vacuum line connected to be sure you don't have something else going on. _________________ ☮️ |
Posted: Sun Jul 16, 2017 6:42 pm Post subject: Re: [advice needed] Weak brake Booster? |
MarkWard wrote: |
Two things to check. I would disconnect the vacuum hose at the booster and measure the vacuum. There is also a check valve in the system that could be not functioning properly or installed backwards. I would also see how the brakes feel without the vacuum line connected to be sure you don't have something else going on. |
Hi Mark and thank you for trying to help me!
I don't have anything to measure the vacuum unfortunately
I will put my finger on the hose end and "feel" it. I can disconnect later at the intake to compare the feel.
This damn thing has to be running by Tuesday morning
I will try to connect without the check valve see if it does something. I have spare ones at least.
I will also try to get the feel of the pedal with the vacuum disconnected, but my logic tells me it's the same as if it would be braking with the engine off....
Report soon, eating on the fly and back wrenching ! _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Sun Jul 16, 2017 7:20 pm Post subject: Re: [advice needed] Weak brake Booster? |
Ok I went to unplug the elbow fitting at the booster and tested the vacuum with a finger to plug the hose. It's pulling vacuum damn fine I would say!
I shut the engine off and kept my finger on it for a few minutes to try to see if the hose held vacuum. I held it for 2 min until I got bored with no drop in vacuum. So it's definitely pulling vacuum rather fine.
It can only be the booster then. Dammit, like I had nothing else to do than to drop the dashboard right now
With engine off, the pedal is hard but doesn't hit a stop though.
With engine on, if I press the pedal twice, it comes to a stop somehow feeling like it hits something metallic if I press repeatedly fast, like the throw is too short? If I keep reving the engine, that stop disappear and I can go past it.... _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Dwighia Samba Member
Joined: November 26, 2010 Posts: 78 Location: Arlington, VA
Posted: Tue Nov 16, 2021 5:36 pm Post subject: Re: [advice needed] Weak brake Booster? |
I have that similar "metallic" sounding brake pedal on the last 1/2 inch of travel on my '84 1.9 camper. I've also replaced all the parts except the brake booster, but I also get good results in testing the booster.
So I'm at a loss.
Did you ever get your brakes to work with confidence and without that hard clunk metallic sound at the end of the brake travel?
Thanks,
Dwight _________________ '71 Ghia Sedan
'68 Ghia Convertible
'84 Vanagon
If you dismantle a VW engine and reassemble it enough times, will you end up with enough extra parts for another engine? |
Posted: Sat Nov 27, 2021 5:54 pm Post subject: Re: Weak brake booster? [advice needed] |
Thanks ALIKA T3,
Anyone out there with this weird metallic clunk at the end of their brake pedal? Van stops but I just feel like I'm not getting 100% braking power.
'84 Vanagon 1.9 automatic w/o AC or power steering. All new brake parts except for booster.
Thanks _________________ '71 Ghia Sedan
'84 Vanagon
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2320 Location: Adobe Jungle USA
Posted: Sat Nov 27, 2021 7:36 pm Post subject: Re: Weak brake booster? [advice needed] |
You don’t have to drop the dashboard to fix the booster. Take off the cluster, unbolt the mounts and the whole assembly pulls out the top. Would be a good time to look at the clutch clevis too, and lube things up. I put in a larger BMW booster over the summer and finally getting a modern brake feel. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Sun Nov 28, 2021 10:08 am Post subject: Re: Weak brake booster? [advice needed] |
Thanks for the encouragement on removing the dash. I'm only slightly intimidated by the the dash, but I mostly would really hate to replace the booster if the problem is really something else. Here's what I have:
1) I have replaced all the brake components except the proportioning valve and the booster.
2) I don't have any hissing or anything that would suggest a vacuum leak.
3) My pedal does the following:
Engine off:
1/8" initial play in pedal
3/4" to start engaging the brakes
2" to what feels like the end of the braking
With engine on:
3" to a hard metallic sounding clunk
No amount of pumping the brakes makes any difference.
Also full disclosure: I did not make any adjustments to the booster push rod when I installed my new master cylinder.
Any help would be muchly appreciated.
'84 Vanagon
